Brake parts
Old 08-06-21, 01:10 PM
Bladeputr13
Quoted: 15 Post(s)
Brake parts
I hope you guys don't mind simple questions. What is the eyelet for at the base of my pinky and the triangle piece sitting by itself. Two of them connect below the brake pads.
Bladeputr13 is offline
Old 08-06-21, 01:17 PM
Bladeputr13
Quoted: 15 Post(s)
Sorry, meant to post to bicycle mechanics.
Old 08-06-21, 01:20 PM
tyler_fred
tyler_fred's Avatar
Quoted: 350 Post(s)
Liked 276 Times in 128 Posts
The triangle pieces are tire guides. When installing your wheel, its function is to guide the tire between the brake pads. Does it help? Meh...
The eyelet hole is most likely aesthetics.. but also a grip function when opening the caliper arms.
tyler_fred is offline
Likes For tyler_fred:
Old 08-06-21, 01:23 PM
ClydeClydeson
Quoted: 581 Post(s)
Liked 921 Times in 518 Posts
I think the 'eyelet' is actually part of the quick release to open the brake slightly to remove the wheel. It's probably 'closed' when the eye is pointing down towards the brake pad, and open when pointing up (as it is in the picture).
ClydeClydeson is offline
Likes For ClydeClydeson:
Old 08-06-21, 01:25 PM
Charliekeet
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times in 142 Posts
The "eyelet" thing on the right side is not an eyelet - it's just a place to grab and turn what is a quick-open mechanism; swing up (like the position it's in now) and it enables you to loosen the brake pads apart to make on/off of the wheel possible without having to unclamp the brake cable. Yours just happens to have a hole there, but it could be filled in solid metal and it works the same.
The thing on your palm, I'm not sure.
Charliekeet is offline
Likes For Charliekeet:
Old 08-06-21, 01:35 PM
Bladeputr13
Quoted: 15 Post(s)
Thanks guys/gals! You're great.
Likes For Bladeputr13:
Old 08-09-21, 07:49 AM
sovende
Bikes: TNTL (Too numerous to list)
Quoted: 184 Post(s)
Liked 147 Times in 115 Posts
Can’t say for sure but the “eyelet” most likely had a rubber or plastic cover that has long since gone missing. I have a few bikes with that type of brake caliper and most had the cover still intact. I put improvised covers on the ones that didn’t.
sovende is offline
