Campagnolo Centaur Ultra Torque crankset
Quoted: 5 Post(s)
Hello Everyone,
I have a question regarding compatibility of the crankset and the bottom bracket.
Is the Campagnolo centaur 170mm 53/39 Ultra Torque compatible with both Ultra torque Bottom brackets ? (Italian and English)
My frame has threaded shells bottom bracket 700mm width and 1.37″ x 24 threads. I know it is not common.
Thanks a lot for you help, let me know if I have to give more details.
Thanks
Thanks
Quoted: 1819 Post(s)
Liked 1,693 Times
Hello Everyone,
Thanks
Thanks
Quoted: 5 Post(s)
I have a Bianchi with 1986 1987 campione del mondo sticker, I beleive it is made in Japan (Tange Infinity tubing)
I have bought a Campagnolo Centaur Ultra Torque crankset that came with Italian Bottom bracket, I am wondering if I can just change the BB cups to ENG threads and keep the same Crankset.
Thank you !
Thank you !
Quoted: 5 Post(s)
Thank you !
Thank you !
Quoted: 645 Post(s)
Liked 797 Times
Thank you !
Thank you !
Liked 1,693 Times
What is not clear is the bottom bracket shell width and threading. The OP says 700mm shell width(probably 70mm) with BSC threading. This is quite uncommon and if using English threaded cups the crank spindle might not be long enough. It might be necessary to face the BB shell down to 68 mm. If the BB threading is Italian, the BB cups that they already have would be fine because they are made for a 70mm BB shell
Quoted: 5 Post(s)
Quoted: 5 Post(s)
Merci !
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
The width of the spindle is set. Half of it is integral to the left arm, and half of it to the right, with a special joint where they connect in the center. The cups are the important thing to match to your frame. If you’re not sure about the thread pitch of your BB shell, get confirmation. Usually, English road bike shells are 68mm wide (Italian is 70 I think), and although the diameter is the same between English and Italian, the thread pitch is different.
If you’re sure about which standard your frame has, order the correct cups, and you’ll be fine. The crank doesn’t care—Ultra Torque is Ultra Torque.
Quoted: 1104 Post(s)
Liked 1,825 Times
The answer to the orginal question is YES, Ultra Torque cranks are compatable with English or Italian threaded UT BB cups.
Quoted: 5 Post(s)
Quoted: 1561 Post(s)
Liked 1,734 Times
It's almost impossible that that bike had a BB that was neither Italian nor English.
Quoted: 5 Post(s)
Also the right side of the bottom bracket shell is left threaded, does is not indicate an English shell even if the width is 70mm ?
Thank you !
Quoted: 5 Post(s)
Are you sure you are measuring the right thing? How are you measuring that 34mm now? You are supposed to be measuring the diameter of the threads of the cup that comes out of that bottom bracket, NOT the inner diameter of the BB hole.
Thank you !
Quoted: 5 Post(s)
I'm trying to figure out if there may be another reason for the 70mm BSA, i.e. to space the drive side of the BB further outboard of centre?
Either way your UT cranks should work with the correct pretension spring.
not common Centaur UT cranks, most are power torque.
Quoted: 5 Post(s)
I have finally find the extra 2mm after cleaning the frame this morning, English it is
Thank you all for your precious help !
Klaatu..Verata..Necktie?
Quoted: 10424 Post(s)
Liked 11,898 Times
Mine, too, purchased last year. That was for a 2006 Bianchi 928, which has an English threaded BB shell.
still can’t figure out what’s happening there, sure it’s BSA thread? Not French?
Quoted: 5 Post(s)
Hello, sorry for the late reply, so long story short yes it is BSA thread, and I had to face it down (in a bike workshop) to 2 mm, to have 68mm width (it was 70mm), so all good now, I was able to mount the BSA BB cups
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Likes For Trsnrtr:
Quoted: 5 Post(s)
Quoted: 1857 Post(s)
Liked 664 Times
Hello Everyone,
Thanks
Thanks
Does this chainset take square taper spindles, or does it have the large diameter Campy integrated spindle and threaded cups which thread into the ends of teh BB shell? If it's the former, you can use an English threaded cartridge BB (probably Centaur or other Campy 111 millimeter). You only have 2 mm extra shell width, and the non-drive side might be able to take care of this. If not, have the BB shell faced down to 68 mm at a shop which has "adjusted" frames in this manner a lot of times.
If you have the separated cups for the big, fat, hollow Campy integrated spindle and they are British threaded, first gently verify the threading by screwinng them in gently without cross threading. Then take them out and go through the standard Campy installation procedure. There should be zero end-play when the cups are turned down home, and very free chainset rotation with no scraping.
I think at the start of the Cam[y procedure they ask you to verify the correct bottom bracket dimensions. If you took the frame and those numbers to the best LBS in the area, they can tell you right anything is not right. Have that shop correct it if it seems like they can do it. But it does take some special tools, pretty $$. It it is too wide, it takes a special hand mill to cut the faces squarely.
