So NOW what? (vintage Raleigh content)
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
I added to the years-long Raleigh Grand Prix thread over on the C&V forum ( Here )
I was moving ahead with the switch from the original steel 27” wheels to some alloy 700c wheels I had on hand when I hit a snag: the front fork is WAY narrower than 100mm. (see pic)
We’re talking like 80mm! I had read Sheldon’s pages, and threads here, about how it would be narrower, maybe 90-92, and spreading the fork a bit, but come on, man. You can see that my Dutch-made GP has Brampton track hubs and apparently a super narrow width.
Assuming this is not a distance that can be overcome by spreading (I don’t want to ride a compromised fork), I need to either
1. Stick with 27”, which will mean buying 27” tires, which aren’t a great deal these days and precludes wider tires, and also living with the heavy steel wheels.
2. Find another (cheap/free) donor Raleigh with a more normal spacing and use that fork
3. Get a new fork, which means getting a new headset (as the Raleigh is 26tpi, not 24).
Where I need help is re: option 3 (if I even want to spend the money!) on how to identify a fork and headset that would work.
Would something like this work? JIS fork
I believe what I need is a J.I.S. fork, as the only difference between that and the Raleigh is the TPI, right?
And then can I just use a regular 1” threaded headset top race and nut to mate with the new fork, but retain the Raleigh cups, or do I need to have the whole headset replaced?
Thanks for any help
Thanks for any help
Monkey Boy
Bikes: '22 Surly Straggler, '15 Breezer Downtown EX, '19 Motobecane Record (fixie)
Quoted: 76 Post(s)
Liked 89 Times
I will measure when I get home, but I might have a spare (narrow) old-school high flange hub if you're interested (you'd pay postage only)? It's the style with 2 wing nuts for the 'quick release'
Artist | Musician | Bass Player
Life is what happens to you while you're busy making other plans. (o.o)
BMX Connoisseur
Bikes: 1988 Kuwahara Newport, 1983 Nishiki, 1984 Diamond Back Viper, 1991 Dyno Compe
Quoted: 399 Post(s)
Liked 108 Times
You will need the right sized spokes, but you could lace the old hubs to the new rims. Or have you already thrown them out?
Likes For cbrstar:
xlbs
Bikes: True North TI, Miyata 1000LT, Rodriguez tandem, Fontan vintage road, Sekine vintage road, Catrike recumbent
Quoted: 10 Post(s)
Liked 7 Times
Why not rebuild the wheel to 700C using your hub?
Likes For xlbs:
Quoted: 219 Post(s)
Liked 217 Times
Mostly cost, and because I've never done wheelbuilding before.
(I've stripped & restored metal, paint and refinished, assembled from frame up, cleaned and repacked or replaced headsets, BBs, cranks, pedals, brakes, stems, shifters, bars, tape/grips, cables, chains, front & rear ders, posts, seats, swapped hubs & freewheels, so I'm not a noob, BUT ---- I've never unlaced or built up a wheel, or even trued one.)
Quoted: 2026 Post(s)
Liked 1,095 Times
There are a lot of on-line tutorials and excellent books showing how wheel building is done. If you get appropriate rims and spokes and just relace the new rims to your current hubs, a good bike shop could complete the tensioning and truing at a relatively low cost. The needed tools are simple and low cost, basically just a properly sized spoke wrench and a screwdriver to spin the nipples in place.
BTW, have you checked to see if your brake pads will adjust the needed 4 mm lower to align with 700c rims?
Quoted: 219 Post(s)
Liked 217 Times
It hasn’t been ridden in decades, and thought I'd try it out, maybe keep it as an extra just-riding-around bike or give it to a family member, but I wanted to at least replace the wheels/tires, saddle, bars, stem, pedals with stuff I already had around that is new/newer, but that won't wreck the overall aesthetic. Then if I DIDN'T enjoy riding it in slightly-improved form, I could put it back as-was and sell it on, cleaned, and rehabbed, to someone else - lot of work, but I enjoy the learning experience and the work regardless).
It's clear to me now that I've gotta figure out whether it's a worthwhile project for me if I'm getting into additional expenses and time.
