Crank spindle stuck
Crank spindle stuck
Hi!
I am new to BmX world and very very excited to ride one.
just got a used Eastern Jane 2007. I wanted to get the BB/crank interface cleaned and lubed before riding so removed the cranks but the spindle wouldn’t come out. I’ve tried penetrating oil and mallet but it doesn’t even budge.
Any suggestions?
thanks!
KT
Any suggestions?
thanks!
KT
Hi!
Any suggestions?
thanks!
KT
Any suggestions?
thanks!
KT
Victimless Criminal
Quoted: 951 Post(s)
Liked 2,212 Times
To my knowledge, the Jane has a Spanish bottom bracket (consisting of two bearings that press directly into the bottom bracket shell, a spindle, and a spacer tube that the spindle runs through and keeps the bearings from being side-loaded), so there isn't anything preventing the spindle from coming out other than age/corrosion. I hesitate to recommend that you just "hit it harder," because that can damage the ends of the spindle where the crakarms and fixing bolt go, so give the penetrating oil some time to work. Re-apply often, and lay the bike on its side so that it flows between the spindle and the bearings. Flip the bike over and do the other side. When you do get the spindle to give, go ahead and replace the bearings; they'll likely be contaminated by the same corrosion that has frozen the spindle in place.
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 107 Times
Hi!
Any suggestions?
thanks!
KT
Any suggestions?
thanks!
KT
