slipping on gears
slipping on gears
Old 08-05-11, 07:47 AM
91bulldog
Bikes: 2010 Giant TCR 2, 2007 Scott Mountain, 2011 Mericer Kilo TT
slipping on gears
Hello,
Here is the story. Let me know what you think
So one day of riding with alot of wind...i shifted to the smallest gear and out of no wear my chain get caught in between my crank and front derailer. It was pretty hard to pull out but with alittle muscle it comes out. After that case, on some gears i feel and see the chain slipping from the rear derailer. If i pedal light, no problem but when i start pedal hard....slips.
My question, is it my front, rear derailer, chain or crank that needs to be fixed or replaced? Or a good old tune up will fix it?
91bulldog is offline
Old 08-05-11, 09:27 AM
wrk101
Thrifty Bill
wrk101's Avatar
Quoted: 1226 Post(s)
Liked 928 Times in 608 Posts
Two different problems. Problem #1 is a front derailleur adjustment problem, Park tool site has an excellent tutorial on that.
Problem #2 is likely a worn cassette or freewheel. Tune up will not fix that. Need to know how many speeds, and whether you have a freewheel or cassette. If you are handy, good cassettes can be found new for about $15, freewheels are less. Should also replace the chain, they can be found pretty cheap as well.
wrk101 is offline
Old 08-05-11, 02:21 PM
gpshay
Quoted: 5 Post(s)
I just had the same problem with the chain skipping on the rear cassette the mechanic examined everything very very closely [i was with him] and it turned out to be the chain .. so of the links did not move freely and stuck just enough to cause the problem .. put on a new scram chain and now no problems... p.s. it was more noticable on the small gears 13,12,11 rather than the larger 28,30 ...
gpshay is offline
Old 08-07-11, 04:25 PM
91bulldog
So a new chain should fix my issue? Is there any difference between a $15 chain and the $50 chains?
Old 08-07-11, 08:06 PM
wrk101
Thrifty Bill
wrk101's Avatar
A new chain won't fix a thing if the cassette is worn out. But if your chain is worn out or damaged, sure.
As far as the cost of chain, I almost exclusively use KMC chain, and typically pay about $5.50 (on line) for a 7 speed chain. 5 and 6 speed chain is less. Higher speed chain cost more (don't know how many speeds you have). KMC makes good, quality chain (several threads on chain quality out there).
wrk101 is offline
124Spider
Bicycle Mechanics
9
09-03-19 03:14 PM
the sci guy
Bicycle Mechanics
24
09-18-15 01:25 PM
boomwater
Bicycle Mechanics
9
08-15-13 04:17 AM
Giant40
Bicycle Mechanics
96
02-21-13 06:54 AM
KapnKaos
Recumbent
17
04-22-11 06:38 PM
