Claris 1x?
All that is needed to convert any bike from a 2/3x is removing the front derailleur and changing the chainrings on the crankset to a single narrow/wide style chainring.
Maybe install a chain catcher. Other than the likely need to resize the chain, there's really not much to it.
The biggest decision you'll have to make is what front chainring size you want to run. 42T is a popular choice, but it depends on what sort of terrain you're riding and what range of cogs you have in the back.
Is there even a 40t+ cassette available for 8-speed? You can go up to 36t easily enough with a Shimano 8- or 9-speed mountain derailleur, and it'll work with Claris shifters. I'd recommend something with a clutch ("shadow derailleur") for extra chain-drop protection. The Claris derailleur is rated for up to 32t so it'll probably handle 34t no problem.
On the topic of narrow-wide chainrings, do they work with 8-speed chains? I remember at least one manufacturer (Wolf Tooth?) recommends a 10-speed chain even when running a 9-speed cassette.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,102 Times
The biggest 8-speed cassette I remember seeing is Shimano Megarange 11-34. Claris are rated for a 32 bottom which means they could probably eke out a 34 but no one should tell you it will definitely work.
Not sure you need the NW ring or the chain catcher on a road bike.
I feel like replacing the RD and the ring and the cassette and the chain and the tires and maybe adding a catcher is going to cost a lot in comparison to the Claris-level bike itself.
Genesis 49:16-17
Genesis 49:16-17
Disco Infiltrator
Liked 2,102 Times
Sorry for reviving this, I have Claris dropbike shifters and was interested if I need to do anything else if I don't want bigger cassete at the back and just want to convert my bike to 1x. So just front chainrings and chain adjustment?
Sunshine
Quoted: 10902 Post(s)
Liked 7,393 Times
But yeah, if you want a more 'real' 1x then you could buy a new crank and 1x ring then slap that on and shorten the chain.
You will still have the left shifter with paddles that do nothing. There is no Claris 1x left brake lever to use so it looks cleaner.
Giffyguy
Hybrid Bicycles
3
03-24-17 01:05 PM
Carloswithac
Mountain Biking
6
09-23-13 10:16 AM
Sebber
Mountain Biking
3
05-14-11 07:50 PM
