New Tire Won't Fit on Old Wheel (or is it me?)
I have a 1990's vintage Trek 820 (my dad's) that I want to replace the dried-out knobby tires with something more street friendly
The old wheel is 26 x 1.5 / 559 according to the sticker on the wheel. BUT, there is second sticker that also notes 519
The old tire is a 26 x 1.95
The new tires I have are Continental Doublefighter III 26 x 1.9 50-559. I have installed plenty of bike tires. The bead(s) don't set at all; it seems the tire is too wide.
Question 1. Just checked the specs on the bike; they note Weinmann 519 - so guess it won't work?
Question 2. I have already replaced many components on this bike in a rebuild. The wheels are in pretty bad shape anyway. What specs do I need to be mindful of if I want to use the new tires and buy new wheels? Best source?
Really Old Senior Member
No reason the tires shouldn't fit.
519 is a model# of the rim, not a diameter.
If the old tire 's "metric" designation is 559-xx, and the new tire is 559-xx, the bead seat dia. is the same.
Some tires are just a real bear to install on some rims.
Quoted: 451 Post(s)
Liked 364 Times
I am a not half-bad little tire installer. So I thought. Don't have any special tools, just levers and usually, use my hands. Got tired of getting so many flats on my Vittorias, so just gave up and bought a set of Hardshells. Not interested in tubeless right now, but also bought some new tubeless-ready wheels (aluminum., as I have rim brakes and live in the Land Of The Never Ending Rain. Anyhoo, tires and tubes off. Warmed up the new tires, started to mount. Like I've done a hundred times before with many other tires. Couldn't do it. Could not really actually even get that close, I am sad to report. Used every trick I know of. Not really sure what the problem was. Maybe me. The truth hurts.
Walked up to the LBS. Guy said Hardshells can be a bit tough. He had them on in 5 minutes using only his hands. I watched him. Piecea pie. I slunked home. Apparently, some people are better at mounting some tires than others.
Quoted: 4200 Post(s)
Liked 3,854 Times
There's a lot to be said for practice. Mounting tough to fit tires can be a personal point of pride for some shop wrenches. If we have to use a tool the tire won As others said 519 is a label of rim model, not a size reference.
As to the wheel replacement, your wheels are about the most common size available, you should have many options. You already know the tire/rim interface dimension. The rear hub is most likely a 135mm lock nut to lock nut width (or the frame has a 135mm inside of drop outs width). I suspect the hub/cog set are of the freehub/cassette design as opposed to the freewheel and threaded hub shell one. But do figure out which your bike has and duplicate it so the gears/cogs are reuseable. The rim will require a brake track, one that's machined will have a smoother feel to the brakes. I don't suggest a wider rim as street tires rarely get as wide as off road rubber tends to be. A hollow, double wall or box section rim will be somewhat stiffer for the same weight (note that I didn't say stronger as that's a different thing). Spoke count these days seems to be less number or weird patterns the better. But the longest lasting wheels statistically have had more spokes. I like Shimano hubs in the moderate replacement cost range but there are a lot of cheaper options too. Most will just duplicate the rear wheel specs for the front with the obvious difference in the hub/axle fit. Likely the common 100mm wide axle and using a 5mm QR skewer. Andy
AndrewRStewart
AndrewRStewart
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
I am a not half-bad little tire installer. So I thought. ...
Anyway, don't feel like you're alone.
Oh, and btw, because I knew it was possible, the next time I made sure that the bead went into the center well of the rim, and it worked like it was supposed to. I was able to get the tire on with only my hands.
Likes For WizardOfBoz:
Thanks - Got it to Work!
All, thanks so much! Learned alot from all the information passed via the forum. The trick on this one was that I really had to rely on the tire tools to get it the job done.
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,593 Times
The Kool Stop tired bead jack has saved me much aggravation. Around $13.
Likes For cb400bill:
