Vintage Schwinn downtube shifter issues
I have just restored a 1964 Schwinn Varsity and the downtube shifters (with braze-on brackets, not bosses) seemed to be fit and secure when I took it apart, but when I put it back together the shifter keeps wanting to slip off of the braze-ons. No matter how tight I clamp it down. When I try to mount it above the braze-on brackets the shifter clamp won't tighten around the down tube.
For now, I have cut a strip of rubber from an old tube and wrapped it around the tube above the braze-on brackets and clamped the shifter down tight over the rubber strip, it is tight'ish and won't slip down below the brackets now but it visibly moves to one side when I pull the lever to shift. I looked for a clamp-on boss set but the down tube appears to be 26.4 mm rather than the 28.6, which is about as close as I can find to 26.4 with clamp-on bosses. I thought of converting it to a stem shifter and putting cable hangers where the downtube shifter is now, but I like the downtube shifters... AND the cable hangers are still also 28.6, still too big. Also thought of just getting a different down tube shifter, but nothing I'm finding appears to be the correct size (and that's verified by comments on various sites by posters who confirm their shifters are too large for the 1960s down tube Schwinn.
Seems like this should be a really easy non-problem, but it's not. Anyone else had this issue, and if so, how did you solve it? I'm a new member and can't post pictures until I get ten posts, otherwise I'd post a few here.
Quoted: 3803 Post(s)
Liked 3,324 Times
hello and welcome to the forum
perhaps this parts drawing will help you to communicate with readers...
Likes For juvela:
Quoted: 4510 Post(s)
Liked 6,374 Times
I have just restored a 1964 Schwinn Varsity and the downtube shifters (with braze-on brackets, not bosses) seemed to be fit and secure when I took it apart, but when I put it back together the shifter keeps wanting to slip off of the braze-ons. No matter how tight I clamp it down. When I try to mount it above the braze-on brackets the shifter clamp won't tighten around the tube.
For now, I have cut a strip of rubber from an old tube and wrapped it around the tube above the braze-on brackets and clamped it down tight, it won't slip down below the brackets now but it visibly moves to one side when I pull the lever to shift. I looked for a clamp on boss set but the tube appears to be 26.4 mm rather than the 28.6, which is about as close as I can find to 26.4. I thought of converting it to a stem shifter and putting cable hangers where the downtube shifter is now, but I like the downtube shifters... AND the cable hangers are still also 28.6, still too big.
What gives? Anyone else had this issue, and if so, how did you solve it? I'm a new member and can't post pictures until I get ten posts, otherwise I'd post a few here.
As was said in the other thread, we need pics, you need 10 posts, 5 X 2 days, respond to any posts here to get there.
Likes For merziac:
Liked 3,324 Times
the final year for these downtube controls on the Varsity was 1966
beginning with the 1967 model year they came through with the Twin Stik stem controls
Quoted: 809 Post(s)
Liked 1,018 Times
Does it have a band clamp kmerskine ? It sound like it does since you were able to wrap an inner tube around it. I'm with you on keeping the down tube shifters.
Pictures will help. If they are the original band clamps, I wonder if they got bent out of shape. Pictures are going to help.
Put some pictures in your gallery and perhaps someone can retrieve them and post them. Otherwise, post five comments a day and you'll be up to the required 10 posts in two days.
Fun fact here at BikeForums C&V, some members appreciate Varsities and Continentals and some don't. No worries, we have plenty of members in the Varsinental camp.
I love the down tube shifter look. I'm new to restoring bikes and don't know why down tube shifters weren't the go-to for most bikes, instead of the stem shifters. I have a 1986 Bianchi, my first road bike - I bought it new from the LBS, that has down tube shifters. Another bike I restored from the 1970s has the stem shifters and although they are solidly connected to the frame, I just don't like them.
Quoted: 809 Post(s)
Liked 1,018 Times
Stem shifters became popular during the bike boom of the '70's. People liked the sporty look and feel of the lighter weight, agile European bikes. But for most people they rode with these new ten speeds, their hands on top of the bars rather than the drops, so it was a shorter easier reach to stem shifters. The other item that came with the bike boom was Turkey levers.
Schwinn made 1000's, maybe 100's of thousands of Varsities. Varsities with down tube shifters are less commonly seen. Let's see if someone here or the collective group can help get the shifter mounted back on the frame.
Likes For Velo Mule:
mycocyclist
Quoted: 910 Post(s)
Liked 811 Times
Picture Assistance
They are brazed on clamps, but the new paint has slightly increased the size of the clamp so the shifter no longer fits them snugly. There are no bosses, unfortunately.
And here are a few pics. I'm looking at possibly just getting some clamp-on bosses, but cannot seem to find anything online that matches the diameter of this down tube. From measuring it, it appears to be 26.4. Can anyone confirm that? I've looked online and cannot find anything confirming this, AND replacement parts all seem to be 28.6, which might be the diameter the clamp needs to be if clamped over the braze-on bracket.
Quoted: 809 Post(s)
Liked 1,018 Times
kmerskine great job on the repaint and cleaning and polishing all the metal surfaces. I noticed that the cable on the front brake caliper does not align. If you put the barrel adjuster in front of the brake arm it should line up better. Are you missing the rear brake frame ferrule?
It looks like there is a band clamp for the down tube shifters. Is the clamp sliding down the down tube? You don't want that happening with new paint. Is there something limiting how tight you can make the clamp. Are the ears of the clamp touching each other?
Can you get a close up picture of the underside of the band clamp, where the screw goes through?
Edit: Thanks for posting the pictures. I was typing while you were posting. Now we can see what you are describing as it originally had braze on's for the shift lever and they were cut off. If you move the shifter clamp above the braze on's this will stop the shifter from sliding down, assuming that the band clamp is the right size. You will be left with a visible hole in the frame though.
Or is it possible that I am all wrong and this is the wrong shifter. I have to admit, I am not sure what shifter was originally on the bike. The one that you have looks correct. But the braze on on the down tube has me at a loss.
Quoted: 2362 Post(s)
Liked 1,749 Times
Are there threads inside those holes on the braze-ons? If so, there might have been studs threaded into them, analagous to studs threaded into braze-on bosses for cantilever brakes. Finding the right studs might prove to be a challenge.....
Quoted: 809 Post(s)
Liked 1,018 Times
kmerskine from your pictures in post #12, it looks, to me, like your Varsity had the shift levers and all the plates mounted directly to the "braze-on" . Then it looks like someone cut off the shifter studs, then some time after that installed a band clamp shift lever. So, the good thing is that you have the right pieces. The bad is that the shifter studs have been cut off and what remains has to be dealt with. Even worse is that brazing on a new stud would require repainting.
Velo Mule, thanks. I'm not sure what you mean re "cable on the front brake caliper does not align." Do you mean the cable housing is coming through the frame hanger for the cable? If so, I've gotten a new ferrule for a few bucks on ebay and that is now fixed (as is the ferrule that I was missing on the right brake handle).
Yes, the down tube shifter is a clamp on. It was sliding down the tube when I tightened up the cables and tried to pull a lever. Above the clamps, yes, the ears were making contact and preventing me from tightening it up tightly enough. So I've gotten a piece of rubber from an old tube and cut it, wrapped it around the down tube, and used the original braze-on brackets as stops. So now it doesn't slide down the tube, but it does visibly move to the left or right when I pull the left or right lever. It will work, but it's not the perfect solution. I had to tighten the shifter band down so tightly that I was afraid it the bolts on the back would rip the metal band apart in the front. You can see from these pics that I roughed up the paint pretty good.
No, no threads. And nothing came out of there when I took the shifter off originally. When I took it off I thought it was oddly attached - just sort of settled in there snugly - and I put it on and took it off a few times to be sure I'd remember how to do it. But the paint seems to have increased the size of that fit just enough to make it no longer fit.
Liked 1,749 Times
So that's the same band/clamp as in the original photo, cleaned up? And it fit over the braze-ons originally? Then I would say sand off enough paint to get it to fit over again. If it takes it too far down, you can touch it up with a very thin coat. It'll be under the band anyway. Might also be worth trying a longer screw.
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 977 Post(s)
Liked 626 Times
Those Teruh shifters are rare.
Perhaps consider a spacer band of a less compressible material? Some kind of plastic... or cork?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 809 Post(s)
Liked 1,018 Times
Thanks for more pictures kmerskine . I like the fact that you placed the shifter clamp above the braze-ons, This should have stopped them from moving down, The fact that they continue to move and I noticed that the clamp ears are touching each other, may mean that the clamp size it too big for the Schwinn tube size. As you noted above, Schwinn electroforged frames have smaller diameter tubes than most other bikes of the time. The fact that someone found the correct style Huret shift levers is great, however, they may not have come from a Schwinn. At least that is my thinking since they don't seem to fit.
madpogue idea of removing the paint is based on the assumption that it worked before. Was it staying in place before the restoration? If placing the band over the braze-on's works then it also it covers the holes in the braze-on's that you don't want to be visible anyway.
Wrap masking tape around the fresh paint so that if the file slips you won't take off good paint.
Lol, yes, I might have the only one! By the time I realized it was upside down the cables were already connected and I didn't feel like taking it all apart to put it right side up. Figured if I can find a better solution to this it will come off again anyway.
Yes, same band, same everything, just painted over. The LBS guy suggested the light sanding option to me today as well. Might give it a try.
Ride, Wrench, Swap, Race
Quoted: 1562 Post(s)
Liked 1,288 Times
Yeah if the clamp size is too big for the frame tube the lever axes will appear slightly out of parallel, in the "drooping" direction.
