Bob Jackson Help Needed- Price/Model?
Bikes: '72 Peugeot PX-10 '78 Motobecane Le Champion '83 Motobecane Grand Jubile '85 Trek 830 '88 Merckx Team ADR Corsa Extra
Quoted: 471 Post(s)
Liked 1,213 Times
Don't know about you folks, but I tend to change my bike interests every so often. Currently learning about higher up Brit and French bikes. Would like to pick up a good condition Bob Jackson, or the equivalent, that could be a fast all rounder. Maybe this one is it, but I'm not sure. it's my size and I like a shorter top tube for long rides.
Clearly it's a repaint. Sticker indicates the work was done at the BJ shop. Unfortunately, the new paint obscures the serial number. Any idea of the model and year of manufacture? Does the fork indicate it's from the '90's? What's a fair price if everything is copacetic? Appreciate any advice here.
Bob Jackson Frame
Bob Jackson Frame
Quoted: 3806 Post(s)
Liked 3,331 Times
appears a good deal earlier than " '90's "
likely somewhere between late 1960's and mid-1970's
note -
absence of bottle mount(s)
non-recessed brake mount
long dropouts
presence of housing stop for covered cable operation of front mech
presence of centrepull bridge; very latest for this feature on a machine with caliper brakes would be early 1970's
estimate that '74-'75 is the absolute latest it could be
interesting to see that chainstays are rapier pattern
lug pattern is Prugnat S
crown appears Davis
shell appears BOCAMA professional
many of these were contract produced by small workshop operations
the experts may be able to tell how to determine the in-house products from the contracted one...
note -
long dropouts
crown appears Davis
Likes For juvela:
Friendship is Magic
Bikes: old ones
Quoted: 26400 Post(s)
Liked 10,373 Times
...with that rear cable stop for center pull brakes, and the above the BB shell cable routing for the derailleurs, I'd put that one at no later than sometime in the 70's. Also, the seat tube angle looks pretty slack to me, so maybe not the best choice if you prefer a shorter top tube. I have a couple of bikes by Bob Jackson, one of which is probably contemporary with that one. It's a pretty solid bike.
Likes For 3alarmer:
Friendship is Magic
Bikes: old ones
Liked 10,373 Times
...$550 is a reasonable deal. If it was painted and restored by the BJ shop, it probably cost more than that to have that stuff done there.
Likes For 3alarmer:
Quoted: 471 Post(s)
Liked 1,213 Times
Quoted: 471 Post(s)
Liked 1,213 Times
Anybody have any idea what model this might be?
Quoted: 471 Post(s)
Liked 1,213 Times
note -
long dropouts
crown appears Davis
note -
long dropouts
crown appears Davis
Crawlin' up, flyin' down
Quoted: 1025 Post(s)
Liked 2,524 Times
Be sure to ask about/check out the bottom bracket threads. In the early 70s, Jackson had problems with mangling an unfortunate number of their BB shell threads such that bottom brackets would not stay put. I had one that resulted in my getting an exploded view of my bottom bracket assembly in the middle of a ride (and in the middle of the road)
I was a teenager at the time and had no clue how to deal with it. A good, reputable shop solved the problem with a Phil Wood BB and red Loctite. That kept the problem from ever rearing its ugly head again, so a work-around is possible and bad threads don't have to be a deal breaker. Using red Loctite, however, is a pretty permanent solution - don't do it unless the BB can stay put without servicing for the rest of the bike's life.
Odds are it isn't an issue with this particular frame; as with Mexico-built Benottos that had overcooked tube joints, its likely that all the problem child Jacksons were discarded long ago. But it would not hurt to do some due diligence so you know what to expect.
Likes For bikingshearer:
Quoted: 471 Post(s)
Liked 1,213 Times
Quoted: 3464 Post(s)
Liked 2,828 Times
this subject frame notes renovated- so the seat stay brake bridge could be an addition later.
otherwise the appearance looks like a Messina model to me.
Likes For repechage:
