Snap! Pop! Crack-le!
Quoted: 1363 Post(s)
Liked 1,674 Times
After two days of fighting traffic driving the car to work I was looking forward to a nice relaxing bike ride into the office today. The first half of the ride was nice and relaxing. Then the cable to my front derailleur snapped, but I was still able to ride and it's not a difficult or expensive fix. But 15 minutes later while gliding around a corner a 3 inch nail injected itself into the sidewall of my rear tire. First I heard the pop, then the simultaneous sounds of air escaping and a tire skidding to a stop. After puncturing the inner tube the nail managed to stick out far enough to smack one of the rear fender supports hard enough to twist the fender enough to tear it half apart and pull the Jagged Edge into the rear tire tearing it and freezing the rear wheel. I was lucky enough over lunch to get the shifter cable replaced and buy a new tire and inner tube. The new fender is on order.It's an SKS p45. The front fenders have quick release clips so that if something gets caught in the spokes the fender disengages and the spokes are saved. However, for whatever reason the rear fenders did not have the quick release clips. I don't remember if that was my doing, or if they were designed that way. Even so it's hard to know if that would have saved the fender.
All in all, still less frustrating than driving.
Likes For BobbyG:
Bikes: ...a few.
Quoted: 2010 Post(s)
Liked 408 Times
Rear fenders don't have break-away clips on SKS, or at least they didn't come with mine. Reasoning is that not having them in front could prove quite catastrophic. On the rear it's likely not, but your fender might get shredded, as you learned today.
Glad you are alright. Sorry about your bike. I will have to remember this in case I ever get real fenders.
Liked 1,674 Times
I remember on the Charge Plug the fender mounting threads were larger than normal. That may be why I thought there may have been clips I didn't use...but I think you're right...no rear clips.
Bikes: 2016 Felt Z85 105, 2016 GT Grade Sora
Quoted: 117 Post(s)
My planet bike fenders don't have a quick release on the rear fender either.
Glad no injuries though
Quick release clips are only mandatory on front fenders according to the German StVZO (not the rear fenders.) SKS Germany is based in Germany and thus follows the minimal requirements of the StVZO, hence the rear fender is toast. Also, it could cause quite a bit of damage to the rear mech is the rear fender came off.
Liked 1,674 Times
Liked 1,674 Times
So I am saving the fender struts since they are already cut to length. On these fenders I had drilled a hole to line up with a thread on the cross bar where rim brakes would be mounted, if there were rim brakes. The hole points down towards the fender and is no doubt intended to be a support for a fender and not for rim brakes. The tear in my fender was 5 inches away from this hole.
Quoted: 5222 Post(s)
Liked 3,576 Times
yikes! that's some radical nail!
good times, NOT https://www.bikeforums.net/bicycle-m...er-mishap.html
I've since added QR tabs front & rear. of course, no mishaps since ...
Quoted: 357 Post(s)
Liked 136 Times
Cold will sometimes affect fenders. After years of use, they will snap. The only one that holds up are metal fenders. They are more costly and a pain to put on. Anyone know the lifespan of say, VO fenders?
Likes For Colorado Kid:
Liked 3,576 Times
Likes For rumrunn6:
Happy banana slug
Quoted: 1531 Post(s)
Liked 1,527 Times
Jinkies! Glad you and your bike didn't suffer major damage.
EDIT: Dang, fooled by a zombie thread.
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Looks like you've ignored multiple indications to mount that rear tire the other way, what's up with that?
Likes For ThermionicScott:
Liked 3,576 Times
Likes For rumrunn6:
Liked 3,576 Times
Likes For rumrunn6:
