Shimano Brake and Shifter Cable Sets
Bikes: Pinarello Gavia TSX; Bianchi Intenso
Quoted: 167 Post(s)
Liked 92 Times
I'm looking for replacement shift and brake cable sets for my 10sp Shimano 105 drivetrain. There seems to be 2 levels at the top of Shimano's hierarchy, the Dura-Ace polymer coated sets and the stainless PTFE sets. I have internal cable routing on my CF frame and would like to reduce as much friction as possible.
Anyone care to comment on the comparative value of the two Shimano cable sets? Is the Dura-Ace version just the best and worth the slightly higher price?
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,436 Times
IMO, this is all you need. https://www.ebay.com/itm/255580019410? Obviously, lots of places to obtain these.
Likes For delbiker1:
Quoted: 3511 Post(s)
Liked 2,926 Times
I tried the Dura Ace polymer coated cables, but didn't like that the polymer eventually shredded into a brown lint. I have since discovered what I consider to be the best cables available--the Aligator 31s.
I also use Rock 'n' Roll Cable Magic oil.
Likes For smd4:
Does Shimano have a 5mm brake housing like the 4mm OT-SP41 shift housing? If so a model number and link to Shimano's site, please.
Quoted: 836 Post(s)
Liked 1,061 Times
I didn't have a very good experience with my Aligator 31 strand cables. Bought 2 of them thinking they would keep from fraying longer than any Shimano or Jagwire cables at the shifter of my 6600 Ultegra STI's. They ended up fraying much sooner and the thin strands are more fragile when getting kinked or ??? from some mishap of some sort that happens to most of us at some point. These were properly installed with new Jagwire housings and ferrules, no rough spots.
Liked 2,926 Times
Quoted: 836 Post(s)
Liked 1,061 Times
Probably not much worry about fraying then with the DT shifters. I haven't used their brake cables as I really like Jagwire top tier kits with the housing that's much less compressible giving a firmer feel than anything else except for the solid link types.
Liked 2,926 Times
Totally. I'm using the Aligator31s with compressionless housing. The responsiveness is insane. The housing is about 30% lighter than regular housing. Clearly a win-win-win.
Quoted: 453 Post(s)
Liked 104 Times
Pro Compressionless Brake Housing | Jagwire
Likes For jimc101:
Liked 2,926 Times
Aican makes the stuff I use.
No, what your asking for is compressionless brake housing, Jagwire (and probably others, you will need to research that), the Jagwire model / name for it is KEB-SL
Quoted: 453 Post(s)
Liked 104 Times
Have seen no reference to that being compressionless, the OT bit seems to refer to the outer casing being pre-lubed with a silicone grease over the regular SP41
SP41 Shift Outer Casing | SHIMANO BIKE-US
Clark W. Griswold
Quoted: 4353 Post(s)
Liked 3,993 Times
Likes For veganbikes:
I've been using Aligator 31s shift cables for about 3yr and had good luck with Ultegra 6800 shifters. The rear works for about 1.5yrs (6K mi) and front still good after 2yrs.
I use OT-SP41 housings from bulk roll.
