Screw on Presta pump
Cantilever believer
Quoted: 531 Post(s)
Liked 1,826 Times
Likes For RCMoeur:
Quoted: 3504 Post(s)
Liked 2,922 Times
Liked 2,922 Times
A
I ordered the screw on presta adapter suggested by smd4. It arrived today and was tested. As soon at the pump head is clamped on it starts leaking. Specifically, when the clamping lever is pulled up it starts leaking. The little screw knob on the presta valve was backed off about halfway, same result. I cannot stop the leaking..
Quoted: 430 Post(s)
Liked 460 Times
Sounds like there's at least some user error with the original pump but I love Lezyne and have two floor pumps for the house/garage and one mini pump for the ride. Never have to guess again whether I've got a good seal. Some regular flip chucks work great initially but over time the seal wears out and it becomes finicky. To be fair the Lezyne threaded chucks can wear out too but it takes longer to wear in my experience and they're easy to replace when needed.
Expired Member
Quoted: 3661 Post(s)
Liked 5,408 Times
May be obvious to most, but a pump with a flexible hose can usually accept other brands of head with the help of a small worm gear hose clamp.
Quoted: 6191 Post(s)
Liked 4,807 Times
Perhaps the OP is pushing the air chuck too far down on the valve before moving the locking lever. The air chuck shouldn't engage the presta valve core at all. At least not on the ones that I've used. Air pressure alone is all that is needed to open the presta valve once it's unscrewed. It is a good habit to burp the valve prior to putting the air chuck on as sometimes they get sticky.
Likes For Iride01:
Liked 2,922 Times
Funny you should mention that. I, too, always tap the presta valve once unscrewed, but in decades of doing this on my bike and others', not once has the valve been sticky. I don't know why I continue to do it, but I do. Probably another old bike wives' tale.
Liked 4,807 Times
Not a wives' tale. I finally after all these years currently have a presta valve core that is sticky. Don't know why but it is. If I forget to burp it, then I have to put all my 175 lbs on the pump to get it to open. And that's not easy to do, so I usually take off the air chuck and burp it like I should have done originally.
Likes For Iride01:
Expired Member
Liked 5,408 Times
I always burp the valve and assumed everyone did until a friend was having (now that I remember) maybe the same issue as OP. Good call and maybe that will solve OP's problem.
Lopsided biped
Bikes: 2017 Day 6 Cyclone (the Buick); 2015 Simcoe Deluxe (the Xebec); Street Strider 3i (the not-a-bike); GreenSpeed Anura (the Black Swan)
Quoted: 316 Post(s)
Liked 160 Times
Try replacing the valve core?
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
It's like riding a bicycle
Cantilever believer
Quoted: 531 Post(s)
Liked 1,826 Times
While I would personally follow your advice and not drill out a hole, beng1 's claim that it has lasted 20 years seems to suggest it's not that big of an issue. I have seen rim models offer both presta and schrader versions, so I imagine at least those would be capable of being drilled out (if done properly).
Several of these rims have failed, but at a sidewall or spoke hole, not at the valve hole.
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
climber has-been
Quoted: 3427 Post(s)
Liked 3,561 Times
But not all rims are beefy, and aluminum in particular doesn't last long when highly stressed. I repeat my caution against drilling out rims. Especially a lightweight road rim, such as the Mavic MA40:
Mavic Ma40 rim cross section
Of course, there will always be the requisite "I did this and it didn't fail" responses. Personally, I would not take the chance on such a repetitively stressed part.
Over the hill
Quoted: 996 Post(s)
Liked 1,204 Times
Based on photos of beng1 bikes, he's probably drilling out cheaper rims with plenty of metal to spare. Lucky for him.
Likes For urbanknight:
Quoted: 7 Post(s)
Liked 6 Times
There is no realistic weakening from widening a hole in any but the narrowest road rims.
It's pretty common on the touring side of things for the sake of replacement tube compatibility, and touring loads push wheel components to their limits.
However, I personally recommend this over a drill. "Hand reamer." Hand reaming from presta to tight schraeder takes two minutes if you're being careful.
Likes For ExtremeSquared:
Quoted: 7 Post(s)
Liked 6 Times
Vaguely related to the original question...
Crank bros makes a screw on presta mini pump, sort of.
The hose-pump interface is click-in magnetic, so you just screw the whole mini hose onto the valve, then attach it to pump.
I'm testing the reliability of this pump now. It's hard to say whether it's a good / durable design.
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 253 Times
Lezyne floor and mini pumps are the best for the money, followed by Topeak. Sure, Silca makes a great pump, but they start at $150, whereas with the Lezyne you can get a similar quality steel floor pump for half the cost of the Silca, and like the Silca it's rebuildable. Lezyne mini pumps are the best in the world, they pump up tires faster than the competitors using less strokes to do so. If you want a frame pump, go with the Topeak Road Masterblaster, the Zefal frame pump was probably a tad better but it's no longer being made, and the Silca offering is way overboard on price. With a frame pump you do have to measure your frames inside dimensions from the seat tube to the headtube to get the correct fit.
Quoted: 4802 Post(s)
Liked 3,923 Times
May I recommend this based on a quick search from one of my favorite vendors:
https://www.walmart.com/ip/AUDEW-Bik...5?from=/search
Quoted: 426 Post(s)
Liked 274 Times
I have this pump to mount my tubeless tires. It works great for that. It screws onto the presta valve like you want. If I am not trying to seat my tubeless tires I never use this pump though. I find it a hassle to screw on the presta valve vs the other floor pumps that just kind on cinch down over the valve. This might work for your tire though.
Digital Pressure Over Drive 2.5
