Pills and Ills This is a discussion subforum for the health challenges faced by riders 50+. These discussions are in no way to be considered professional medical advice.
Good bye, bikes??
Old 01-21-23, 08:44 AM
car5car
car5car's Avatar
Bikes: Dead Mongoose XR100, Roadmaster
Quoted: 104 Post(s)
Liked 18 Times in 17 Posts
Good bye, bikes??
Moderators, please delete the thread.
car5car is offline
Old 01-21-23, 09:19 AM
Trakhak
Trakhak's Avatar
Quoted: 1551 Post(s)
Liked 1,577 Times in 920 Posts
Originally Posted by car5car View Post
Last couple weeks I had horrible back pain, (I am 63, getting better now). X-ray shows almost non-existent one of discs.
If I ever ride a bike, it will be full suspension.
Discs are going down w/o any signs until it is really bad. Nobody gets X-rays until it is too late.
Sorry for negative thread. Just trying to help(???)
I suggest getting X-ray of lower back to evaluate condition and then make decisions based on pictures.
X-ray pics also show condition of butt joints cartilage.
I used to work out almost every day: resistance and running.
As long as you're fit enough and not much over your healthy weight, cycling (in a leaned-over position that gently stretches your spine, relieving pressure on the discs) might be one of the few exercises available to you that would be safe and comfortable for your back.
I traumatized some discs in my lower back many years ago---and then did it again, very painfully, a couple of months ago. This time, I could barely move, let alone walk, for the first couple of weeks.
But once I was able to hobble around, I went back to riding my bike. That became a largely pain-free oasis during days that were otherwise not much fun. I'm almost completely recovered now, and I suspect that riding the bike helped my recovery.
Possibly relevant: all my bikes are set up with clamp-on aero bars, so I tend to ride in a flatter-backed position than most people. May have helped, doesn't seem to have hurt.
Trakhak is offline
Old 01-21-23, 09:49 AM
10 Wheels
Galveston County Texas
10 Wheels's Avatar
Bikes: 02 GTO, 2011 Magnum
Quoted: 1275 Post(s)
Liked 1,057 Times in 524 Posts
Try some Vitamin B-12 for Pain.
It works for me.
Fred "The Real Fred"
10 Wheels is offline
Likes For 10 Wheels:
Old 01-21-23, 10:09 AM
rydabent
rydabent's Avatar
Quoted: 3234 Post(s)
Liked 998 Times in 599 Posts
If you want to continue to cycle there is probably a solution to your back problem that many people have found that works. But Im not allowed to use the word ********* on this forum. Maybe some one else could.
rydabent is offline
Old 01-21-23, 11:23 AM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3575 Post(s)
Liked 1,569 Times in 1,146 Posts
Click on this: https://www.bikeforums.net/22768315-post95.html
It's never too late.
Start doing 3 X 30 at the gym (3 sets of 30 reps, all sets same weight in each exercise), in this order: barbell squats (full depth), seated rows, back extensions, leg sled, bench press, one-legged calf raises (unweighted), plank, stiff-legged deadlift, lat pull-downs. Do that for a full year, twice a week, gradually increasing the weights. If the 45# barbell is too heavy for 30 reps, start with unweighted squats, then do goblet squats with a dumbbell.
The next year, decrease reps to 20, adding weight. After that, you'll be good to do anything you want in the gym. It's a slow process, but that's the whole idea - and it works. Consistency is everything. Really, you don't want to be using a walker in a few years.
The standard road bike position, back at about 45°, is a good position for the spine. Though riding won't make your spine any stronger, it will strengthen your back muscles. Holding the spine in column is most of the battle and that requires strong back muscles.
Results matter
Carbonfiberboy is offline
Old 01-21-23, 11:39 AM
MoAlpha
Bikes: Shmikes
Quoted: 9004 Post(s)
Liked 4,919 Times in 2,624 Posts
Spine imaging does not correlate very well with symptomatology, except when there is specific nerve root or spinal cord involvement. I would venture a guess that virtually everyone reading this has some lumbar spine degeneration. To take an admittedly extreme example, my spine looks absolutely horrible and I ride 14 hrs a week (with 4” of drop) and no pain. By contrast, of many people with mild or minimal changes on imaging are crippled with very real back pain. I saw countless numbers of them as a neurology resident.
MoAlpha is offline
Old 01-21-23, 11:42 AM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 1429 Post(s)
Liked 2,113 Times in 1,148 Posts
A recumbent might be an ideal solution in this case.
(I hope you are making a joke. If you are genuinely being prevented from using the word "recumbent", that solution is vastly worse than any problem you created that it was designed to solve.)
Polaris OBark is offline
Old 01-21-23, 11:46 AM
zandoval
zandoval's Avatar
Quoted: 648 Post(s)
Liked 1,029 Times in 662 Posts
X-Ray Meh... You can have horrible back pain and nothing wrong on X-Ray!
Look man... This is the time ya get to really build your own bike. There are so many things you can do. Raise or lower your bars and seat. Change out your bars, go recumbent. One of the first things you can try is ridding a "Belgianese" style commuter bicycle. If I had seen the way my bicycle is currently set up for my ridding 50 years ago I would have laughed.
" Improvise, Adapt, Overcome " Have... Fun, Fun, FUN!
zandoval is offline
Old 01-21-23, 12:12 PM
gobicycling
Quoted: 119 Post(s)
Liked 332 Times in 99 Posts
One of my better docs told me "I don't treat xrays. I treat symptoms.".
And you need good strong back muscles to hold the spine together.
gobicycling is offline
Likes For gobicycling:
Old 01-21-23, 02:36 PM
davester
davester's Avatar
Quoted: 841 Post(s)
Liked 911 Times in 384 Posts
<br /><br /><br />That's also what I've heard from my orthopedic doc and chiropractor. I would say that your "make decisions based on X-rays" statement is the exact opposite of what I've heard should be the best approach. Most older people's back X-rays show all sorts of "problems" that don't actually cause any problematic symptoms and can therefore be ignored. Perhaps you would be better off seeing a physical therapist or chiropractor. Have you gone that route yet?
davester is offline
Likes For davester:
Old 01-21-23, 03:48 PM
cb400bill
Humble Administrator
cb400bill's Avatar
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR gravel Viscount Aerospace Pro Colnago Classic Rabobank
Quoted: 2867 Post(s)
Liked 5,141 Times in 3,054 Posts
Thread moved to 50+ P&I.
Originally Posted by Retro Grouch View Post
Fenders protect you from tire splatter. Mudguards protect you from tyre splatter.
cb400bill is offline
Likes For cb400bill:
Old 01-21-23, 07:52 PM
Carbonfiberboy
So true. If I'd done that, I'd have just crawled into a hole. Not happening, nope. IME when I feel pain somewhere, I work that area. So far that's always fixed it. Mammalian bodies are really resilient. We have seen a 3-legged beaver around here for years. We had to put up a chicken wire fence to keep him from destroying our fern garden.
That said, my torn meniscus needed surgery. I almost had to drag one leg behind me on our 10-day backpack that year - the backpack didn't help. After the backpack, I kinda had to get up on my doctor's desk to get an MRI and a diagnosis so I could get it fixed. He couldn't believe I could possibly have a torn meniscus. My doctor says the time to go in for back surgery is when you can't walk anymore - because you might not be able to walk after the back surgery either.
Results matter
Likes For Carbonfiberboy:
Old 01-23-23, 10:07 AM
car5car
car5car's Avatar
Quoted: 104 Post(s)
del
car5car is offline
Old 01-24-23, 10:02 AM
boozergut
boozergut's Avatar
Bikes: Kona Dew, Gary Fisher Paragon, Salsa Campeon
Quoted: 94 Post(s)
Liked 86 Times in 51 Posts
https://www.youtube.com/@GentleYogaandWellness
boozergut is offline
Old 01-24-23, 12:08 PM
TiHabanero
Quoted: 1508 Post(s)
Liked 1,027 Times in 530 Posts
Bulging disc and no disc left are two very different problems with two very different solutions. Bulging discs can be "reformed" into cooperation with certain stretches and exercises, and those items are individual specific, not one size fits all. No disc material left in the cavity is not fixed by the former solution that I am aware of. Consult the doc.
Disclaimer: I bulged 3 discs in the lower back in my late twenties. Have managed the pain and disability with consistent application of specific stretches and exercises. FWIW, yoga caused issues so I only use a two poses in my stretching routine. i do lift weights that do not stress the lower back, and i also do crunches, but limited to 20 per day and I have to be very aware of how I do them, form is of essence.
TiHabanero is offline
Old 01-25-23, 09:26 AM
MoAlpha
Bikes: Shmikes
"No disc left" generally solves itself over time by auto-fusion.
MoAlpha is offline
Old 01-25-23, 11:48 AM
Leisesturm
Quoted: 2100 Post(s)
Liked 493 Times in 359 Posts
Thanks for all responses. I am getting better, still waiting for physical therapy insurance approval. I used to sell 75lb. Jeep cylinder heads on ebay, I am done. Not sure about bikes, we'll see.
My 81 Schwinn Le tour is for sale. NE FL.
Doesn't appear that you have heard a single word of anything anyone has said to you. Why did you ask? Oh, sorry, you were just ranting. But help??? How are you helping? I don't want, or need to be infected with your defeatism. I am speculating, but I doubt I would lose a lot of money betting that you are several tens of pounds over the line and you have never done a single plank in your life. Why wouldn't your back hurt? When my wife hurt her back years ago, her PT put her on a Plank regimen. So I started doing them with her. Mostly to be supportive. But now neither of us need to be convinced. Planks and other Core (abdominal exercises) are known to be very effective in the treatment of back problems. I haven't seen any mention of core strengthening exercises (till now) in this thread. They are key, in my opinion, to getting to the bottom of any problem involving the back except possibly an accident or other trauma. Even then, I would at least try and address the Core, especially if like most of us, we have never paid any particular attention to maintaining core strength.
Leisesturm is offline
Old 01-25-23, 01:59 PM
car5car
car5car's Avatar
Quoted: 104 Post(s)
https://www.dickssportinggoods.com/p...fgprpwrtwrxmec
car5car is offline
