ANT+ cadence/speed sensors recommendations
Old 01-06-13, 11:47 PM
rho
Bikes: Cervelo P1, Time RXRS, De Rosa King RS
Im currently using garmin's sensors for my bikes, however I have some issues with one bike, as the chain stays are not straight as in my other rides. Garmin's device seems not to suit this particular frame, because of the shape of the chain stays it is not possible to the bike computer to catch both wheel's speed and cadence, even if I move the lil speed detector arm. For the record I want to say that the magnet for the cranks it's located into the pedal's axle and most ofbthe times I use metal spoke wheels the wheel's magnet rubs the sensor because the sensor moves due to chainstay's design.
Please feel free to give some advice on some reliable options. It doesnt matter if the speed sensor hast to be attached to the fork.
Thanks in advance.
Ronaldo
File Type: jpg
rho is offline
Old 01-06-13, 11:52 PM
jdott
100% car free
Bikes: 2008 LeMond Tete de Course
There's a Timex speed/cadence sensor where the two are separate and connected with a wire. Your shop should be able to get one for you.
jdott is offline
Old 01-06-13, 11:54 PM
timmy29er
timmy29er's Avatar
Bikes: 2012 Giant TCR Advanced SL, 2013 Giant Anthem Advanced
https://www.wahoofitness.com/Products...nce-Sensor.asp
Would this work?
timmy29er is offline
Old 01-07-13, 05:16 AM
bobones
Quoted: 22 Post(s)
Liked 22 Times in 10 Posts
Can you get the Garmin sensor to work by swinging the speed sensor arm upwards so it's clear of the chain stays? Otherwise, as timmy29er and jdott say, the Wahoo sensor and similar designs should do the job. If you were in Europe, I'd recommend the sensor from Decathlon as it's super cheap and the design would work for you. But you're not, so I won't!
Incidentally, I now have 2 broken GSC10 sensors so would not recommend them. Both have the same fault: broken reed switch in speed sensor. Neither is much older than one year. I'm currently using a Motorola sensor which has been very reliable and can be easily switched between bikes because it uses a rubber o-ring rather than zip ties to attach it to the bike. It's a similar shape to the Garmin so may not work for you. I believe the Bontrager Interchange sensor is exactly the same as the Motorola one I'm using.
While I'm whinging. My Garmin deluxe HRM strap also stopped working prematurely. Replaced by a Motorola strap that has been fine. I won't be buying any more Garmin accessories, that's for sure.
bobones is offline
Old 01-07-13, 07:08 AM
fenice
Have you considered a new magnet? The distance between the magnet and sensor can be greater than the standard Garmin magnet - I use them on both my bikes with a large gap and no problems.
fenice is offline
Old 01-07-13, 08:25 AM
rho
Thanks for the replies guys.
I already tried changing the speed sensor position and no good results...
I'm no fan of wired sensors, I think the tech-bug bite me long time ago, thanks on the timex option anyways.
I think the cylindrical magnet Im currently using is better than the stock garmin's, as I can onky take it off with the metalic part of the torque wrench and actually I can lift the torque wrench with it. Anyway ill try to find out a longer one to reduce the gap.
I'll ask about the wahoo, motorola/bont at the LBS.
Ronaldo
rho is offline
Old 01-07-13, 08:32 AM
bobones
Quoted: 22 Post(s)
I think you picked this up wrongly. The Timex sensor is the same design as the Wahoo one: there is a little wire between the cadence and speed parts that makes it easier to position them independently, which should help on a bike with stays like yours.
bobones is offline
Old 01-07-13, 08:50 AM
Cowboy905
total Newbie
Bikes: 2009 Look 566 Ultegra
Quoted: 8 Post(s)
Liked 7 Times in 7 Posts
Thanks in advance.
Ronaldo
i have the same issue as you with my chainstay design.
Like others have said, the Wahoo seems like it will do the trick.
Cowboy905 is offline
Old 01-07-13, 09:49 AM
saratoga
Bikes: ?
That's what I have. The wire between the two makes it easy to point the cadence sensor one way and the speed the other. It looks identical to the Wahoo thing.
$38 on Amazon with free shipping.
saratoga is offline
Old 01-07-13, 10:34 AM
Looigi
Looigi's Avatar
Quoted: 14 Post(s)
Liked 13 Times in 12 Posts
Swing the GSC10 sensor arm up, as has been mentioned. Loosen the little screw holding it, swing up, then gently tighten it. I needed to do this on both road bikes I have with GSC10 sensors...
Sometimes it's possible to use it with the sensor between the left chainstay and the spokes by using and additional zip tie to hold the arm against the chainstay. It is also sometimes possible to put the magnet flipped around on the spoke to give more clearance, or even mount it on a ride-side spoke.
File Type: jpg
Looigi is offline
Old 01-07-13, 02:18 PM
rho
Sorry bobones, I got you wrong. I'll check the timex as well.
Looigi, i've already tried rotating the sensor's arm but it didn't improve the gathering of data.
I guess that frame manufacturers try to keep our minds sharp in these cases by doing some crazy/good looking designs for the chainstays.
rho is offline
Old 01-08-13, 06:49 AM
rolliepollie
Flying Pig
rolliepollie's Avatar
Bikes: 06 Specialized Allez Sport, '10 Trek Fuel EX 7
You need to move the sensor to the left in your pic. I have the same Garmin sensors on my road and mtn bikes with chainstays that are also not very straight. You should be able to strap the sensor close enough to the crank sensor then swing the wheel sensor arm close to the wheel sensor. If it's too wide a gap, put some double-sided tape on the crank sensor. Doesn't matter if the sensor is a little crooked as long as they sense the magnets at the grooved markings.
rolliepollie is offline
Old 01-08-13, 07:25 AM
bobones
Quoted: 22 Post(s)
The easiest way to test this is press, hold and release the little white button on the front of the sensor unit. It should blink red then green. Now it should flash red when the cadence magnet is detected and green for the speed magnet. If you get green and red flashes you are good to go. If you don't get green flashes at all, even when the magnet is close, then the reed sensor in the speed arm may be broken, which is a common fault. The lights only flash for a small number of revolutions so you may need to repress the button to retest. If the flashing is as it should be, go to the head unit and make sure the sensor is being picked up. If not, change menu to no sensor present, back to present and then rescan.
bobones is offline
Bezalel
Tandem Cycling
59
09-17-16 10:46 AM
taat2d
General Cycling Discussion
10
07-02-16 09:39 AM
MikeDVB
4
05-23-14 12:47 AM
Aushiker
Recumbent
0
07-20-13 08:35 PM
wrr1020
Road Cycling
12
01-15-11 05:48 PM
