Right proper blowout!
Thread Killer
Quoted: 3129 Post(s)
Liked 1,697 Times
We were doing hill repeats last night when, braking hard on a descent, I locked up the rear and *boom* it blew like gunshot. Some say it sounded like a car backfire, but you get the idea either way: it was loud.
I was nearly stopped, so no problem there, and upon inspection found found a 1.5” flap torn from tread center to nearly the bead. It wasn’t a long skid, but I figured I flat-spotted it to the threads and just yielded with a bang. Looking closer, it looks like there’s wear to the threads all around the circumference, concurrent with cracking of the tread right along the centerline. Weird…but there was heat coming off the rim, too, so I wonder if there wasn’t some swelling from overheating the aluminum rim, too. I mean, the tire didn’t have a lot of mileage, and looked to be in good condition prior to the ride; often a worn tread will look thin, revealing the casing texture underneath or looking a little bubbly or wavy, and there was none of that. I certainly would have noticed if the tread was worn through to the threads, anyway, so maybe I was on the verge of that starting the ride and just missed the signs.
Anyway, the Hutchinson Galactik was such a shredded, irreparable mess that it precipitated the “call of shame.” The mosquitoes this year are outrageous here, and I got mauled awaiting my rescue. I can’t recall ever having this type of failure in all my years, so it was something new and, I guess, interesting!
Likes For chaadster:
Quoted: 20808 Post(s)
Liked 9,450 Times
Lol - and I thought that I got a little risky with runnin' my tires down to the cords. I will admit, though, that I did have one tire that did something similar - it looked okay at the start of a ride and was showing cords all the way around at the end.
The Galactik is essentially their RDO tire, isn't it? Probably not too much tread to begin with, so not surprising that you didn't get many miles out of them.
Thin race tyres doesnt last long if locked up. That is one trade off with such light tyres. Then again, I once suggested riding mountains on GP 4 Seasons, for safety reasons. Response was a flood of snide remarks, as if it was the most stupid thing ever, even contemplating it .. There you go! - Watch out and Stay healthy :-)
Thread Killer
Liked 1,697 Times
Aside from the dramatic way it went out, it was an excellent tire…really handled well and seemed fast. I’ll probably go back to Schwalbe Pro One, though,
Thread Killer
Liked 1,697 Times
Quoted: 6177 Post(s)
Liked 4,794 Times
Did you check to see if your rotation arrow was going the correct way when you installed the tire?
Though I don't really think it matters one bit. Although they are hard to make out in the pic, it just seemed to me that the pattern on the tread is in the wrong direction.
I've had tires blow out too, but mine were old and you could almost see the air inside. Although I did have a fairly new tire get a very small sidewall cut and the tube pushed out through the cut and made a noise like a 22 caliper pistol going off...... or did someone with a 22 caliper pistol shoot my tire?
Quoted: 7648 Post(s)
Liked 3,465 Times
I was not shocked when you said Hutchinson.
I have been using their Fusion 5 tires on a couple bikes with bad results. I have had the bead separate from the body on a couple, and another has developed weird wear marks as if the rubber compound was badly mixed and some of it was too soft.
This tire has not been abused, and pretty obviously I didn't lock it up to create those wear patterns .... I would have been skidding through a pretty horrendous low-side, and those moments tend to be memorable.
I think Hutchinson built a bad batch of tires, maybe? Sticking with Contis or something else from now on, I guess,.. Too bad---I really liked the Hutchinsons while they were holding air.
Likes For Maelochs:
working on my sandal tan
Quoted: 3870 Post(s)
Liked 2,563 Times
Thread Killer
Liked 1,697 Times
Maelochs Whoa!
I was just getting home from the last ride on this thin GPsomething when I thought it might be a good idea to lock up the rear and see what happens. It blew almost instantly and then I realized you fool you just ruined a good tube.
Liked 4,794 Times
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
@chaadster: Phwoar!
Dude, wuut?! That's gotta be in the top five of the weirdest things I've seen go wrong with a bike.
BTW, just discovered something neat - I just @ed "OP", and the board did the rest.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Likes For Kimmo:
Liked 2,563 Times
Liked 9,450 Times
Likes For WhyFi:
Advocatus Diaboli
Quoted: 4729 Post(s)
Liked 1,531 Times
Quoted: 18349 Post(s)
Liked 4,502 Times
Anybody consider not locking up the rear wheel? Or if you manage a chirp, let it go very quickly.
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
That looks horrible. Is it rubbing somewhere?
Liked 4,502 Times
Quick boot and you're back on the road.
Gator Hardshell, mounted previous day new. 70 miles or so into the ride. Bead blown off.
Booted, removed brake pads, and limped an additional 20 miles to the nearest bike shop, picking up anything that appeared useful along the side of the road.
