wearing a hydration pack while bikepacking
...whatever works for the individual...
You say you are using a 100oz camelback. That's over 6lbs of static weight. I would rather not have that on my back, hour after hour day after day.[/QUOTE]
I absolutely agree with the first statement.
Regarding the second statement...Most people will drink more often when wearing a hydration pack so 6 lbs. of static weight hour after hour, day by day will only occur if you don't drink at all. Actually, as you tire, you'll drink more and the more you drink, the lighter the pack gets...seems to make sense.
Personally I think that is fine under some circumstances where the advantages are sufficient to justify the weight on the back, but figured the correction was worth making lest someone make the choice based on incorrect info.
For me it can be worth it for long days in the desert with 100 F heat if the camelback is filled with ice and I get the cooling effect of melting ice all day. For most general use I don't care for them.
mosquito rancher
A gallon of water weighs 8.34 pounds so 100 ounces of water weighs a hair over 13 pounds.
Adam Rice
Adam Rice
My math was incorrect as I accidentally based it on 64 ounces being a gallon. Dumb mistake, too early in the morning. I stand corrected.
Quoted: 2236 Post(s)
Liked 1,314 Times
Could have gone either way. I just thought of ounces as weight and extrapolated 16/pound. Didn't even consider fluid volume at all
Quoted: 623 Post(s)
Liked 396 Times
cyccommute
I have one of the 100oz military Camelbaks It has the insulation even around the tube. I have had it for over a decade. I don't have any problems with the weight either.
All you imperialists, just use litres and grams, it would all be so much simpler.
seriously though, I've totally lost my ounces stuff and always find it confusing when folks describe x camping gear in ounces...
And yet, still haven't picked up on bar tire pressure and only understand psi.....
Liked 1,314 Times
I'm a 57 yo Canuck and can think in metric for everything except temperature. For the life of me I can't stop my brain from picturing the weather in Fahrenheit.
Mad bike riding scientist
Quoted: 6214 Post(s)
Liked 4,212 Times
“Bar” is atmospheric pressure or 14 psi/atmosphere. 100 psi~7 atmosphere or about 7 bar. Of course, that assumes sea level. Up here at around 1600 meters, our “atmospheric pressure” is 80% of that of sea level.
Pascals are harder to use (and wrap your head around) because there are just so many of them. One standard atmosphere (14 psi) is 96,500 pascals. 100 psi is 675,000 pascal. Even if you convert it to kilo pascals (kpa), that 675 kpa which is still hard to think about. Even professionally, few people use pascals.
I had to interpret from metric to imperial (really just ‘Merican now) for the Dutch guides. They couldn’t wrap their heads around temperature in Fahrenheit (nor could the ‘Mericans think in Celsius). I explained that 20°C is room temperature and body temperature is 37°C.
Luckily we never had to deal with volume or pressure.
Stuart Black
Stuart Black
I think we've had this discussion before, but I'll always remember the first time I rode a motorcycle at 100mph, a real milestone.
Liked 1,314 Times
All good arguments for being assimilated into the Borg
The only reason I know Bars is because I scuba dive. We still use psi but I can think in Bars if I have to.
I've always appreciated the water connection to metric as a way of making sense of the measurements - there! tied the segue back to the topic
Quoted: 595 Post(s)
Liked 282 Times
I often make use of a 2L Camelbak when the bulk of my tour is going to be in very hot and humid environments and or the distance between available water refills can be so great, as was the case this summer touring Nebraska ( silly me, I didn't realize it could be so hot and arid there). One thing for sure is I tend to drink more when wearing a Camelbak because it is so easy to catch a sip vs. having to grab for a bottle.
Quoted: 960 Post(s)
Liked 1,627 Times
Sometimes I find myself grabbing for my canteen on my hip... Old Army Habit... ha
Quoted: 960 Post(s)
Liked 1,627 Times
Growing up and working with my grandfather as a kid I remember he was always making the challenge, "?quantos pulgadas", how many inches. And, "?quantos centemetros", how many centimeters. He said you need to know them both and many more. Like speaking Spanish, English, German and Coahuiltecan. But that's in South Texas. It was advice I did not follow but kinda wish I did.
I got a good dose of the metric system when stationed overseas in the Army. I hold the skill close...
Quoted: 623 Post(s)
Liked 396 Times
I can't afford to carry another gram of weight on my body when ridding. I am just to heavy to begin with. If I am planning a hike or a bike route my first priority is available water. That's just the way it is in most of Texas. My Brother and Kuz were taking a day hike in Big Bend. They asked a ranger how much water for the high point hike from the last station. He said 3 gallons then followed 3 gallons each way. It was April.
Likes For Rick:
