creakiness
Old 10-14-21, 03:29 PM
cyrano138
cyrano138's Avatar
Bikes: 1986 Schwinn LeTour, 1977 Raleigh Super Course (converted to fixed gear), 199X GT outpost
Quoted: 126 Post(s)
Liked 53 Times in 32 Posts
creakiness
I have a significant creaking sound coming from the drivetrain in the front. Normally I would assume it's the bottom bracket and make sure it was adjusted properly, but it's a sealed cartridge bottom bracket. Are those adjustable? I am new to them so pardon me if it's a dumb question. I ruled out the chainring bolts but not the pedals. It seems like it would be weird for the pedals to both be acting up at the same time since it started suddenly after I converted to a fixed gear.
cyrano138 is offline
Old 10-14-21, 04:15 PM
Rolla
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times in 1,439 Posts
  • First, check the crankarm bolts and tighten them if they're loose.
  • Still creaking? Check the pedals, just to rule them out. Remove them, clean and grease the threads, and re-install. Non-drive side is reverse-threaded.
  • Still creaking? Remove the cartridge bottom bracket, clean and grease all threads, and re-install. Drive side is reverse-threaded.
  • Still creaking? Maybe replace the cartridge if it's more than a couple years old.
Rolla is offline
Old 10-14-21, 04:37 PM
cyrano138
cyrano138's Avatar
Quoted: 126 Post(s)
How tight to I make each side of the bb?
I know in the old cup and cone bb's the drive side was basically as tight as you can, and the nds was just tight enough to eliminate play, and then the lock ring gets tightened pretty good.
Old 10-14-21, 04:59 PM
Iride01
Iride01's Avatar
Quoted: 6177 Post(s)
Liked 4,794 Times in 3,306 Posts
Are you sure it's not just your wheel spokes moaning and groaning as you put power into the cranks? Or maybe your sweaty bike shorts rubbing on your saddle.
Iride01 is offline
Old 10-14-21, 05:28 PM
Rolla
Guest
Pretty darn tight. Don't put a cheater bar on it or anything, but 50 - 70 Nm would be my guess.
Rolla is offline
Old 10-14-21, 06:07 PM
cyrano138
cyrano138's Avatar
Quoted: 126 Post(s)
Yes, and yes. The spokes are numerous and heavy, not unlike the crowd at wal mart on black Friday, and my shorts expressly promised to wick moisture away to, I can only assume, some other place, probably in a bunker under a mountain somewhere.
Likes For cyrano138:
Old 10-14-21, 06:08 PM
cyrano138
cyrano138's Avatar
Quoted: 126 Post(s)
Thank you, going to try this tomorrow.
Old 10-14-21, 08:48 PM
cxwrench
cxwrench's Avatar
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times in 1,489 Posts
RTFM. Seriously, it's probably etched right on the cup. If not it's in the instructions thoughtfully included in the box.
cxwrench is offline
Old 10-14-21, 08:55 PM
cyrano138
cyrano138's Avatar
Quoted: 126 Post(s)
I didn't install it.
Old 10-15-21, 01:46 AM
Lazyass
Quoted: 2432 Post(s)
Liked 638 Times in 395 Posts
Tighten the rear wheel skewer. That sounds like it's coming from the BB area.
Lazyass is offline
Old 10-15-21, 08:17 AM
blinky
senior member
Bikes: 2003 Litespeed Tuscany with Ultegra R-8000 components
Quoted: 145 Post(s)
Liked 40 Times in 35 Posts
Had a similar issue a few years ago and exhausted many possible causes before taking my bike to my mechanic whose father was a chemist - my mechanic also had an interest in chemistry and had success applying Loctite 660 to each sealed bearing surface , reinstalling the two press fit cups , and letting it set overnight .
He did this with my bike and the creak was gone the next day - PM me if you have questions .
Amazon.com: Loctite 66040 Loctite Retaining Compound, Surface Repair, 50 mL, Silver : Industrial & Scientific
blinky is offline
Old 10-15-21, 11:54 AM
blinky
senior member
Quoted: 145 Post(s)
OP , is it a fixie or a single speed ?
blinky is offline
Old 10-15-21, 12:18 PM
guy153
Quoted: 321 Post(s)
Liked 263 Times in 212 Posts
This can be the seat. Worth double checking if it still does it if you ride standing up.
guy153 is offline
Old 10-15-21, 06:11 PM
cyrano138
cyrano138's Avatar
Quoted: 126 Post(s)
Thanks guys. It's not a press fit -- I don't know if that matters wrt the locktite solution, but I'll keep that in my tool kit for sure.
The wheels are bolt on, not quick release.
Just to update -- I'll need around with it tomorrow and let you guys know. So far it's not the chainring bolts or the pedal (at least where they bolt on to the cranks. I tightened those and it still creaks. I'm hoping I was just to gentle tightening down the crank bolts, but if that doesn't fix it I'll pull the cranks and tighten the bottom bracket.
Old 10-15-21, 06:18 PM
Kimmo
bike whisperer
Kimmo's Avatar
Quoted: 1523 Post(s)
Liked 716 Times in 508 Posts
How tight is the chain? It's got some slack, yeah?
Kimmo is offline
Old 10-16-21, 12:05 AM
cyrano138
cyrano138's Avatar
Quoted: 126 Post(s)
Yeah it doesn't sag but you couldn't bounce a quarter off it, for sure.
Old 10-16-21, 02:17 AM
Kimmo
bike whisperer
Kimmo's Avatar
If it's not sagging at all, that's typically not enough slack, because every single speed drivetrain I've ever seen isn't concentric enough at hub and crank for there not to be tight spots through rotation - pretty sure if you feel the chain as you turn the crank there will be tight spots, but watch your fingers on that deadly fixie drivetrain...
Kimmo is offline
Old 10-16-21, 01:20 PM
cyrano138
cyrano138's Avatar
Quoted: 126 Post(s)
It was one of two things. Either the cranks were creaking on the bottom bracket spindle, since I pulled the cranks and heard creaking as they were coming off and they had no lube on them, or it may have been the bottom bracket although that's a little doubtful. The non-drive side of the bottom bracket was pretty loose so I snugged it down a bit. But i did it at the same time that I pulled the cranks and lubed them (just a dab if grease) and retightened the crank bolts, so I'm not sure which one it was but my money is on the crank arms against the spindles.
Thanks for everyone who helped out and threw in suggestions!
Old 10-16-21, 01:59 PM
WizardOfBoz
Generally bewildered
WizardOfBoz's Avatar
Quoted: 1152 Post(s)
Liked 341 Times in 251 Posts
Oh... You're talking about the bike.
WizardOfBoz is offline
Likes For WizardOfBoz:
Old 10-16-21, 02:01 PM
Rolla
Guest
Hard to say, since you addressed three things at once (I would have done the same), but since the NDS BB cup was "pretty loose," I would guess that was the culprit. My crankarms always go on bone dry, and I've never had one make a peep unless the bolt was loose. Glad you got it sorted, regardless.
Rolla is offline
Old 10-16-21, 04:48 PM
cyrano138
cyrano138's Avatar
Quoted: 126 Post(s)
Thanks! The reason I landed on the crank arms is the noise they made when I pulled them. I've never had any make any noise at all before, and it sounded suspiciously like the creak. I did not crank down very hard on the bottom bracket on the non drive side when I tightened it, so if it comes back that may be the culprit. I have a torque wrench on the way, and I figured I would just err on the side of caution until the torque wrench arrives.
I did try tightening the crank bolts independently before hand but that didn't do it.
In any case it's quiet now so all is right with the world.
