Gloves. Which do you own or recommend for these problem areas
I ride to clear my mind
Thanks in advance
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,898 Times
I wear minimal golves (Giro ZeroCS), but I also make sure my weight is not carried too much on my hands AND I move them around a bit. I've found that, FOR ME, padded gloves exacerbate every problem they're supposed to help with.
Likes For genejockey:
Yes they do lol. I find this to be a fact
Quoted: 4559 Post(s)
Liked 2,802 Times
After trying padded gloves and having problems, I switched to thicker handlebar wrap and thinner gloves. I also like the Giro Zero CS and similar lightly padded gloves, including some Adidas brand cycling gloves I got earlier this year. There's just enough faux-leather on the palms to limit wear, but no gel or thick padding.
But for the bar wrap, I like Arundel Synth Gecko and similarly thick, rubbery wrap, or good quality "cork" wrap, often over an underlayer made from old inner tubes cut into strips like handlebar wrap. Inner tube strips alone are adequate bar wraps but the carbon black will eventually wear off onto your hands, clothing, brake hoods, etc. So it's usually better as a base wrap between the bar and an outer layer of good outer wrap. (That tip is often suggested by GCN videos as well.)
Also, cutting old inner tubes into long strips is handy for practice wrapping handlebars. No worries about making mistakes, so it's a cheap way to practice new or unconventional wrap techniques.
Thread Killer
Quoted: 3140 Post(s)
Liked 1,707 Times
At some point, padding will help. As an example, sleeping on a mattress vs. the floor, or sitting on a park bench vs. an arm chair; some amount of padding has to help. In the same way a thin pad doesn’t do much to make stadium bleachers into sofa-comfy seats, maybe the gloves folks have found lacking siimply didn’t go far enough. Alternatively, it may be practically impossible to add enough padding to a glove…I dunno.
Louis Garneau Air Gel Ultra have some serious padding, though:
https://garneau.com/us_en/air-gel-ul...gloves-1481183
Likes For chaadster:
Liked 11,898 Times
I use thin gloves and fairly thin bar tape (Fizik Microtex Classic) and have no pain or numbness issues even after 4+ hours. I don't know whether I'm just lucky, or my bikes are set up better than people who have chronic problems with hand pain. It does make me think, though, that a lot of what people try to fix with padding could possibly be addressed with bike fit. But like I said, I might just be lucky.
Quoted: 1083 Post(s)
Liked 686 Times
I took a chance on these cheap gloves, and they're fantastic. I bought my wife a pair and she loves them too. The padding is thick and they seem to be very well made, at least they're holding up so far.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Quoted: 6193 Post(s)
Liked 4,809 Times
I've been using the Specialized Body Geometry Sport Gel Gloves for several years and they have been fine. Though it's time to replace them. Might try the Specialized Body Geometry Dual-Gel next depending on what they look and feel like when I get to the shop and try them on.
https://www.specialized.com/us/en/sh...es/c/glovesmen
If you keep your hands only in one place, like on the hoods, then you should be changing them up more often to help with numbness. I find the drops much more comfortable for the hands and don't get any numbness in them when on the drops.
I'm using shallow drop bars so my body position doesn't change very much from hood to drops. So that allows me more time in the drops comfortably.
Quoted: 1743 Post(s)
Liked 1,281 Times
I like thinly padded gloves for the feel. I use Assos gloves mostly because I like the style and quality. but, there are a lot of other gloves that are just as good. It's an individual thing.
