QR hub: diameter of hollow hub axle
Old 07-04-22, 07:51 AM
anga
Quoted: 82 Post(s)
Liked 21 Times in 18 Posts
The skewer of a QR has a diameter of 5mm.
What is the diameter of the hollow hub axle (skewer is inserted into this)? Is this diameter a standard?
Thanks
anga is offline
Old 07-04-22, 08:28 AM
HillRider
Quoted: 1892 Post(s)
Liked 871 Times in 615 Posts
The ID of a qr hub is nominally 5mm and allows passage of the skewer. Pretty much all qr hubs are the same.
HillRider is offline
Old 07-04-22, 08:30 AM
Iride01
MotuekaCascadeChinook
Iride01's Avatar
Quoted: 4639 Post(s)
Liked 3,144 Times in 2,190 Posts
I don't think there is a "standard". However since the outer diameter of the axle is somewhat controlled by the slot in the fork ends or drop outs and the skewer has to have room to be installed and removed, that over the many many years skewers have been with us that most holes through axles requiring a skewer will be pretty close to the same. I doubt any manufacturer wanted to risk making a product that wouldn't work with others for this particular application and time period. Might see some differences because of the grade of steel or other material that is used for the axle. But not so much that one skewer won't work with another.
Iride01 is offline
Old 07-04-22, 08:31 AM
t2p
Bikes: Cannondale - Gary Fisher - Litespeed - Schwinn Paramount - Schwinn (lugged steel) - Trek OCLV
Quoted: 274 Post(s)
Liked 247 Times in 175 Posts
the shaft of many (most) titanium skewer quick releases measure close to 4mm
t2p is offline
Old 07-04-22, 08:34 AM
Polaris OBark
Dirt Roadie
Polaris OBark's Avatar
Quoted: 851 Post(s)
Liked 1,238 Times in 699 Posts
My steel skewers are all 4.5mm in diameter, and the nuts that go on the threaded end are all interchangeable. The bore (inner axle diameter) is 5mm. The conical springs keep the skewer centered.
Polaris OBark is offline
Old 07-04-22, 08:35 AM
Polaris OBark
Dirt Roadie
Quoted: 851 Post(s)
Even if they are 4.5mm like steel, they will be significantly weaker at that diameter. That is why I would never use them in applications where failure could kill me.
Likes For Polaris OBark:
Old 07-04-22, 09:49 AM
anga
Quoted: 82 Post(s)
Thanks
From https://www.bikeradar.com/advice/buy...xle-standards/
A quick release wheel has a hollow axle, 9mm in diameter at the front and 10mm at the rear, with a 5mm diameter skewer that passes through it.
anga is offline
Old 07-04-22, 10:29 AM
sweeks
sweeks's Avatar
Quoted: 822 Post(s)
Liked 363 Times in 268 Posts
I've been riding with titanium skewers for 20+ years. I realize that that doesn't mean they couldn't break next time I ride, but titanium has very nearly the same tensile strength as stainless steel:
"Stensile (sic) strength measures the maximum stress that a structure can sustain. Stainless steel’s tensile strength is 485 MPa versus titanium’s 480 MPa. For some additional perspective, aluminum has an MPa of only 90 and copper’s MPa is only 200."
SOURCE
That's about a 1% decrease in tensile strength.
EDIT: I found a value closer to the one you quoted HERE in Table 1. I can't explain the discrepancy, but I *can* verify that my titanium skewers have held up for over 20 years. I'm not a metallurgist!
sweeks is offline
Old 07-05-22, 06:46 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3038 Post(s)
Liked 2,159 Times in 1,288 Posts
The shaft is typically about 4.5mm diameter, but the threaded section is created by rolling the threads rather than cutting them, so the diameter of the threaded section ends up 5mm diameter.
JohnDThompson is offline
Likes For JohnDThompson:
Old 07-05-22, 01:24 PM
bboy314
bboy314's Avatar
Quoted: 98 Post(s)
Liked 156 Times in 92 Posts
It seems like you’re asking for the diameter of the axle, which should be 10mm for a normal QR rear wheel, or 9mm for a front.
bboy314 is offline
Old 07-05-22, 03:36 PM
Andrew R Stewart
Andrew R Stewart's Avatar
Bikes: Stewart S&S coupled sport tourer, Stewart Sunday light, Stewart Commuting, Stewart Touring, Co Motion Tandem, Stewart 3-Spd, Stewart Track, Fuji Finest, Mongoose Tomac ATB, GT Bravado ATB, JCP Folder, Srewart 650B ATB
Quoted: 3570 Post(s)
Liked 2,427 Times in 1,542 Posts
If the question is what is the axle's through hole, that positions the QR skewer, than I would speculate it's slightly bigger than 5mm to allow for a bit of clearance. I also suspect that different axle manufacturers will have their axle "holes" a tad different but all close to the same dimension. Of course one could measure and then we would not have to wonder which aspect was in question, or what the dimension actually is. Andy
AndrewRStewart
Andrew R Stewart is offline
Old 07-05-22, 03:37 PM
Andrew R Stewart
There have been 9.5mm (3/8") axles with a QR capacity. I suggest measuring what's actually in play. Andy
AndrewRStewart
Old 07-05-22, 03:45 PM
Polaris OBark
Dirt Roadie
Quoted: 851 Post(s)
I deleted my reply because I thought it must be wrong.
Anyway, thanks for that link.
I think the difference must be stainless steel vs. more "normal" alloys of steel. I also discovered one pair of my skewers is indeed Ti.
Old 07-05-22, 04:12 PM
Trakhak
Quoted: 1208 Post(s)
Liked 1,145 Times in 665 Posts
There may have been rare exceptions to the use of standard-diameter skewers (and thus hub axle I.D.s). I have a vague memory of Weyless hubs using proprietary dimensions for their hubs. Maybe larger-diameter aluminum skewers. Could easily be wrong, though.
Trakhak is offline
Old 07-06-22, 05:53 AM
anga
Quoted: 82 Post(s)
I am indeed asking for the inner diameter of the axle's through hole.
Is it possible that 9mm and 10mm are the outer diameters of the hollow tube that is the axle's through hole?
anga is offline
Old 07-06-22, 06:37 AM
bboy314
bboy314's Avatar
Quoted: 98 Post(s)
Yes, that is correct.
bboy314 is offline
Old 07-06-22, 11:33 AM
Ironfish653
Dirty Heathen
Ironfish653's Avatar
Bikes: 1997 Cannondale, 1976 Bridgestone, 1998 SoftRide, 1989 Klein
Quoted: 709 Post(s)
Liked 585 Times in 363 Posts
A Ti fastener will always be weaker than the same fastener in steel, but significantly lighter.
You can have Strong, Light,or Cheap: Pick Two. Lightness generally comes at the expense of Strength.
Nobody is making you put Ti skewers on your LHT.
(Also, if your QR skewer is a weight- bearing element; you're doing something wrong)
Ironfish653 is offline
Old 07-06-22, 11:39 AM
Polaris OBark
Dirt Roadie
Quoted: 851 Post(s)
I would prefer strong >> (light or cheap). I'm using Dura Ace and DT Swiss for that reason.
The usual mode of failure is for the threads to strip out the nut, or to strip off. (I suppose they can also break the spindle from over-stretching while over-tightening, but titanium is actually more able to withstand that than is steel.)
This is probably most important for folks who have disc brakes and quick-release (rather than thru-axle). Because of the downward force during braking, the wheel has a tendency to move within the dropouts of the fork, or will even have a tendency to be ejected from the fork if the dropouts aren't forward-facing. This encourages the user to crank down on them as much as possible. Before I got internal cam Dura Ace and DT Swiss skewers, my front wheel would need to be re-seated after hard braking or I would get a bit of pad rub on the disc. If you are going to crank it down hard, you will want strength.
Thru axles weigh a lot more than quick release skewers and their end-caps, and I have never heard anyone complain about their weight.
Old 07-06-22, 11:45 AM
Ironfish653
Dirty Heathen
Quoted: 709 Post(s)
Ritchey had a DH MTB hub in the late 90s/early '00s that used a 9mm "skraxle" (9-F/10-R) kinda like a thru-axle, but for QR dropouts.
One of those transition technologies from the end of the 26'er era.
Old 07-06-22, 12:28 PM
GhostRider62
Quoted: 1669 Post(s)
Liked 1,381 Times in 874 Posts
The outer diameter of the axles on my wheels are either 15mm (6802 or 6902 bearings) or 17 mm (6803 or 6903 bearings).
My old crap with loose balls is 10 mm IIRC
GhostRider62 is offline
Old 07-06-22, 12:50 PM
Ironfish653
Dirty Heathen
Quoted: 709 Post(s)
I can see, in a QR skewer application, that the 'stretch' inherent in a Ti fastener might be considered beneficial, but it's been my experience that Ti fasteners tend to deform (twist or elongate) at a much lower threshold than the same fastener in steel. One of our manipulator systems uses a lot of Ti M5 fasteners, and we've had enough bolts broken during routine maintenance, that fleetwide standing instruction is that no component installation is to be done on them without a properly set torque wrench (no hand-tightening)
Ti is too finicky, IMHO, for field repairs on something as basic as a bicycle.
Old 07-06-22, 01:40 PM
Polaris OBark
Dirt Roadie
Quoted: 851 Post(s)
I didn't realize the external cam QR skewers I replaced with internal cam steel skewers (and later, DT Swiss steel skewers) were titanium until a couple of days ago. I had just assumed that the problem was that they were external cams, but it might be the titanium was stretching under load a wee bit.
Old 07-06-22, 02:59 PM
79pmooney
A Roadie Forever
79pmooney's Avatar
Quoted: 3546 Post(s)
Liked 2,343 Times in 1,534 Posts
Yes, titanium stretches twice as much as steel for the same force applied. This means the the QR needs to pull the skewer measurably farther. So, either the lever assembly needs to be bigger to keep the hand force needed the same or the tension in the skewer is lower. I like nice clean levers. I also like nice tight skewers that keep rear wheel locked solid in horizontal dropouts and front wheels from ever coming out. (I won't use a disc brake mounted behind the hub because introducing a large lifting force to the fork when braking just seems to me like a really bad idea.)
So, for me - no discs and simple, reliable, all steel (aluminum levers and heads are OK) internal cam QRs of modern design (the new cam shape, not the old Campy NR shape with it's far less secure locking). Good thing is such levers are easy to find. Lesser modern all steel Campy QRs are sweet. So is my Ultegra of the 9-speed era. I have a really cheap modern Shimano that looks its price range with really good action; as good as anything I've used.
79pmooney is offline
Old 07-15-22, 09:11 AM
anga
Quoted: 82 Post(s)
Thread has acquired a life of its own, discussing titanium vs steel skewers
Nothing to do with original topic!
anga is offline
Old 07-15-22, 09:19 AM
Andrew R Stewart
As the OP topic has been answered by a few here I would not be bothered by continuing blabbing. Andy (who questions the claim of older Campy NR skewers being of poor clamping force)
AndrewRStewart
