Vintage Frame Tire Fitment
Old 12-21-21, 06:29 PM
Rdmonster69
Shawn of the Dead
Quoted: 241 Post(s)
Liked 405 Times in 193 Posts
I am building a 2001 Litespeed Classic frame. Factory it came with 700x23. I would like larger tires but am unsure of the max size that would fit. I imagine 700x25 would fit OK but would like a little bigger if possible. Im hooked on the fat tires that came on my Trek SLR !!
I am using Dura Ace 9100 rim brakes and plan on getting a set of Dura Ace C40 wheels. I know I can't go big with this bike but am seeking ideas for options.
Thanks in advance.
Rdmonster69 is offline
Old 12-21-21, 07:52 PM
HillRider
Quoted: 1815 Post(s)
Liked 751 Times in 546 Posts
If your frame is anything like mine ('96 Catalyst, 2006 Tuscany) anything bigger than 700-23 is iffy and bigger than 700-25 is likely impossible. Depending on the fork you have it's likely to be equally the limiter.
HillRider is offline
Old 12-21-21, 07:57 PM
canopus
canopus's Avatar
Bikes: Road, Touring, BMX, Cruisers...
Quoted: 133 Post(s)
Liked 167 Times in 106 Posts
Real simple... Measure.
Place wheels into frame, measure your clearance from the rim. Measure width, measure from rim to brake bridge in MM. That will give you an idea on the largest tires you can run. Give yourself 2mm in clearance for safety (If you measure 29mm from rim to bridge, (29-2=27) so for safety go with a 25mm tire.
You sizes are 700x23, 700x25, 700x28, 700x30, 700x33. I wouldn't expect you to need much over that on a Litespeed. If you do, you probably need to reevaluate frame selection.
1984 Cannondale ST
1985 Cannondale SR300
1980 Gary Littlejohn Cruiser
1984 Trek 760
1981 Trek 710
Pics
canopus is offline
Old 12-21-21, 08:12 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 3352 Post(s)
Liked 1,988 Times in 1,301 Posts
Even easier is to try a wider tire and see if it fits. Since tire labels are not measurements and rim internal widths effect tire profile one can't really use measurements as the final word. Shops I have worked in will allow a customer to test fit a tire to see what, in real life with the real rims and frame/brakes, will fit with what clearances. When dealing with tires and it comes down to a couple of mm's only a true trial counts. Andy
AndrewRStewart
Andrew R Stewart is online now
Old 12-21-21, 09:02 PM
Rdmonster69
Shawn of the Dead
Quoted: 241 Post(s)
It's probably similar. The fork is modern tho and is sometimes used for gravel bikes so it will be fine. I may put the 700x23 wheelset from my other Trek on just to see what it looks like.
Old 12-21-21, 09:50 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3483 Post(s)
Liked 1,784 Times in 1,152 Posts
There ya go. Your frame, wheels, and whatever you can scrounge up for feeler gauges will tell you way more than we can.
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 12-22-21, 08:27 AM
L134
Bikes: 1978 Bruce Gordon, 1977 Lippy, 199? Lippy tandem, Bike Friday NWT, 1982 Trek 720, 2012 Rivendell Atlantis, 1983 Bianchi Specialissima?
Quoted: 245 Post(s)
Liked 65 Times in 44 Posts
Switch to tubulars. A 23mm tubular will ride like a 28mm clincher, only better.
L134 is offline
Old 12-22-21, 01:23 PM
HillRider
Andy is exactly right. I had an 1992 Trek road bike that came with 700-25 tires that fit perfectly. When they wore out I replace them with another make of "700-25" tires that wouldn't clear the chainstays near the bottom bracket. That said, every make of 700-23 tires I've installed on my Litespeeds have fit well.
Old 12-25-21, 05:05 PM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1407 Post(s)
Liked 976 Times in 666 Posts
...whatever you can scrounge up for feeler gauges...
Hex drivers are a great tool for this.
dsbrantjr is offline
Likes For dsbrantjr:
Old 12-26-21, 08:28 AM
Bruizer
Bruizer's Avatar
Bikes: Grazzini,Litespeed,and Pinarello
Quoted: 20 Post(s)
Liked 52 Times in 18 Posts
I have a 2004 Litespeed Classic with 700-25 Continental GP5000. They fit with no problem at all. I canít speak about any other brand of tire because Iíve never tried any other tire.
Bruizer is offline
Old 12-26-21, 09:47 AM
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor S/S, Nashbar 3sp commuter
Quoted: 602 Post(s)
Liked 698 Times in 393 Posts
Thanks in advance.
Iím running 25s (Rubino Pros) on my 2000 LS Vortex with Ouzo Pro fork. With C17 wheels (Campag Zondas) the actual measured tire diameter is 26-26.5 mm. Thatís as wide as I would comfortably go.
Litespud is offline
