Go Back  Bike Forums >
Bike Forums
Classic & Vintage
Old downtube shifter and new derailleur
Old 09-25-22, 05:39 AM
Spellscape
Spellscape's Avatar
Bikes: Union Sakai
Quoted: 59 Post(s)
Liked 113 Times in 41 Posts
Hi all
Is there any way to use new 10 speed shimano MTB derailleur on old downtube shifter (was 6 speed)
I just want to use 8 speed -9 speed cassettes with it and to save my classic derailleur for thematic rides.
It seems that I don't have enough cable to pull for 1 more cog on back - I can do it by hand pulling cable and all mechanically working fine.
Spellscape is offline
Old 09-25-22, 05:47 AM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2723 Post(s)
Liked 2,201 Times in 1,225 Posts
Originally Posted by Spellscape View Post
Hi all
Is there any way to use new 10 speed shimano MTB derailleur on old downtube shifter (was 6 speed) Which shifter? Friction should work, but yes the amount of cable the shifter “wraps” will be an issue
Shifting into the largest cog probably won’t work because as soon you release tension on the cable it will likely shift back to the smaller cog.
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Old 09-25-22, 05:53 AM
Spellscape
Spellscape's Avatar
Bikes: Union Sakai
Quoted: 59 Post(s)
yes I'm thinking about
ENE 11S SHIFTER | Diacompe
Likes For Spellscape:
Old 09-25-22, 06:07 AM
Bianchigirll
Bianchi Goddess
I’m unfamiliar with this particular shifter but it seems to be styled after some Campagnolo shifters I have. The rear/right shifter looks to have a much larger barrel to wrap all that cable.
I thought you were trying to use and older pair of shifters.
ENE 11 DiaCompe
Old 09-25-22, 06:10 AM
Spellscape
Spellscape's Avatar
Bikes: Union Sakai
Quoted: 59 Post(s)
Yes but if they don't have enough cable pool - I can change them supposedly - also saving them for vintage rides.
Are old french brazed downtube shifters mounts same size as modern ones?
Old 09-25-22, 06:20 AM
Moe Zhoost
Half way there
Moe Zhoost's Avatar
Quoted: 958 Post(s)
Liked 828 Times in 496 Posts
[QUOTE=Spellscape;22658602]yes I'm thinking about
ENE 11S SHIFTER | Diacompe[/QUOTE
I wanted to use DT shifters when I converted and old Bianchi frame to an 11 sp rear. The Diacompe shifters seemed to be the only game in town. Unfortunately I could not find them anywhere at the time, so I went with a Shimano Dura-Ace bar-end shifter that works really well.
You may have some luck with one of the cable pull converters, like the Jtek Shiftmates.
Moe Zhoost is offline
Old 09-25-22, 06:21 AM
jamesdak
Bikes: Paletti,Pinarello Monviso,Duell Vienna,Giordana XL Super(2)Lemond Maillot Juane (2) & custom,PDG Paramount,Serotta CSI,Fuji Opus III,Davidson Impulse,Pashley Guv'nor,Evans,Fishlips,Prologue TT,Y-Foil,Softride, Tetra Pro, CAAD8 Optimo,Klein Quantum II
Quoted: 2098 Post(s)
Liked 3,187 Times in 1,277 Posts
I can say for sure that the old Simplex shifters will cover up to an 11 speed cassette.
If you are just barely falling short with your current setup try running cable housing liner over the part of the shift cable passing over the barrel of the DT shifter. That gives you a tad more range.
Steel is real...and comfy.
jamesdak is offline
Likes For jamesdak:
Old 09-25-22, 06:23 AM
Dylansbob
2k miles from the midwest
Dylansbob's Avatar
Quoted: 495 Post(s)
Liked 823 Times in 404 Posts
microshift makes a barcon/thumbie that can be used on a DT boss.
Dylansbob is offline
Old 09-25-22, 06:24 AM
Spellscape
Spellscape's Avatar
Bikes: Union Sakai
Quoted: 59 Post(s)
I think they are old Simplex - not single markings on them
Old 09-25-22, 07:05 AM
jamesdak
This is an Ultegra 9 speed RD
These covered everything from 8 speed Shimano up to an 11 Campagnolo cassette as I changed gearing over the years
This frankenbuild ran everything from 8 to 11 speeds over the years I had it. Simplex shifters had plenty of pull.
Are you sure your cable tension is right and limit screws are not causing problems? When you are on the smallest gear in back is the DT shifter at the end of it's travel in the one direction? So that basically you are getting all the pull capability? If so they it must by pull ratio on the RD limiting you if you can physically cover the full range of the cassette. Would moving to the other side of the RD pinch bolt give you more pull per movement of the RD?
jamesdak is offline
Old 09-25-22, 07:12 AM
Spellscape
Spellscape's Avatar
Bikes: Union Sakai
Quoted: 59 Post(s)
maybe because my derailleur is MTB SGS ? I think road ones have shorter pull
Old 09-25-22, 07:40 AM
jdawginsc
Edumacator
Quoted: 1846 Post(s)
Liked 1,983 Times in 1,324 Posts
Do you mean the retro friction, James? That would be good info since I have somehow amassed three sets, though I will likely never go 11 speed.
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1980s Vanni Losa Cassani thingy, 1985 Trek 670, 1982 AD SLE, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981? Faggin, 1996ish Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe (most not finished of course), 1989 Fauxsin MTB, 1981 Ciocc Mockba...I...am...done....
jdawginsc is offline
Old 09-25-22, 07:54 AM
repechage
Quoted: 2690 Post(s)
Liked 1,732 Times in 1,273 Posts
Miya not the stub diameter so much as different threading and cable stop plate mounting
repechage is offline
Old 09-25-22, 09:22 PM
1simplexnut
1simplexnut's Avatar
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 238 Post(s)
Liked 461 Times in 207 Posts
Yes those grey painted plain old levers are most definately Simplex .
1simplexnut is offline
Old 09-26-22, 12:24 PM
KCT1986
Quoted: 175 Post(s)
Liked 138 Times in 104 Posts
Yes, pre-11 speed road RD use shorter pull. Pre-10 speed MTB RD also use a shorter pull and should work better than a long pull 10 speed RD.
KCT1986 is offline
Old 09-26-22, 12:51 PM
Spellscape
Spellscape's Avatar
Bikes: Union Sakai
Quoted: 59 Post(s)
I think yes - tested with my kids bike SHIMANO ALTUS RD-M310
and all is working just fine - so ordered SHIMANO Alivio RD-T4000 - hope it will work fine
Old 09-26-22, 09:48 PM
Retoocs
Quoted: 54 Post(s)
Liked 24 Times in 17 Posts
There's an easy solution. Take the inner liner out of some shifter cables housing. You'll need about 2". Side the liner into the shifter cable all the way up to the shifter. The liner will now sit in the cable groove on the shifter. This effectively increases the diameter letting you pull more cable.
Retoocs is offline
Likes For Retoocs:
Old 09-27-22, 04:40 AM
Hondo6
Bikes: Yes
Quoted: 358 Post(s)
Liked 396 Times in 275 Posts
ENE 11 DiaCompe
Exactly. The folks at Velo Orange say it can pull 50+mm of cable. They also say they've tested it with Shimano 11-speed road, Shimano 10-speed Dynasys (mountain), and Sensah SRX and found it works with each.
Hondo6 is offline
Old 09-27-22, 04:45 AM
Spellscape
Spellscape's Avatar
Bikes: Union Sakai
Quoted: 59 Post(s)
Will they fit old french brazed downtube mounts?
Old 09-27-22, 05:35 AM
Hondo6
Bikes: Yes
Quoted: 358 Post(s)
Have no idea. Might want to ask the folks at Velo Orange.
Hondo6 is offline
Old 09-27-22, 05:57 AM
Hondo6
Bikes: Yes
Quoted: 358 Post(s)
To add some detail: per Bike Gremlin, other than 6-8 speed Dura Ace Shimano used the same pull ratio for all of their index-shift mountain and road derailleurs up to 9 speed - 1.7. That means 1mm of cable pull by the shifter resulted in 1.7mm of RD lateral cage movement. (6-8 speed Dura Ace used a slightly higher pull ratio of 1.9mm). Shimano 10-speed road also used a 1.7 pull ratio.
That changed with 10-speed mountain, which Shimano called Dynasys. That used a very different (by between 30 and 40 percent) pull ratio: 1.2. So Dynasys required substantially more cable pull per shift.
Shimano 11-speed road followed suit and also used a lower pull ratio, but that was 1.4 - not compatible with 10-speed mountain. (Tiagra 4700 and GRX also use this pull ratio.) And 11-speed mountain changed again - to a pull ratio of 1.1.
Haven't seen info about Shimano 12-speed.
Hondo6 is offline
Old 09-27-22, 09:02 PM
icepick_trotsky
Aspiring curmudgeon
icepick_trotsky's Avatar
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 111 Post(s)
Liked 20 Times in 10 Posts
You can also try alternate cable routing at the rear derailleur to change the pull, or use a device like a Wolftooth Tanpan to change the pull ratio to increase it. This YouTube clip shows it in action. They use it to get a rivendell silver shifter to work with a SRAM eagle 11 speed system:
"Party on comrades" -- Lenin, probably
icepick_trotsky is offline
Old 09-28-22, 07:55 AM
Spellscape
Spellscape's Avatar
Bikes: Union Sakai
Quoted: 59 Post(s)
New nonMTB deraileur solved everything.
Actually it was cheaper than buying new shifters
