Go Back  Bike Forums >
Bike Forums
Bicycle Mechanics
2x Wheel Lacing
2x Wheel Lacing
Old 08-03-09, 11:03 AM
Joako
2x Wheel Lacing
Hello,
I am going to build a new wheel with a 2x. However, I have been looking in the forum and google and did not find how to lace a wheel with 2x. Could anyone please provide any details in lacing a 36h rim 2x? Thanks in advance.
Joako is offline
Old 08-03-09, 11:08 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1571 Post(s)
Liked 639 Times in 360 Posts
What's the point?
I'll confess to never having built a 36 hole rim 2x. If I was, however, I'd just start with my first spoke a little closer to the label on the hub.
Retro Grouch is offline
Old 08-03-09, 12:05 PM
BeretCyclist
Natural Energy.
BeretCyclist's Avatar
Bikes: 2004 Lemond Reno.
I'd google it...under images there has to be something...I know i've ran across wheel building sites as well.
BeretCyclist is offline
Old 08-03-09, 12:44 PM
BikeWise1
30 YR Wrench
BikeWise1's Avatar
Bikes: Waterford R-33, Madone 6.5, Trek 520
Liked 2 Times in 1 Post
No reason to build 36H 2 cross. But if you must, it is exactly the same as 3x, but with one fewer cross! That may sound obvious, but if your spoke length is correct, you won't be able to do anything other than 2 cross and have it work.
Couldn't find anything online? Really? Let me help!
BikeWise1 is offline
Old 08-03-09, 01:11 PM
rs1101
punk kid.
Bikes: 1970's Nishiki, Late 70's Centurion Super Elite
https://www.astounding.org.uk/ian/wheel/patterns.html
rs1101 is offline
Old 08-03-09, 01:20 PM
dabac
Quoted: 1074 Post(s)
Liked 292 Times in 219 Posts
Originally Posted by Joako View Post
..I am going to build a new wheel with a 2x. However, I have been looking in the forum and google and did not find how to lace a wheel with 2x. Could anyone please provide any details in lacing a 36h rim 2x?
Have a look at a 3X wheel. Notice how spokes appear in pairs that runs pretty much parallell( one heads-out, one heads-in) For a 3X lace there will be 6 holes in the flange between these "paired" spokes and for a 2X ther should be 4 holes in the flange between these "paired" spokes. Out by the rim the sequence is exactly the same for both 3X and 2X.
dabac is offline
Old 08-03-09, 01:57 PM
carpediemracing
Bikes: Tsunami road bikes, Dolan DF4 track
Quoted: 382 Post(s)
Liked 171 Times in 95 Posts
With cross patterns, you can lace a wheel up a quarter at a time. One side with spoke head on the outside of the flange, then the other side with the spokes dropping in the same way (head out).
Then you drop spokes so the spoke heads are inboard. When doing the crosses, you should do the following:
If n = number of crosses...
Over n-1, under 1.
For 3 cross, you go over 2, under 1.
For 2 cross, over 1, under 1.
For 4 cross, over 3, under 1.
As pointed out before, you need different length spokes for the different crosses (unless you also change hub or rim in a way that allows you to use the same length spoke).
To calculate spoke length, you can use this:
https://www.sheldonbrown.com/rinard/spocalc.htm
(You need Excel and also need to know what you have but don't need to measure much)
If you don't mind measuring (rims are a pain if you don't know what you have), go here:
https://www.bikeschool.com/spokes/
hope this helps,
cdr
carpediemracing is offline
Old 08-03-09, 02:49 PM
Joako
Thanks dabac and carpediemracing. I have built wheels before, but only 3x and radial, and could not find any specific details for 2x. The point for this build is that I am using 406 rims with a large diameter flange (igh), therefore a 3x is overdoing it.
Joako is offline
Old 08-03-09, 05:39 PM
AEO
AEO's Avatar
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times in 5 Posts
the times a spoke crosses, is exactly the amount a hole moves over.
Originally Posted by damon rinard page
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
AEO is offline
Likes For AEO:
Old 08-03-09, 07:24 PM
tatfiend
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
To the poster who asked why do 2x.
Rohloff specifies 2X for larger diameter wheels and 1X for smaller ones due to the design of their hub where there are bosses on one spoke flange for bolts that hold things together. So does NuVinci for their hub which is almost 6" in diameter at the spoke holes in the flanges.
Very little difference in strength between 2x, 3x, and 4x wheel construction per Jobst Brandt and 2x should save a few grams of weight.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
tatfiend is offline
Old 08-03-09, 08:14 PM
AEO
AEO's Avatar
the tangent at which the spokes go out from the flange to the rim become more extreme as the ERD decreases and flange diameter increases.
for a 32h 406mm rim 2x is normal for low flange hubs.
2x @406mm goes out at nearly the same angle as a 3x @622mm rim does with the same hub.
AEO is offline
Old 08-07-09, 09:48 PM
smiller
i tend to like funky wheels so i laced up my 36 hole chorus hub 2x on the non drive side and crow's foot on the drive side to an asymetrical rim. took 3 tries. had to stop and go have a couple of beers and try the next day, but it wound up great and is strong and true.
smiller is offline
Old 08-07-09, 09:59 PM
operator
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 23 Times in 17 Posts
Yeah because you're clearly racing if your hub requires 2x lacing, a. la large flange hubs like the rohloff or nuvinci right. Those hubs are SUPER light!
operator is offline
