How would you fix this?
Quoted: 3015 Post(s)
Liked 3,792 Times
You could try welding/drilling/tapping. I think the probability of it working is low and the probability of it costing more than a new derailleur is high.
Likes For iab:
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
Time for a new derailleur.
Likes For oneclick:
Quoted: 3806 Post(s)
Liked 6,674 Times
Is it tapped all the way through? If so, I’d try a bolt smaller in diameter than what it came with, a nut for that bolt, and a washer to press against the cable. Tighten down and see if it holds when shifting.
Likes For nlerner:
Quoted: 604 Post(s)
Liked 1,063 Times
Landfill, or recycling bin, if they will take it. Recyclers will probably just throw it in the landfill anyway though.
Tim
Tim
weapons-grade bolognium
Quoted: 985 Post(s)
Liked 2,378 Times
Small metal sleeve or band on the outside - slice off a hunk of a .357 casing...
Quoted: 4722 Post(s)
Liked 3,036 Times
That looks like it's a result of some defect during the manufacturing process. I can't imagine a mechanic causing that sort of failure in a derailleur actuating arm.
Likes For T-Mar:
Quoted: 3464 Post(s)
Liked 2,828 Times
When working on those long ago I did not like the design. As the arm moves the cable’s direction of force changes and the cable is not, only deflecting
Quoted: 1106 Post(s)
Liked 1,326 Times
I have not measured it, but it came off a 1969 chromed PX10, so that could be metric tubing; it wasn't an original part (neither was all the other gold stuff) and could possibly have been for 28.6 - a goon would think the cable getting loose was a loose cable anchor bolt instead of the derailleur slipping on the frame.
Passista
Quoted: 866 Post(s)
Liked 721 Times
First I'd cut that threaded part off. Then try to make a "sleeve" from 1/16" or so steel stock with a nut welded and attaching it to the arm with 2 3/32" bolts. Not sure it will work, but since the alternative is throwing it off...
Liked 3,036 Times
www.theheadbadge.com
Quoted: 2421 Post(s)
Liked 4,387 Times
It looks like a later 1970's gold anodized Simplex FD. The aluminum used on these and most other Simplex parts from the era were not great, and I've had one crack at the clamp before.
The example I worked with was also gold, so I'm not sure if the anodizing made the gold variations even more brittle than those in bare aluminum.
-Kurt
-Kurt
Bikes: 1970s Coppi/Fiorelli beater, 1973 Raleigh Competition, 1972 Bob Jackson, 1970 Cilo Sprint-X, 1985 Fuji Touring Series IV, 1969 Legnano Roma
Quoted: 217 Post(s)
Liked 198 Times
Quoted: 1372 Post(s)
Liked 1,751 Times
I run up against this sort of thing all the time. When a replacement part is pricey, I just install anything that I have on hand that will work with the rest of the transmission. Sutour anything is a pretty darn good choice. Then I wait for a chance to snap up what I seek at a price that I can afford. In my mind, the search and find for a good price is part of the fun of this hobby.
This old lady is darn near completely original. Sadly, I did not have a decent handlebar so I used what would work, be it brand, model of period correct. And, guess what...
A decent priced handlebar, exactly what I need, showed up on Ebay today. I put up an item on Ebay that might help me be able to make the purchase. If not, no biggie. I do not mind the hunt.
Liked 3,036 Times
-Kurt
-Kurt
Likes For T-Mar:
Liked 1,326 Times
