Auuuuuggh....please help
Bikes: Motobecane Fantom Cross 2008 Schwinn Super Sport 1972 SS. Surly Pacer Rando bike
My favorite ride is my 72 Schwinn Super Sport that I converted to a single speed commuter last year. This morning, I managed to shear off one of the bolts holding the rear fender with almost no part of the bolt protruding. I do good work, what can I say. Is there a way to get this out that I can do? I don't really want to damage the frame, and I want to be able to get my fender back on. Please help.
You Know!? For Kids!
If enough is sticking out, you can grind a slot in it with a dremel tool or drill with a cut off wheel and then use a flat bladed screw driver to back it out.
Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Looking at the second photo it appears that there is some of the bolt sticking out, I would get a pair of needle nose pliers and grab it and unscrew it. Drillng it out or drilling a pilot hole for an extractor may damage the existing threads unless you are VERY careful.
Last edited by cyclist2000; 08-27-10 at 08:46 AM. Reason: fingers don't type what I think
Quoted: 9 Post(s)
since the head of the bolt is off their is no tension on the threads. if it is not seized it will come off easily. dont forget to give it a shot of penetrating lube
17yrold in 64yrold body
Sears sells a set of bits made for just this. They look like reversed drill bits--you run them in a cordless drill in reverse, and start a hole (with the proper size bit), and at some point, the bit gets enough grip inside the screw to unscrew it. Then you just remove it from the bit.
Bikes: '93 Performance R203, '83 Bianchi 980
i have a 4" slip joint pliers that i use in cases like this, if there is enough material to grab.
they grip much better than needle nose. craftsman brand
If it's a bit sticky then using a hacksaw or Dremel to cut a shallow slot in the end to allow use of a small flat blade screwdriver will remove it for sure.
