Hybrid disc brakes downgrade vs hydraulic disc brakes
Quoted: 13 Post(s)
Hi! I have these two used road bike deals at hand but I can't absolutely determine on my own which is the better one.
They are two substantially identical bikes from 2020, but one is sold at 1400£ with its stock Shimano 105 groupset and hydraulic disc brakes, while the other at 1150£ because its stock Ultegra groupset and full hydraulic disc brakes system got swapped with a Shimano 105 one and a mechanical-hydraulic converter disc brakes system (i.e., now it has some sort of hybrid disc brakes: hydraulic disc brakes that are mechanically actuated).
I really have no experience to realize if the lower price is actually worth it given the brakes downgrade.
Do you have any opinions on the matter? Thank you very much.
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
Personally, I would go with the 1400 pound stock bike vs. the 1150 pound bike with "Franken-brakes".
Likes For Lombard:
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 389 Times
Likes For vespasianus:
Happy With My Bikes
Quoted: 884 Post(s)
Liked 2,307 Times
Another vote for the stock braked bike. While there may be a good reason that someone did this full hydraulic to mechanical hydraulic combination, I don't know what it would be.
Likes For Chuck M:
Sock Puppet
Liked 863 Times
Probably because they wanted to put the better Ultegra full hydraulic brakes on a bike they were keeping?
Likes For Lombard:
Likes For thin_concrete:
Full hydraulic>hybrid hydraulic>mechanical disc>rim
That being said on a road bike I don't care, the > isn't that much to me on a road bike. My road bike is mechanical disc and I'm perfectly happy with it. Mountain bikes on the other hand hydraulic >>>>>>>>>>>> everything else. Go try them both out and see if you will regret the rest of your ownership by saving the money and going with the hybrid setup. You don't want to think "I shouldn't have saved that 300" every time you get on the bike.
Sock Puppet
Liked 863 Times
Mechanical disc brakes suck.
It is funny how things change over the years. 6 years ago or whatever roadies mostly hated disc brakes of any kind, then they hated hydraulic disc brakes because of all the "difficult maintenance" they took so mechanical ruled, and now everything other than full hydraulic is trash.
ignominious poltroon
Quoted: 2238 Post(s)
Liked 3,429 Times
I think there are two things going on here. One is that hydraulic disc brakes (105, Ultegra level) are demonstrably superior to mechanical disc brakes. (You don't see mountain bikes that cost more than $300 using mechanical disc brakes.)
The other is that the less expensive bike was downgraded to an extent not reflected in the small price drop.
The mechanical disc brakes in the OP sound like they are cable/hydraulic hybrids, which I think (no personal experience) are much more highly regarded. The caliper is hydraulic, but is cable-actuated. However, they are still a bit of a compromise.
Likes For Polaris OBark:
also depends heavily one what hybrid hydraulic brakes are on on it. There are some super cheap ones and some super expensive kinds. Juin Techs run $170 each and are pretty highly regarded or $50 a pop no name brakea off aliexpress.
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2579 Post(s)
Liked 5,634 Times
We have plenty of traditionalists on this forum which is fantastic. It’s similar to preserving classic cars. If it works for them, what could be better? I do take issue with whiners and negativists, but they too are an unfortunate part of life <-Just like me complaining about them right now.
Road 🚴🏾♂️ & Mountain 🚵🏾♂️
Likes For rsbob:
Sock Puppet
Liked 863 Times
Sock Puppet
Liked 863 Times
Cyclists tend to be tradionalists. Whatever has worked for the last 20 years has to be good enough. When something new comes along it is met with suspicion and derision until the pro-riders adopt it, and then it is great and a ‘must have’. Note: The pros usually don’t adopt new tech unless it is proven.
Grupetto Bob
Liked 5,634 Times
I too have two with rim and discs and know of what you speak. Everything has to go through development from the initial offerings, but then there are always the sub-par cheapos which just suck.
Likes For rsbob:
Quoted: 1456 Post(s)
Liked 1,477 Times
For the OP, spending 250£ more to get an actual hydro 105 setup is a no brainer, IMO. The reason the other bike likely has these brakes is because someone wanted to keep the Ultegra stuff and had (or got a good deal on) a rim-brake 105 groupset, but still wanted to list it as "hydro brakes".
pan y agua
Quoted: 1447 Post(s)
Liked 724 Times
I’ve used hydraulic disc brakes, mechanical disc brakes, and hybrid disc brakes.
In my experience, hydraulic disc brakes are clearly superior to mechanical, and hybrids are better than purely mechanical, but not as good as purely hydraulic.
we changed the mechanical trp disc brakes to trp hybrids on our Co-Motion Java tandem. The mechanical brakes were difficult to setup to have enough stopping power without rubbing, and required frequent adjustment. The hybrids were a marked improvement in stopping powe, and also required much less futzing. ( like pure hydraulic they automatically adjust to pad wear, unlike pure cable actuated brakes.)
while the hybrids are a compromise, they have a place, such as for use on a travel bike where you may not want hydraulic lines that can’t easily be disconnected, or to extend the life of a mechanical group.
You could get lost and die.
You could hit a tree and die.
Bikes: SL8 Pro, TCR beater
Quoted: 987 Post(s)
Liked 584 Times
I'd go with the 1st one. Are they both in the same condition and do they have similar mileage on them? That is more important than the actual brake type IMO.
Giant had a similar technology a few years ago (it was cost effective - mechanical levers being cheaper) but it disappeared quickly.
