Modern lugged steel disc brake frame with carbon fork & fully internal cable routing
Old 08-12-21, 06:51 PM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 7755 Post(s)
Liked 4,736 Times in 2,732 Posts
https://bikerumor.com/2021/08/12/bat...ake-road-bike/
Battaglia Portofino 40th anniversary edition.
Custom geometry, carbon fork built in Italy, lugged 2OS tubing, fully internal cables, cromovelato paint with fade.
Pretty slick.
mstateglfr is online now
Likes For mstateglfr:
Old 08-12-21, 08:11 PM
MattTheHat
MattTheHat's Avatar
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 656 Post(s)
Liked 2,858 Times in 994 Posts
Oh, that’s tasty!
MattTheHat is offline
Old 08-12-21, 08:27 PM
LibertyFLS
GDFTR
LibertyFLS's Avatar
Bikes: '74 Falcon San Remo, '80 SR Semi Pro, '88 Trek 360, '18 Fairdale Goodship
Quoted: 51 Post(s)
Liked 82 Times in 44 Posts
Man that’s beautiful!!
LibertyFLS is offline
Old 08-12-21, 08:29 PM
big john
big john's Avatar
Quoted: 4242 Post(s)
Liked 3,637 Times in 1,975 Posts
Pretty, but $5800 for a frameset is out of my budget.
big john is offline
Old 08-12-21, 09:01 PM
tomato coupe
Quoted: 1845 Post(s)
Liked 2,914 Times in 1,210 Posts
Why do they put a carbon fork on that bike? A steel fork seems more appropriate.
tomato coupe is offline
Old 08-13-21, 07:31 AM
mstateglfr
Sunshine
mstateglfr's Avatar
A good portion of why is the carbon fork has a D shaped steerer tube to allow for internal cables. Also, most all modern mid-high end steel road and gravel bikes from builders use a carbon fork at this point.
Old 08-13-21, 07:43 AM
delbiker1
Mother Nature's Son
delbiker1's Avatar
Quoted: 614 Post(s)
Liked 804 Times in 471 Posts
It is a gorgeous bike, a real ego booster. But for me, that is about all it would be. If I were considerably younger, in fine financial shape, and wanted a top of the line, modern steel frameset, this could well be it.
delbiker1 is offline
Old 08-13-21, 07:54 AM
robbyville
robbyville's Avatar
Bikes: Speedvagen Steel
Quoted: 402 Post(s)
Liked 197 Times in 135 Posts
Stunning, love the chrome lugs!
although I’m not in the market and will never get rid of my Speedvagen, I recently saw this Ti disk that they did that had me yearning.
robbyville is offline
Old 08-13-21, 08:55 AM
prj71
Quoted: 2023 Post(s)
Liked 623 Times in 410 Posts
Because carbon rides better than steel.
prj71 is offline
Likes For prj71:
Old 08-13-21, 09:15 AM
tomato coupe
There's no reason you couldn't make a D-shaped steerer tube on a steel fork.
I don't understand why they do that either.
Forks or whole bike?
Old 08-13-21, 09:45 AM
mstateglfr
Sunshine
mstateglfr's Avatar
True. And that is something I thought about before responding, but I mentioned the D shaped steerer since that was in the article and is typically part of how brands manage to hide their cables.
I think any steel fork on that frame would look out of place due to the tubing size. Its actually quite larger than 2OS tubing. A skinny steel fork added to that size tubing would look more out of place than some of Cannondale's offerings back in the day.
Personally, I like steel forks. Its what I have on all my road bikes and also my old gravel bike turned commuter. But my current gravel bike uses some various shaped and sized 853 tubing for the main triangle and a gravel fork. I think the wider fork blades match well with the larger frame tubes, especially the downtube.
Old 08-13-21, 02:29 PM
prj71
Both.
prj71 is offline
Old 08-13-21, 02:55 PM
Koyote
Quoted: 4919 Post(s)
Liked 7,086 Times in 3,070 Posts
Pretty slick.
For 5,000 Euros, I think you could do better from a custom builder.
Though I will admit that it is very pretty.
Koyote is offline
Old 08-13-21, 03:35 PM
mstateglfr
Sunshine
mstateglfr's Avatar
It isnt what I would get if I were to go custom again, but I dont think many builder could currently do what these guys have done. Fully internal cables is no small feat. It isnt really what I care much about as my gravel bike is fully external and my road bikes have just the rear brake cable inside a tube. But its really no small feat.
Its a solution to a problem that doesnt exist for me, but its super neat to see the efforts to continue to innovate.
This bike is clearly for the trekmoguls of the world.
Old 08-13-21, 03:40 PM
Koyote
Yes, true, I was missing the full internal routing. Any custom builder does charge a fair bit extra for that -- if they even do it.
On my Di2 bike,I got the bar-end junction box A, and had the bluetooth module tucked inside the frame -- and it makes for a tidy front end. Having all of the cables inside the frame would be very clean and attractive.
Koyote is offline
Old 08-13-21, 04:59 PM
CliffordK
CliffordK's Avatar
Quoted: 15645 Post(s)
Liked 3,111 Times in 2,317 Posts
I assume the bike is built to spec. Color, size, etc. I'm not quite sure what else you would expect from "custom". Would they let you specify accessory mounts?
As far as a steel fork, the company does seem to put steel forks on most of their bikes.
My guess is that a typical steel fork would look disproportionate to the bike. And, it might be difficult to keep the weight down for an oversized fork.
CliffordK is offline
Old 08-13-21, 05:26 PM
Koyote
Sorry, I wasn't clear: I think you could get a custom steel frame (with cf fork, if you like) that is as nice as that for a lower price.
But for a person in this price range, a few hundred (or a thousand) dollars either way is probably no biggie.
Koyote is offline
Old 08-13-21, 05:36 PM
CliffordK
CliffordK's Avatar
I could imagine 5000€ for complete build. Campy Super Record, SRAM Red, etc. Hydro discs. Perhaps mix and match a bit.
It is a little expensive when one has to consider another 2000€, or more for the components.
Still, that is an extraordinarily sleek build for steel.
Old 08-14-21, 07:35 PM
chaadster
Thread Killer
Bikes: '15 Kinesis Racelight 4S, '76 Motebecane Gran Jubilée, '17 Dedacciai Gladiatore2, '12 Breezer Venturi, '09 Dahon Mariner, '12 Mercier Nano, '95 DeKerf Team SL, '19 Tern Rally, ‘21 Breezer Doppler Cafe+, ‘19 T-Lab X3
Quoted: 2004 Post(s)
Liked 1,080 Times in 656 Posts
Wow, that’s amazing. And custom sized means they’re making custom lugs, which is a ton of work very, very few builders can swing at any price. I’m thinking that’s a pretty sweet frameset deal for ~6k USD, and were I able to throw down something like $12k for a bike, that rig would suit me just fine.
chaadster is offline
Old 08-15-21, 04:45 AM
bruce19
bruce19's Avatar
Quoted: 1588 Post(s)
Liked 1,047 Times in 614 Posts
That is a beautiful bike. Not one I would buy but that's simply a matter of economics. However, seeing a quality steel bike does make me appreciate my GURU Sidero even more. So happy to have it.FWIW I bought this bike built with SRAM Rival and Mavic Aksiums from a friend for $1200. She had gotten it through a sponsor and it didn't fit her well enough. She rode it about 6 times and sold it to me. I upgraded with SRAM Red and Mavic USTs. I totally love this bike.
bruce19 is offline
Old 08-15-21, 07:04 AM
mstateglfr
Sunshine
mstateglfr's Avatar
...and the obligatory pic has been added.
