Go Back  Bike Forums > Bike Forums > Framebuilders
Torch Leak
Framebuilders Thinking about a custom frame? Lugged vs Fillet Brazed. Different Frame materials? Newvex or Pacenti Lugs? why get a custom Road, Mountain, or Track Frame? Got a question about framebuilding? Lets discuss framebuilding at it's finest.
Torch Leak
Old 07-20-21, 08:51 AM
Tandem Tom
Quoted: 455 Post(s)
Liked 112 Times in 85 Posts
Torch Leak
I have a Unweld 71 torch with a UN-J mixer that I use with a Paige adapter and tips. I am running oxy-propane.
A leak has developed at the adapter neck connection. I cannot seem to correct it. I don't want to get too aggressive with a wrench.
Thoughts?
Thanks!
Tandem Tom is offline
Old 07-21-21, 12:01 AM
unterhausen
Randomhead
Liked 3,696 Times in 2,517 Posts
so it leaks at the adapter?
unterhausen is offline
Old 07-21-21, 06:30 AM
Tandem Tom
Quoted: 455 Post(s)
Yes,it was leaking at the adapter. Yesterday I made a small brass washer out of some shim stock and it seems to have worked.
Old 07-21-21, 08:33 AM
unterhausen
Randomhead
Is your UN-J an official one or a knock-off?
Where did you get it?
Old 07-21-21, 06:03 PM
Tandem Tom
Quoted: 455 Post(s)
It is a real one. I went back and tried to find my receipt without luck. But I bought it from one of the vendors that Doug Vstříc recommended in his course.
Old 07-21-21, 06:57 PM
unterhausen
Randomhead
Okay, thanks, that's interesting.
Old 07-22-21, 06:28 AM
Andrew R Stewart
Andrew R Stewart's Avatar
Quoted: 4201 Post(s)
Liked 3,857 Times in 2,305 Posts
Unrelated to the OP's question but of passing interest- I bought a used torch handle a few years ago off EBay. I forget the brand but was one of the small "aircraft" types we seek. I hooked it up and tried to pass gas, through it. But a funny thing was happening in that when I would open one gas line's valve the regulator for the other gas was showing a pressure change. After a few experiments I decided there was an internal leak between the two passages, between the valves and the outlet. I returned the handle for a refund. Andy
AndrewRStewart
Andrew R Stewart is offline
