CO2 and Sealant Compatibility?
Quoted: 1560 Post(s)
Liked 2,919 Times
If I lose a good amount of pressure before the sealant works, is it a good idea to use CO2 to inflate the tire up to pressure? Rumor has it, the CO2 is so cold it could freeze the sealant and render it ineffective. “Wise”-tale or fiction? Time to buy a new emergency pump for the road bike and would like compact pump to fit under the saddle with the saddle bag and have seen these combo-pumps and just don’t know it the CO2 part would be counter-productive. TIA
Road and Mountain 🚴🏾♂️
Likes For tempocyclist:
ignominious poltroon
Quoted: 1429 Post(s)
Liked 2,113 Times
Once the seal forms, you should be ok. You can keep your hand on the place where the puncture is to keep it warm if you are worried. On the other hand, I decided to ditch CO_2 once and for all, since it is so wasteful. I now use an inexpensive Silca frame pump, which I picked up for $175. Eventually, it will pay for itself.
Quoted: 2975 Post(s)
Liked 5,175 Times
Quoted: 6053 Post(s)
Liked 9,164 Times
rsbob , you should give up on the idea of a mini-pump that will fit in your saddle pack, unless you've got a very large saddle pack. Virtually all of them come with mounting brackets that fit alongside a bottle cage, held in place by the same bolts. I like the Silca mini-pumps (Tattico and Gravelero), but there are plenty of great ones on the market.
Likes For Koyote:
Liked 2,113 Times
Liked 2,113 Times
Well, it is no featherweight:
Liked 5,175 Times
Liked 2,113 Times
Liked 2,919 Times
The good news is that sealant does not freeze, only poor sods hands which don’t cover the cartridge when using. Only a sarcastic $175? That’s a steal!
This is what I was using until water rotted its innerds and rusted away the pin which punctures the CO2. It is also a hand pump. I tie it to my seat bag and is relatively small - emergency only. Clipper is to show scale.
Quoted: 2047 Post(s)
Liked 1,708 Times
I paid $40 for 50 CO2 cartridges about 10 years ago and the old cigar box is still stuffed with them. Much less wasteful than a $175 Silca frame pump.
If I get a flat, the dead cartridge is decorated as a Christmas tree ornament but I cannot remember my last flat
Advocatus Diaboli
I imagine if there was worry about freezing, then methodology would be to put the valve at eg. about 2 o'clock position so the sealant is sitting down at 6 o'clock, and then fill by using shorter bursts on/off with the CO2 instead of one long full blast?
Likes For Sy Reene:
Liked 9,164 Times
Liked 9,164 Times
Liked 1,708 Times
Before I learned my lesson and stopped abusing myself with Herse tires, I counted 400 pumps to fill them up. My record was 13 flats on one ride. Admittedly, it was over 200 miles in cold rain. So, a littel pity for Compass tires.
Advocatus Diaboli
Ride with a group where someone else has a pump.. that's the lightest option. After using a CO2 or two, you lose the weight when you leave them on the roadside.
Likes For Sy Reene:
Liked 2,113 Times
For my all-road bike, I regulate the "suspension" by changing the air pressure in the tires, so the hand pump is worth the 100 gm weight penalty.
Liked 2,919 Times
Used the CO2 ability with this pump several times on my MTB until I wised up and went tubeless. The CO2 aspect worked great and then would use the hand pump to top it off, so fortunately never had to inflate solely using the hand pump. I see that this pump has been discontinued after they revamped it and it started exploding plastic shrapnel into people’s hands. I may just go with a Lyzene CO2 head, a couple of cartridges and a lite weight mini pump. I know there are some old threads on mini-pumps. Not willing to spend over $100 for an emergency pump I may or may not use.
Liked 5,175 Times
Likes For tomato coupe:
Advocatus Diaboli
Protip.. use the pump first to bring tire to a pressure that the CO2 can finish.. easier pumping at the beginning of inflation than at the end
Likes For Sy Reene:
Liked 9,164 Times
[QUOTE=Polaris OBark;22735955]The last photo is a CO_2 cartridge, the valve, and a micro hand pump (that weighs 60 gm itself).
/QUOTE]
Right, sorry, I missed that.
That's how insurance works: you pay your money and hope to never use it.
Ah, but then you're sitting there, watching them pump away for god-knows-how-long.
/QUOTE]
Likes For Koyote:
Liked 2,113 Times
Two critical observations:
It is much easier to weaponize a full-size frame pump than a CO_2 cartridge.
They should enable the bb mark-up tags that allow one to write CO[sub]2[/sub].
Likes For Polaris OBark:
Liked 5,175 Times
Liked 2,919 Times
Liked 2,113 Times
