Shimano 11 speed /10 speed compatibility
Bikes: '85 Peugeot Triathlon, '92 DeRosa Nuovo Classico, '93 DeRosa Titanio, '00 DeRosa Neo Pro, '00 Gary Fisher Marlin, '14 Cervelo R3, '14 Focus Mares
Hello,
I have seen lots of info out there on interchangeability of drive trains, a lot of good stuff from Sheldon Brown, but this combo is using a bit newer components than his info covered at the time, so I was not able to find out if anyone has tried this or has any idea if it would work:
Any possible compatibility for 11 speed Shimano DA Shifters to 10 speed Shimano cassette?
I can use either 10 speed or 11 speed rear derailer.. and can use either 10 speed or 11 speed chain.. a little noise does not bother me.. Main reason for this as is so often true, is I got good deals on the parts and would like to use them to upgrade from my 8 speed system.
Just wondered if this could work.. the info I have so far is that 11 speed spacing on the cogs is 2.18 mm and 10 speed is 2.35mm, Jtek shiftmate does not seem to have a combo like this listed for it's pulleys.
thanks for any reply..
Jeff
Jeff
Bikes: Yes
Quoted: 3230 Post(s)
Liked 3,868 Times
You could probably put an 11-speed cassette on an 8/9/10-speed hub by removing the smallest cog then set the derailleur limits so it stays in that range.
My Bikes
My Bikes
Quoted: 7348 Post(s)
Liked 2,465 Times
I don't see how this can work. The shifters move the cable a prescribed amount which is appropriate to only one size cassette.
