Nishiki NFS Prestige HELP!
Hello,
sorry for my English
I just buy this frame (only frame/fork) and I need information tech for assembly.
Is an Nishiki NFS Prestige serial number
JR300329
I can't post photo because I don't have send 10 post on forum... But I post when I can!
Do you have information of headset and BB standard's?
JR300329
Likes For VGBike:
Quoted: 5888 Post(s)
Liked 3,471 Times
You will be limited in posting photos until you have 10 posts (it's an anti-spam measure). You can create an album if you look under your profile and post pictures of the bike. Pics will help.
Vouz est francais, n'est pas? Soyez le bienvenue ici.
Likes For brian3069:
Quoted: 1557 Post(s)
Liked 1,732 Times
For the headset- this looks like a normal 1" threaded headset. You just have to measure the fork where it mates up with the bottom crown race, to see if it's 27.0 or 26.4mm
As to Bottom bracket, it's almost for sure a BSA bottom bracket.
Quoted: 4722 Post(s)
Liked 3,036 Times
I have seen maybe a handful of these models. Only one was posted by an American based member. All the other seem to be from Europe, so I'm assuming it is a European market model. All have had the extended head tube and appear to have steeper than normal seat tubes, so I believe they were aimed primarily at triathletes. All the NFS models I've seen do not use standard 700C wheels but the smaller 650C which was popular with triathletes.
Based on the serial number, I'd guess this frame is circa 1993-1994. There's a good probability that it uses an off-the-shelf Tange fork, in which case there should be a two character, alpha-numeric date code on the fork's steerer tube.
As noted, the BB threading should be BSC/English/1.37" x 24TPI. You'll have to measure the crown race diameter to determine which of the two standards apply.
Thanks for informations, they confirmed that me say the girl who sell me the frame
Liked 3,036 Times
This it not the type of frame that I would choose for an urban utility bicycle. The frame was designed for 650C wheels, not 650B. While the latter may fit, the frame probably won't accept very wide tyres and the geometry is not conducive to utility riding.
[QUOTE=T-Mar;22106623]I have seen maybe a handful of these models. Only one was posted by an American based member. All the other seem to be from Europe, so I'm assuming it is a European market model. All have had the extended head tube and appear to have steeper than normal seat tubes, so I believe they were aimed primarily at triathletes. All the NFS models I've seen do not use standard 700C wheels but the smaller 650C which was popular with triathletes.
For the fork hay two inscription "Omni" under the head tube and "omni OE-07" on the patte, and two stickers Tange Super LiteI make photo on album "fork Tange"
