Is fixed gear more efficient for pedaling?
Old 11-26-21, 01:41 AM
cjenrick
Quoted: 173 Post(s)
Liked 127 Times in 94 Posts
of course fixed gear is more efficient, that's the whole point.
ever seen a track bike with a derailleur or a freewheel?
fixed gear has a perfect chain line which chews less power.
plus, there are no tension pulleys on fixed gear so you get better chain wrap and less mechanical waste from pulley operation.
switch to the bigger track chain links and drivetrain and you really feel the difference.
only problem is panic back pedaling can seriously screw your back up.
cjenrick is offline
Likes For cjenrick:
Old 11-26-21, 02:14 AM
Maelochs
Maelochs's Avatar
Quoted: 6587 Post(s)
Liked 1,745 Times in 948 Posts
Or, maybe a track bike has no gears because they are only ridden at speeds which can be maintained without a need for multiple gears?
Ever seen a Grand Tour rider win on a fixie? Hmmmm .... maybe there is more to many gear ratios versus one gear ratio than the inefficiency of pulleys .......
Maelochs is offline
Likes For Maelochs:
Old 11-26-21, 03:46 AM
Trakhak
Quoted: 1053 Post(s)
Liked 880 Times in 516 Posts
Single-speed freewheel bikes have all of the advantages of fixed-gear bikes with none of the disadvantages.
Trakhak is offline
Old 11-26-21, 04:49 AM
Branko D
Quoted: 238 Post(s)
Liked 298 Times in 175 Posts
If you are on a track or a pancake flat road then fixed or singlespeed is slightly more efficient.
However if I set out to ride on flat loops around me deliberately, the flattest I can do is 500m of climbing per 100km. Realistic routes which I don't consider hilly but mostly flat average around 1000m of climbing per 100km. Assuming I'm riding at tempo and stay in the big (well, 50t) ring, I'll use almost the entire cassette.
Being able to take on properly hilly routes or mountain climbs all on the same bike with the same gearing is a big boon.
​​​​Even the TT bike benefits from gearing because pancake flat just doesn't really happen even on nominally flat routes, and if I have wind one way and tailwind the other I'll need different gears.
Branko D is offline
Old 11-26-21, 08:20 AM
WhyFi
WhyFi's Avatar
Quoted: 18571 Post(s)
Liked 7,163 Times in 3,625 Posts
Originally Posted by cubewheels View Post
I just tried it on a stationary bike with fixed gear, no resistance and even if I try to completely relax my legs like I'm not trying to pedal at all, it just kept on spinning faster and faster until I'm hitting around 140 rpm more or less and just kept on spinning effortlessly.
While it felt no effort at all, I did feel my body temperature and heart rate rising.
It's strange and also liberating feeling. I feel like I'm chasing the pedals instead of driving them like they're moving on their own. Can't do it on bike with free-wheeling cogs, made it very tempting to go fixed gear, if only conditions were safer.
Congratulations on finding the source of free energy.
WhyFi is offline
Likes For WhyFi:
Old 11-26-21, 08:30 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2816 Post(s)
Liked 1,659 Times in 1,015 Posts
But this ignores the human part of the system: legs muscles are most efficient over a fairly narrow cadence range; that's why variable gear systems were developed in the first place, allowing cadence to remain in or close to that most efficient range.
N.B. I've been riding fixed gear for years, and enjoy it. But I haven't noticed that it makes me dramatically more efficient than riders on multi-gear bikes.
JohnDThompson is offline
Likes For JohnDThompson:
Old 11-26-21, 08:34 AM
JohnDThompson
Old fart
Not all of them: you can't slow the bike with your legs using a single freewheel. This is particularly evident in groups, where legs can slow you more immediately than a brake system to avoid entanglements.
Old 11-26-21, 10:02 AM
asgelle
Quoted: 887 Post(s)
Liked 322 Times in 199 Posts
Since a pursuit, match sprint, or kilo sees speeds from 0 to 30+ mph, and Tour speeds might reach 60, it seems you're saying all those gears GT riders carryi are only for speeds between 30 and 60 mph. Hmmmm.
asgelle is offline
Old 11-26-21, 11:16 AM
Maelochs
Maelochs's Avatar
Yeah ... ummm .... you are smarter than that, and so am I. Track riders spend the majority of every race---even Madisons---riding somewhere between 75% and flat-out. We all know that. We all know that even after all the track-standing, sprints are somewhere between 75% and flat-out.
One ratio works for track bikes because they operate within a narrow rpm range (mechanical efficiency to suit biological efficiency) on a completely flat track.
You might notice, most bike races have these things called hills.
Anyway ... enough all of this. You can believe the Earth is lfat if you like.
Have a nice whatever.
Maelochs is offline
Old 11-26-21, 11:30 AM
HTupolev
Quoted: 1824 Post(s)
Liked 1,030 Times in 504 Posts
Track racers would absolutely get an advantage from variable gearing. The ubiquitous use of brakeless fixies is simply down to that being what track racing is, and what's required by the rules.
HTupolev is online now
Likes For HTupolev:
Old 11-26-21, 01:24 PM
Calsun
Quoted: 127 Post(s)
Liked 69 Times in 52 Posts
Your post implies that you are not in the correct gear when using your other bike, either too low or too high. A cadence meter is a good way to know what you are actually doing in terms of cadence and when. On a long steep grade I will be in a lower gear than on a short grade where I can power over the crest and maintain my speed and my momentum.
Calsun is offline
Old 11-26-21, 02:32 PM
cjenrick
Quoted: 173 Post(s)
it is easier to do a track stand with fixed gear
cjenrick is offline
Old 11-26-21, 05:21 PM
wolfchild
wolfchild's Avatar
Quoted: 2460 Post(s)
Liked 1,352 Times in 661 Posts
Too many people associate fixed gear with track racing...Fixed gear doesn`t mean it has to be a track bike or some tricked out hipster bike...I have a mountain bike and a gravel bike with rear facing drop-outs which I set up as fixed gear which I use for recreational riding.. I really like fixed gear for winter riding because it`s almost maintenance free, I can stop even if my brakes are frozen and I feel like fixed gear gives me better control when it`s very slippery out there... I have multiple wheelsets some of them have a track cog and others have a singlespeed freewheel...Efficiency, proper cadence, proper gear ratio isn`t a priority for me..... I have no logical or scientific explanation why I choose a wrong tool for the job..
wolfchild is offline
Likes For wolfchild:
Old 11-26-21, 07:56 PM
Quoted: 14529 Post(s)
Liked 7,868 Times in 3,925 Posts
My ex rides a fixie around town. No need for multiple gears, and it gets locked outside in bad weather on occasion. Really saved on maintenance. Makes total sense.
She even did a 150 mile+ overnight credit card tour on one. Of course, I had to carry the gear.
Likes For indyfabz:
Old 11-26-21, 08:18 PM
Rolla
Gyro Captain
Rolla's Avatar
Bikes: 4 Singlespeeds, 2 Gearies
Quoted: 616 Post(s)
Liked 1,563 Times in 696 Posts
I ride bikes for the express purpose of ignoring inconsequential minutiae like pedaling efficiency.
Rolla is offline
Likes For Rolla:
Old 11-26-21, 09:15 PM
cubewheels
Bikes: A really old BMX bike, Jackal Mio Gravel Bike
Quoted: 1139 Post(s)
Liked 483 Times in 394 Posts
I should go to Oslo and grab a Nobel trophy.
I'd ride a fixie (gravel fixie) if only the roads here are smooth or could find 150mm crank arms.
cubewheels is offline
Old 11-26-21, 10:12 PM
cjenrick
Quoted: 173 Post(s)
it is easier t fix a flat on a fixed gear bike.
which is frequently necessary as fixed gear bikes should only be allowed to sport tubular tyres.
how are those continental sprint tubulars as far as flats, good as he gator skins?
fixed gear bikes have a certain macho appeal, "look at me everybody i have no brakes, take a picture honey hey where did that car come from i'm dead."
cjenrick is offline
Old 11-27-21, 02:28 AM
Lazyass
Quoted: 2421 Post(s)
Liked 604 Times in 376 Posts
I live in a hilly area in North Carolina. Not the mountains but hills where most people on geared bikes get out of the saddle to climb. My single speed road bike is my main bike and my average speed is the same as my geared bikes, never once have I ever had to stop and take a break or walk up a hill. It's a non issue. The only real difference is I'm out of the saddle more. Of course fitness and strength is what matters and that varies by individual.
Lazyass is offline
Old 11-27-21, 02:33 AM
Lazyass
Tubulars for the win. But I get many, many more flats on clinchers.
Lazyass is offline
Old 11-27-21, 06:45 AM
Branko D
Quoted: 238 Post(s)
Data?
​​​​​​Because the only way I can see that happening is if you are riding with a group below your physical abilities and matching their speed.
Or relatively flat ground. On a gear adequate for riding on flat ground quickly (let's say 50 x 15), I'd spin out downhill and be overgeared up any serious climb.
Branko D is offline
Likes For Branko D:
Old 11-27-21, 09:12 AM
Lazyass
Data?
I'm talking about solo rides. I'm not in the mountains descending or climbing for 20 minutes. The short downhills I have are so short they have little effect on average speed but I can still sprint to 30 miles per hour if I want. Climbs obviously take more effort but I'm not climbing slower. My cruising speed on flat ground is usually a little faster because I'm pushing a 48x18 the entire time, you can't get lazy and shift into a lower gear. Overall, average speed is about the same. After getting a single speed and going on a few rides I started asking myself why I even had bikes with multiple gears.
Last edited by Lazyass; 11-27-21 at 09:15 AM. Reason: Poor spelling because I'm old
Lazyass is offline
Old 11-27-21, 11:08 AM
Rolla
Gyro Captain
Rolla's Avatar
Quoted: 616 Post(s)
BF needs a facepalm emoji.
Rolla is offline
Likes For Rolla:
Old 11-27-21, 11:36 AM
ofajen
Cheerfully low end
ofajen's Avatar
Quoted: 383 Post(s)
Liked 586 Times in 391 Posts
The experimental data Iíve seen (from the work of Formenti et al at Kings College) show that overall efficiency is a decreasing function of pedal cadence for a given external load (bike speed).
This is due to the internal work being a strongly increasing function of cadence. For example, it costs me (at 80 kg) about 10 watts to pedal at 50 rpm, 25 watts at 70 rpm, 50 watts at 90 rpm and 80 watts at 110 rpm.
I wasnít there, but I assume variable gears were implemented to allow riders to climb hills and mountains sustainably at reasonable pedal force and power output.
If you can tolerate it, climbing a mountain at 50 rpm is more efficient than a higher cadence, but the cost could be excessive strain on joints and muscles versus working your heart 25 watts harder at a reasonable pedal force and total workload.
As I said before, efficiency isnít everything! 😊
Otto
ofajen is offline
Old 11-27-21, 12:33 PM
70sSanO
70sSanO's Avatar
Quoted: 1364 Post(s)
Liked 1,259 Times in 793 Posts
After all is said and done, I think it depends on what you are "peddling".
John
70sSanO is offline
Old 11-27-21, 12:59 PM
63rickert
Quoted: 968 Post(s)
Liked 273 Times in 205 Posts
So many riders for so many years have had the same perception as the OP that something has to be happening. Is it a perceived effect or is it real efficiency? Who cares? Enjoy the ride.
63rickert is offline
