Fixing Lezyne Chuck
Fixing Lezyne Chuck
So I have this Lezyne CNC high pressure floor pump. The chuck doesnt seal very well. I imagine all it would need in a new o ring in there. Can I just replace the o ring or do need the whole thing? Is it possible? What size? Thank you.
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
You could try removing the o-ring from your chuck, and seeing if the o-ring dimensions noted in that post make sense.
Here's a post where someone describes replacing the Presta-side o-ring on a similar Lezyne chuck: Presta O-Ring for Lezyne ABS-1 PRO HV Flip Chuck.
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
...O rings come in various diameters and thicknesses. I have a rubber parts warehouse place here in town, that has a big display of them. So I go there. If you measure the exact inner and outer diameters, and thickness, you can probably order an exact match on Amazon, but you'll probably need to order ten of them.
It worked for me, maybe the site was temporarily down. In any case, here is what it said:
I emailed Lezyne asking for the o-ring spec so I could get some, and they instead sent me two of the parts. Popping out the old o-ring and fitting in a new one sorted everything out.When fitting the o-ring I measured it, figuring it’d be nice to know the size in case I want a quicker replacement of this wear part next time:
OD: 9mm
Profile: 1.9mm
OD: 9mm
Profile: 1.9mm
Quoted: 430 Post(s)
Liked 460 Times
Hopefully new o-rings do the trick. On mine, the threads were slightly stripped so I've got to replace the whole chuck.
Bikes: two blacks, a blue and a white.
Quoted: 445 Post(s)
Liked 847 Times
call them. I've personally had success with Lezyne for my pump - they sent me a couple parts. great team over there.
