Bike Friday and Swytch system
Hi
New member here. Just fitted the Swytch electric system to my wife’s Bike Friday. Initial thoughts are that the battery being in handlebars may affect handling and also the position of the cable from the motor means that the bike’s first fold can’t happen as the cable would be fouled.
I’d welcome any advice about workarounds.
Thanks
Thanks
Bikes: 1999 Bike friday NWT, 2009 Bike Friday Tikit, 2023 silverock Dewy, 2008 Dahon Smooth Hound, 2023 Litepro Trifold
Quoted: 191 Post(s)
Liked 230 Times
Hi, Going to an e-assist mod may require some work.
Bike friday does have this video
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
Hi
Thanks
Thanks
Not sure if you can fit a brompton block adapter on a bike Friday but swytch makes a mount for it. There should be plenty of slack in the wire but if more is needed there are extenders available on Amazon. You want the orange 3 point connector.
You don't really need to access the swytch interface on top of the battery when riding, you can just set and forget the power level.
How does it handle and provide power on the folder?
Bikes: BF NWT
Hi
Thanks
Thanks
PS You realise that ours is Gen 2. Presumably yours will be the new battery - even less range?
Thread derailleur
Bikes: Merlin Extralight '94 & Cannondale Supersix '15
Quoted: 367 Post(s)
Liked 460 Times
Check out a private facebook group at https://www.facebook.com/groups/2679153205653978 . The group includes many with direct experience on all the product line. The group exists merely as a resource, with zero affiliation with the manufacturer.
Bikes: BF NWT
It has been brilliant! Has performed faultlessly and we both love it as it means we can ride together again. As we’ve aged I’ve kept cycling at pretty much the same pace but she had slowed down a lot. Only slight issue for us is the range. Wish it was 50 miles not 50km. I understand that extenders are available and we may look into that.
Not sure I need it now, but I am getting older and don't ride the distance I used too
Bikes: BF NWT
If you ordered the newest (3rd) generation Swytch, they sell mounts and cables to enable one to locate the battery midship or on a rear rack. Get ready for a long wait for a 3rd gen delivery! The latest iteration looks nice, with the ability to carry a spare battery to swap during a ride.
Thread derailleur
Quoted: 367 Post(s)
Liked 460 Times
I bought & paid for two of the max kits that, theoretically, will provide the 30km range over flat terrain.
My plan, for now, involves installation on only one bike, while carrying a spare battery on longer rides.
Also, I will use a throttle rather than the crank sensor, since I may only access it on the few climbs heading home.
They charge too much for a second battery, so for only a couple hundred bucks more I bought an entire kit.
Likes For roadcrankr:
