Question about Front Delarieur E-type triple
Quoted: 18 Post(s)
Hello
I wanted to ask about something I have the possibility to buy a triple front derailleur, E-type.
The specifications are: 46/34/24
I wanted to know this: ¿Can I use it as a double front derailleur with a 46/30 crankset, or is it possible to only use the triple configuration?
Thanks in advance
Thanks in advance
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
Not well. Triple FD's have a specially shaped cage for the two shifts and the upper shift is usually optimized for the teeth difference between the middle and top rings
Shimano tech docs still show a bunch of e-type FD's available and most of them are doubles.
https://productinfo.shimano.com/#/sp...t%20Derailleur
Genesis 49:16-17
Genesis 49:16-17
