Looking for a replacement rear wheel - Cannondale Quick
I have a C’dale Quick 4 2018 (V brake, not disc). I’m looking for a second rear wheel, and would like to match the existing C4 wheel as closely as possible (to reduce adjustments required between wheel changes). Any idea where I could source one? This will make it easy to swap between road tires and path/gravel tires. Not really worried about matching the front, nothing to adjust. TIA!
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 217 Post(s)
Liked 155 Times
Probably you have a 700c wheel, the hub is quick release 135mm. These are the required specs, otherwise you will not be able to mount the wheel at all or use it with your brakes. Worth double checking.
Then you probably want the outer rim width to match the wheel you have so that you do not have to adjust the brakes between the wheel changes. Measure it and chose accordingly. Maybe even build yourself.
