Triumph Tiger firing on two cylinders at tickover but seems ok at speed
Weird weird weird.
My 1994 Triumph Tiger sounds like it is only running on two cylinders at tick over, but when riding it seems not to be down on power at higher revs.
Now I am either kidding myself, and my triple has turned into a twin - or third cylinder is kicking in at higher revs?
right hand downpipe does not even get warm at tickover whilst other two get hot quickly.(did the water spray test)
I took off the HT lead while it was ticking over and sure enough - no discernable difference
I put a spare plug onto the removed HT lead and spark is very strong...
Sooooo then - clues?
Could this be a carb problem?
Any ideas what I can do next?
Perineal Pressurized
During installation, a dialog appears warning that email acceleration and FTP acceleration are disabled because another Layered Service Provider (LSP) was detected.
This dialog is a warning stating that email acceleration and FTP acceleration will not be installed on this computer due to a software conflict.
However, the Web acceleration will still work properly. If you would like to have email acceleration and FTP acceleration, the other LSPs must be removed followed by a re-installation of SlipStream SP.
Please contact your Internet Service Provider (ISP) for proper instruction regarding this matter.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Weird weird weird.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
aka Phil Jungels
Low speed juet plugged, or partially plugged. Try a half can of Seafoam, or a bottle of Chevron Techron Concentrate in the tank.
If not completely plugged, that should clear it. If not, excise the clog, while rebuilding the carbs.
Just remember to make sure it gets a lot of time idling while that stuff is in there.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Weird weird weird.
cab horn
Quoted: 42 Post(s)
Liked 26 Times
Domestic Domestique
Bikes: Brand New Old Catamount! Schwinn Homegrown, Specialized FSR, Salsa Vaya, Salsa Chile Con Crosso
Liked 6 Times
It's the carb idle circuit on that dead cylinder. Try a gasoline applied carb cleaner. If that doesn't solve the problem, the carb will need to be overhauled. Hope this helps.
Triumph Tigers are nice bikes but this forum is for bicycles. Cheers!
o - I think that was supposed to be a "wtf" error message to match the "wtf" OP. Of course, given all the helpful responses to the OP, I'm sure this forum will now start scoring high in motorcycle-problem Google searches.
Bikes: Specialized Rock Hopper, Felt F-70, lemond Buenos Aires, Trek T900 Tandem, Bianchi Volpe
How refreshing to have a thread that is not about endless saddle experiments, busted bottom brackets, or knee pain...
aka Phil Jungels
I'm getting ready to head for the southwest, NM, TX, AZ, for a couple weeks. I'll be on my Goldwing, flyin low........
Leavin 0300 Wednesday - my bike will be sooooo lonely.......
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 705 Times
Jeff Wills
Jeff Wills
STFD
Bikes: '80 Windsor Carrera Sport, '02 Specialized Sirrus A1, '10 Giant Escape 2
Put some pedals on it and you'll have no carb troubles.
(Someone had to say it.)
Bike ≠ Car ≠ Ped.
And I'm shocked that there's so many closet motorcyclists on this bicycle forum....
"Purgatory Central"
I'm with 'San Rensho' on this. I suspect the idle circuit too, for whichever carb feeds that cylinder.
Take the plug out of the cyclinder and squirt a little gas in it and fire it up. If all three cylinders run at start up, then quickly breaks down to two cylinders then it would be idle circuit carb problem for that cyclinder.
Hope that helps
Hope that helps
A '04 Triumph has carbs? How barbaric. Might also want to check the butterfly-angle at idle and synchronization of the carbs.
