Fixed from old mtb (chain line problem)
Bikes: BMC SLR01; Cannondale Trail; Lot's of project and vintage bikes..
Quoted: 333 Post(s)
Liked 168 Times
Hello, i restored an old MTB frame from late 1987.
My idea was to convert as a fixed bike, i ordered a track gear but when i mounted on the hub noticed that the chain line seems very problematic, since the hub is very short.....
Which are the possible solution without discarding the new sprocket?
Quoted: 5778 Post(s)
Liked 2,576 Times
That appears to be a traditional cup/cone hub on a threaded axle.
If so, simply remove both end caps (no need to remove cones unless you also want to service the bearings while at it). and transfer some spacers from right to left to move the shell to where you need it. Once the chain line is right, redish the wheel based on the new hub spacing.
On a separate but IMPORTANT note, be aware that riding fixed using a hub that isn't counter-threaded for a lockring, is problematic and could be dangerous if you're depending on reverse thrust (pedal resistance) for braking. I've heard all sorts of excuses from "using superglue" to "I don't use back pedal pressure" and still consider this a somewhat dangerous way to make a ghetto fixed gear.
OTOH- if your goal is simply going single speed, a single freewheel will solve your problems.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Quoted: 1819 Post(s)
Liked 1,693 Times
Quoted: 333 Post(s)
Liked 168 Times
All this. I don't know about what you plan to do with this bike, hoping that you don't plan on actual mountain biking. Single speed mountain biking with a single speed freewheel has an enthusiastic following that I don't get but do not disparage. However fixed gear on tricky singletrack is a recipe for disaster. Imagine, you are approaching a log that you have to get over, but you cannot adjust the position of your pedals as you approach so your feet may be in that magic position where one pedal contacts the log head on as you go over. You will STOP right then probably throwing you over the handlebar ending up who knows where. Fixed gear should not be used off road
Clark W. Griswold
Quoted: 4349 Post(s)
Liked 3,986 Times
They make 130mm and 135mm fixed gear hubs you could build a wheel with one of those otherwise I wouldn't do it. Get the proper single speed hub or just run a normal freewheel and just keep your chain on one gear if you are really that cheap.
