1982 Trek 720 advice
Bikes: 1956 Schwinn Corvette, 1979 Schwinn Stingray, 1980 Schwinn Twinn, 1981 Brian Rourke custom, 1983 Trek 720 Touring, 1984 Trek 620 Touring, 1984 Fuji Touring IV, 1984 Fuji Touring III Pub bike conversion, 1997 Trek 520 Touring, 2017 AllCity Spacehourse
Quoted: 17 Post(s)
I'm kind of a newbie and don't know much about component compatibility... I'm looking for suggestions on a 720 I'm about to restore. It's got a strange mix of components - Campagnolo headset and shifters, an Avocet crankset, 700C Weinmann rims with Suzu hubs and Huret derailleurs. I'm wondering if i should replace the Avocet crankset with Sugina RT I have. And while I love Campy components on my road bikes, the shifters seem kind of out of place. I have spare Suntour shifters I could replace them with. I've also got a nice set of Shimano M700 high flange hubs. Would they pair well with the Weinmann rims? I've heard good things about Huret derailleurs so I'm interested in sticking with those. Thoughts?
Any advice or suggestions are appreciated!
Thats an '83 720, first year for canti brakes. The '82 would've used center pull Gran Compes. The crank is a nice upgrade over stock. Personally I would leave it; but I'm biased as it's the same one I run on my '83 720. I'm sure someone will be along shortly to tell you the rear Huret derailleur is a ticking time bomb; but treat it well and don't abuse it and it'll likely be fine. Just don't pedal backward or push the bike backward unless you know the RD is aligned with the chosen gear. Otherwise you get binding and things go sour. Nice bike btw.
My bikes: '81 Trek 957, '83 Trek 720, '85 Trek 500, '85 Trek 770,'81 Merckx, '85 Centurion Cinelli, '85 Raleigh Portage, '92 RB-2, '09 Bianchi
Likes For nesteel:
Quoted: 801 Post(s)
Liked 1,002 Times
Nice bike, I am partial to Avocet components. They were make by Ofmega in Italy I believe. Please correct me if I'm wrong here. Regardless of who made them for Avocet they are nicely made and look great. I wouldn't change a thing. Ride the bike a bunch and see how you like everything. If there are issues, address them. If not, ride on.
I don't see a problem with mixing component sets.
You might get comments about the foam handlebar covers. Most of us don't like them. I have to admit, that when they were popular, I hated them. This was a standard upgrade in the bike shop. Now that I am more, ahem, mature, I have to admit that they do the same thing as modern tapes. For me, I would replace the foamies for some modern tape. Or Newbaum's cushioned cloth tape. They just look better.
Likes For Velo Mule:
Old fart
Quoted: 3571 Post(s)
Liked 3,369 Times
Yesa, the Avocet cranks were re-branded Ofmega cranks. While the inner ring mounting stand-offs are arguably not as strong as the inner ring mounts on a Sugino RT crank, the Avocet arms are forged, while the RT arms are cast.
Quoted: 5877 Post(s)
Liked 3,445 Times
This is all good advice. The bike is an '83 and the component group is good on this bike. Other than replacing the consumables and overhauling the bike, I wouldn't change much on that bike if it were mine. I would get rid of the bar tape, find some hoods for the brake levers, and replace the downtube levers with suntour bar end shifters. Those derailleurs are actually very good. I used them when I took my '83 Trek 720 on a cross country trip. @nesteel is right though you do not want to be careful about binding. I find that with the Huret RD on this bike, you need to let up a bit on the pedals before shifting. That's true with any RD actually but moreso with this one than with other designs. Other than that it is a fine rear derailleur that can take up unbelievable amounts of chain and does a fine job of shifting wide ranging gearing.
Likes For bikemig:
Bikes: Trek 7.5 Hybrid, Trek 1.1 Road, Holdsworth touring,Raleigh International,Ritchey Commando,Italvega Speciallissimo,et.al.
Quoted: 20 Post(s)
Liked 10 Times
You have a really great bike . Depending on what you would like to do, I would suggest, like others, a set of SunTour bar end shifters and perhaps replacing the rear derailleur with a Shimano Deore, or XT, and perhaps a Shimano front derailleur. Although they shifted OK, I was never a fan of the Huret Duopar front and rear derailleurs. As noted, the Avocet crankset is of excellent quality. I am currently in the process of building up a 1984 burgundy 720 frameset into a nice touring bike-joining the many others that I already own. This one will be special.
Likes For jacksbike:
Quoted: 1361 Post(s)
Liked 422 Times
Very nice original! If all components function, I wouldn't change them. Sure there's minor quips of this or that, but that's the charm of these classics.
On that note, the Weinmann concave rims haven't been mentioned. Popular to some for their cool factor but just as many probably don't like for the hassle of water drainage, non-hooked bead and weight. I like the unique and using required wire bead tires, keeping a close monitor on air pressure is no biggie.
When that bike was new Avocet cranks would have been considerably more expensive than Sugino and considered an upgrade. They are a bit on the light side but high quality.
Campy shifters are dead reliable and shift perfectly pretty much forever. (except for the last couple years with the nylon inserts but let's forget that) No point in switching them unless you go to bar ends or something. I like duopars but I've never thought of them as super reliable. They are super cool but be cautious. Kind of like a Citroen DS.
I hated grab on grips then and hate them still, so I'd encourage you to get some new tape. Some people liked them, obviously. There were at one time a thinner version called Grab-on racing grips, which time seems to have forgotten.
Likes For Salamandrine:
tantum vehi
Quoted: 1166 Post(s)
Liked 966 Times
Solid bike and solid advice! I love bar ends, so that would be my suggestion too. But if you don’t, ratcheting Suntour DT shifters would be better and more functional than the campy levers.
But ride it for a while and see how it like it as is.
Congrats on a classic!
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Likes For mountaindave:
Quoted: 17 Post(s)
Thanks for all the great advice. I'm curious about the feedback on the year, Everyone seems to agree that it's a 1983. Interestingly, the Vintage Trek website lists the serial number, 34327 as a 1982. Vintage Trek Bicycle Frame Serial Numbers in 1982
Maybe I'm reading it wrong. Is there another source for SN data?
Quoted: 2350 Post(s)
Liked 1,729 Times
No, you're reading it right. Another anomaly, Mandela effect, timeline shift, whatever. Or maybe the BB was just struck with an SN in '82 and sat on a shelf for a year. The above-mentioned differences, at the very least the under-the-BB shift cable routing, lean toward an '83. I have a similarly mysterious 400 series, early '82 serial number (10920?), but clearly sporting the same cable routing as yours. Interestingly, and perhaps NOT coincidentally, mine also has a Tim Isaac BB shell (60TSI in my case). Maybe a number of his shells / lugsets were set aside for later builds.
Hmmm, trivia question that MIGHT shed a twinkle of light, for any "real" '83 owners following. Do the '83s that have an actual '83 SN do the cable routing with grooves and bolts like shown above? Or do they use the more commonly found plastic guide screwed into the shell? My mystery bike is cabled like the OP's; maybe that's a characteristic of the TSI shells :shrug: .
Likes For madpogue:
Quoted: 17 Post(s)
Interesting comments about the Weinmann rims. I am not familiar with them. Can you elaborate on your comments about water drainage and the requirement for beaded tires? And also tire pressure? Thanks for your help and great feedback!
Extraordinary Magnitude
Quoted: 2597 Post(s)
Liked 1,678 Times
Remember there are no 1985 Trek 720s- every single one of those frames were built in 84. The big cue in seeing them is the downtube decal (although there are other little differences- the DT decal is easily seen).
To that end, even though the frames are (usually) the same between the frames decaled as 84 and 85- 85s are referred to as 85s because of the decal. Additionally- as I recall, bikes built in October and later are generally built to be next year’s model. In the case of the 82 vs 83- the 83 had canti bosses- so there’s a concrete difference-
Commence to jigglin’ huh?!?!
Likes For The Golden Boy:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,445 Times
Novel look and reportedly hella strong, but I've never been tempted to use them myself.
Likes For thumpism:
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
Assuming that the bike fits you, then I agree with others who advised removing the bar foam and replacing the downtube shifters with SunTour barcons. Any decent cork tape would do for you. Those would be my only changes at this point. And, of course, new tires.
Quoted: 1125 Post(s)
Liked 1,704 Times
Those are really strong but they are hookless rims and can not handle really high pressure and folding tires very well. The concave rims were also inconsistent in the grinding of the welds. The set I have are overground creating divots that are catchy on the braking surface.
Likes For Mr. 66:
Quoted: 17 Post(s)
Finished up the 1983 Trek 720
Likes For endoftheisland:
Quoted: 1924 Post(s)
Liked 1,954 Times
It looks like you worked through some component comparability issues and adjusted it to fit. It looks great. Five speed is plenty with the 1/2 step plus granny. If you haven't yet, read up on that. It is a kick.
Likes For Classtime:
missing in action
Quoted: 41 Post(s)
Liked 48 Times
Looks great, nicely done! Strangely enough, this afternoon I was browsing ebay and saw a familiar group of mismatched components: Avocet, Huret, Campagnolo!
https://www.ebay.com/itm/SEROTTA-NOV...8AAOSwsQJeuIwF
Likes For Chris_in_Miami:
Liked 1,678 Times
Nice build!!! I dig the Shimano cantis on there!
Bikes: Current: 2016 Bianchi Volpe; 1973 Peugeot UO-8. Past: 1974 Fuji S-10-S with custom black Imron paint by Stinsman Racing of PA.
Quoted: 215 Post(s)
Liked 204 Times
The concave Weinmann rims over the 35+ years I rode them only needed truing once They just never went out of round or true, even as my weight fluctuated up to Clyde level for a few years and back, and some rough road riding. I used them with Dia-Compe center and sidepulls, Mafac Racers, and Shimano 600 calipers with stock shoes or for a while the finned shoes and coolstops salmon pads. They never exhibited undue brake track wear. A lot of our riding would now be considered gravel as we rode on canal towpaths and logging trails in PA. One thing I did not do was ride in the rain. That rim used to be a 'go to' rim for tandems and touring and could be had in 40 hole and special order 48 holes using Phil Wood hubs. My wheel builder said they were not the lightest, but were one of the strongest rims out at the time. I never saw a set as OEM.
They were not a true box rim, but had two small boxed areas at the edges of the concave and had ferrules. I kept my bike clean and the rims still looked great when I left that bike go.
Hope this helps.
Likes For Bill in VA:
tantum vehi
Liked 966 Times
+1 on both. Looks like you don’t have a wide enough FW to take advantage of your half step crankset. If it’s 50/45, you will need 14-17-21-26-32 to make it work properly. It’s not easy to find, but pastorbob might be able to build one up for you. I’ve seriously considered having him make me a 6s with an added 12t sprocket.
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
