need good air gage for compressor.
Quoted: 538 Post(s)
Liked 466 Times
Hey guys,I have a nice compressor and need a recommendation for a good tire pressure gage that attaches to the compressor line. I need something fairly cheap ,but still isn't just junk.
Quoted: 6193 Post(s)
Liked 4,809 Times
You do realize you can't just attach it to the line and measure your tire pressure. At least not unless you regulate the pressure of the compressor to what you want your tire to be. Then there is no need for the extra gauge.
This is one air chuck and gauge combo that I see a lot being used by LBS's..... https://www.parktool.com/product/sho...category=Pumps
They have it configured so you are measuring tire pressure and not line or tank pressure of your compressor.
I like bike
Bikes: Roubaix Comp 2020
Quoted: 267 Post(s)
Liked 283 Times
I use one of these: https://www.amazon.com/gp/product/B08K47SRGP
The head on it would not attach reliably to Presta valves so I spent another couple bucks for a new head. Other than that it works great, the main gauge is very well-made.
Quoted: 4204 Post(s)
Liked 3,861 Times
The Op asks for a good gauge but a cheap one. The typical is that the cheap stuff isn't as good at measuring then the more expensive stuff is. Pick one because you are likely to not get both. Of course we don't really know what the OP means by "good". It is easy to install an in line gauge (usually hard threaded into the compressor's outlet with a "T" connector). Gauges that are a part of a air chuck tend to be more expensive and the plumbing needs to be such that the line pressure isn't being read and only the tire's is in play WRT the gauge.
I'll tangent here- so many people talk about a gauge's accuracy, how "good" it is. I will postulate that consistency is the more practical aspect. I don't care what my measured tire pressures are. I do very much care that when I fill the tire so the gauge needle reads "X" AND the ride/performance of the tire at "X" is what I like, the next time I pump up the tires to "X" the pressure is pretty much the same. Of course this means that the rider will be willing to find out what pressures work for them in what conditions and not rely on published numbers that were measured by some other gauge of unknown accuracy.
I have used many different gauges, built into the air chuck and freehand versions from a number of brands, and they all have some drift from each other (and I'm allowing for the slight pressure loss with each gauging). I've seen as much as about 10% difference from the same brand/model when comparing gauges. It is because of this that I discount accuracy claims. Andy
AndrewRStewart
AndrewRStewart
I like bike
Quoted: 267 Post(s)
Liked 283 Times
In any case I agree repeatability is more important. My built-in hand pump gauge (analog) is always 18psi low, no more no less. So I just get used to adding 18.
Liked 3,861 Times
precision vs accuracy - Bing
The digital gauges mentioned above display precision but of unknown accuracy. So what's the OP's definition for "good"? Andy
AndrewRStewart
AndrewRStewart
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
Do you mean something like this ?
Harbor Freight https://shop.harborfreight.com/media.../3/63049_I.jpg
About $12
About $12
I managed to mate one of these:
https://carsoncitybikeshop.com/pump-...BoCMgQQAvD_BwE
with one of these:
https://www.harborfreight.com/pistol...xoCogYQAvD_BwE
and it works great.
with one of these:
and it works great.
I buy winters brand liquid filled gauges from Amazon for around $20. I put a 0-100 psi model on my ancient silca pump. The same sort of gauge can be attached to a variety of heads, with the 1/4 inch pipe threads and used for car tires. I'm not a fan of measuring bike tire pressure, except when pumping them up with my silca pump. There are other pressure ranges available. Pressures above 100 psi are mostly a thing of the past, at least for me.
https://www.amazon.com/Winters-Stain...9561623&sr=8-4
Quoted: 1572 Post(s)
Liked 643 Times
I made one a lot like JoeTBM's about 25 years ago. I cut the Schrader inflator off at the hose and clamped a Silca Presta chuck in it's place. I don't remember what it cost me, but it was way less than $130.
Likes For Retro Grouch:
https://www.amazon.com/dp/B07SKMLP3Q...roduct_details
This was delivered today, via Amazon. I have a gauge on my Walmart pump (Zefal) but I'm skeptical as to the accuracy.
Liked 4,809 Times
Accu-Gage!
Wow, the very name itself will have me running scared and dubious of any pressure reading.
But I have been surprised by the accuracy of some of my cheap gauges. One being the one on the cheap floor pump I bought from Walmart. It too a Zefal.
Accu-Guage is a pretty well respected name in auto tire gauges (I have four, one in each of our vehicles and one in the garage). My Zefal gauge was reading about 1 lb low, compared to the new gauge.
Quoted: 836 Post(s)
Liked 1,061 Times
+1. Accu-Gage also offers a lifetime warranty and they honor it. They're not super high-end gauges but plenty accurate for cyclists unless you're going for the world hour record in which case you might want to spend $300+ for one. Also handle your pressure gauge like any precision measuring instrument and don't drop it or bang it around and store it where it's protected.
Likes For Warbird21:
Advanced Slacker
Quoted: 2762 Post(s)
Liked 2,537 Times
I bought 3 Accu-gauges of different ranges (0-15, 0-30, 0-60) a couple years ago. 2 of them were so far off as to be useless. They were so bad I wondered if there had been a mismatch between the innards and printed faces.
Guess I just got a bad batch.
Get away from the crap sold on amazon. Go to an industrial supply house. You can get a great gauge that will lead a long accurate life for around $20.
-SP
-SP
Likes For speedy25:
Quoted: 569 Post(s)
Liked 581 Times
Quoted: 569 Post(s)
Liked 581 Times
Unless you have dead weight tester access I would be cautious of calibration. If so you should return them as they were a bad batch. They are grade B ASME B40.1 certified so within 2% of scale in the middle 50% of scale and 3% outside that. So on the 0-15 gauge the error when reading 15 psi can be only 0.45 psi, with the 0-30 gauge for a 15 psi reading it can only be an error of 0.6 psi and with the 0-60 for a 15 psi reading it can only be an error 1.2 psi.
I have this gauge, it is specified to be Grade B by ASME B40.1 which means if you got the one you show it's accuracy is 2% within the middle 50% of range or 25psi to 75psi and 3% outside that range. I use mine for road bikes so I get the 0 to 160 psi range so that it's accuracy is 2% at road bike tire pressured which is much better than I need.
Advanced Slacker
Liked 2,537 Times
i would have returned them, but I had opened them up and see if I could fix them, and just made it worse and was unsure if that was going to make returning a hassle. And in the end these were cheap enough that is just was not worth the the effort at the time.
Anyway, next time I will just return them right off the bat.
