gravel tires..32's??
Quoted: 722 Post(s)
Liked 353 Times
can i call my bike a gravel grinder while riding 32's Ritchey tires? Entering my 1st gravel event on 23 of may here in NJ.
Thread Killer
Bikes: 15 Kinesis Racelight 4S, 76 Motebecane Gran Jubilée, 17 Dedacciai Gladiatore2, 12 Breezer Venturi, 09 Dahon Mariner, 12 Mercier Nano, 95 DeKerf Team SL, 19 Tern Rally, 21 Breezer Doppler Cafe+, 19 T-Lab X3, 91 Serotta CII
Quoted: 3078 Post(s)
Liked 1,631 Times
When I was running 30c, I called mine a “dirt dancer” rather than a “gravel grinder,” hoping to evoke a sense of the grace and elegance required to successfully hustle a relatively narrow tire at speed down a rough, dirt road. 😄
Personally, I think 32s are more dancers than grinders.
Maybe we can call bikes with 32, 35, and 38c “rubble rounders,” and leave the grinding to the +40c fatties…
Likes For chaadster:
Quoted: 693 Post(s)
Liked 903 Times
I’d call that cyclocross bike.
Likes For Ghazmh:
Guest
Quoted: 1346 Post(s)
Liked 3,269 Times
Likes For Rolla:
Expired Member
Quoted: 3634 Post(s)
Liked 5,310 Times
^^^Haha- I ride some GK slicks in 32. Nice tires but with my mediocre handling skills, I can only ride smooth, hard packed dirt. Kudos, OP if you are able to enjoy a gravel event using 32s. Full report after, please.
Thread Killer
Liked 1,631 Times
Sunshine
Quoted: 10897 Post(s)
Liked 7,384 Times
Everyone was going to laughat you behind your back at the race. But now that you have 32mm tires, they will openly laugh at you.
All seriousness, ride what works for you and call the bike whatever you want.
I am not sure if I have ever called my bikes 'gravel grinders'. That term is...just not for me.
Randomhead
Liked 3,662 Times
It grates on my nerves just to type "gravel gr----" -- okay, I couldn't do it.
I have no idea what the gravel is like in NJ. Around here, I am not sure 32mm tires would work. Now I'm curious how many people do Keystone Gravel on tires that size. I hear about people riding D2R2 with smaller tires, more power to them.
I rode for a year with 30mm cx tires. They were pretty nice at low pressures, but I got 20 flats that year. At high pressure they were too skittish.
I really don't remember what pressure I rode them at. I never measured them, they always seemed bigger than 30mm
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Likes For Badger6:
Quoted: 1455 Post(s)
Liked 1,477 Times
I ride 32mm GP 5000's on gravel sometimes. It's cool. They're super fast on hard pack dirt and dry gravel roads. Gets a little sketchy when things are loose.
Likes For thehammerdog:
Quoted: 532 Post(s)
Liked 621 Times
Then I'd say you can call it a grinder...I rode slick 32s for years on the gravel forest roads in Germany, it's not the size of the tire, it's how you use it. (Though bigger is comfier, for sure!)
Likes For Badger6:
My Domane came with 32mm Bontrager slicks and I rode them on everything until I got a second set of wheels. With the 32's, I would keep the pressure around 40 psi if I was going to ride a lot of gravel roads and 60+ if I was riding mostly road. At 60+ psi, it was a handful on gravel.
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times
Yah, back in the day, Gravel grinding was done on 28x1-1/4" tires.
Likes For chas58:
Quoted: 532 Post(s)
Liked 621 Times
Just to make you jealous... 😉
Since I live in Belgium, it's a just a short trip back to Stuttgart...so after visiting my dad in Northern Michigan (with my gravel machine, of course) next week, upon my return to the continent in June, I will work for one week then go visit some friends and ride several hundred Kms in the forests above and around the Kessel then ride in the Schwarzwald. I've got a big summer planned, now that I'm vaxxed! Denmark and Sweden are on the agenda too.
#grinduro
#grinduro
Likes For Badger6:
Quoted: 722 Post(s)
Liked 353 Times
i completed the 28 mile version Never knew we had so many dirt roads....it was a blast
used 32 tires worked well but got beat up .
Bikes: Dahon Jetstream p8 (sold), customized Dahon Helios x10, customzed Dahon Smooth Hound x9,customized Dahon Hammerhead 8.0 d7, Planet X Free Ranger (mullet setup 1x11), Planet X Giovanissimi 20 (1x9), Frog 52 (1x9) and Frog 48 1s
Quoted: 249 Post(s)
Liked 221 Times
I ride/rode on Kojak 35-406 on the Fosse way (Roman Road in it the UK) and ex-railway track. As these are "hard pack" even a slick works. I used to do 17miles of gravel commute to that often lead to longer commute on nice summer evenings.
Senior Guest
I think you will be fine with 32mm tires
I use 32 Gravel King tires on my cyclocross bike to ride gravel events in NY.
Farmer's Daughter Gravel Grinder in Chadam, NY coming up in a week. I rode it before with 32-35 mm tires and it was fine. I did not ride the NJ gravel grinder but I assume the roads are similar. I also have a road bike with 32 mm GP5000 slick tires. That bike will also be fine on the NY, NJ "gravel" roads, the only difference is the gearing, road gearing may not be enough to climb some dirt roads with 15 % grade. Had to modify my cross bike gearing to climb some steep and long dirt roads in NY.
Liked 1,477 Times
Tubeless. I don't want to oversell it here. 32mm GP5K's are fine for smooth/hardpack dirt, small gravel and crushed limestone. If your route involves tree roots, larger/sharp gravel or anything loose it probably isn't enough tire.
I frequently do gravel and tame singletrack on 33mm CX tires, so my comfort level might be a bit different than someone who straps on 45s anytime they touch dirt.
I might just play around with some GP5000 TL 32C for a while and see how it goes.
Quoted: 590 Post(s)
Liked 445 Times
On 32's I've done the D2R2 180k with ~13k' of dirt descent, and I wish I had a bit more width due to the consistent braking needed to control myself on the loooong and winding dirt downhills. 32's were doable, but wider would have been easier on my forearm braking muscles for sure. Unfortunately my frame at the time didn't support wider than 32. I now have a gravel bike that supports up to 44mm, just so I don't get caught under-biked in the future.
