Stages Left Power Meter ADC Value Changes
Quoted: 28 Post(s)
Liked 33 Times
I just picked up a Stages Left Power Meter. I zero' cal'ed it off the bike to check that value and received an 882. Right after installation though, the ADC value changed to 843. That feels like a huge change.
Has anyone had their calibration value change significantly after installing the left crank?
Quoted: 20810 Post(s)
Liked 9,456 Times
Why even check it when it's not installed? 843 is within the expected range - just ride it.
Quoted: 28 Post(s)
Liked 33 Times
But yeah, in theory, it should be fine for now.
LR÷P=HR
Quoted: 867 Post(s)
Liked 1,204 Times
When you checked it off the bike, did you suspend it vertical with the pedal attached?
Zero cal has to be vertical and the weight of a pedal may slightly change the number.
Barry
A little off topic but here you go....
Last week my coach queried the power readings of my Stages R8000 dual and my Wahoo Kickr Bike.
(Note: the Wahoo Kickr BIKE, not a Kickr Trainer you attach a bike to).
Coach thought the Stages vs Kickr Bike numbers might be different and cause issue when comparing indoor/outdoor rides.
So, I borrowed a pair of Garmin Vector 3 pedals (dual).
I attached the pedals to the Road bike and compared Stages to Vector 3.
I attached the pedals to the Wahoo Kickr Bike and compared Kickr Bike internal power meter to Vector 3.
Across the range of powers I tested at, the Stages and Kickr were within ~1W or each other and the Vector 3 read about 2-3W higher.
I count that as a win, and well within the published margin of error for the devices.
He who has a watch knows the time, he who has two watches is never sure.
Well, I'm a lot more sure now.
8-)
Barry
Barry
8-)
Barry
