Question About Suntour Bar End Shifters
Old 09-07-22, 02:27 PM
cpsqlrwn
OldSchool
Quoted: 82 Post(s)
Liked 28 Times in 20 Posts
If one were to buy a set of Suntour Bar End shifters and the listing indicates that they are 6 speed, would it be expected that those shifters would also be capable of handling 7 speed? Not getting an answer from the seller so I need a little help here. Thank you for any info.
cpsqlrwn is offline
Old 09-07-22, 02:52 PM
clubman
Phyllo-buster
clubman's Avatar
Quoted: 2298 Post(s)
Liked 2,054 Times in 1,254 Posts
I suspect they will shift 7 in friction mode. I own one of the 6 speed levers but I was surprised that there is no ratcheting when in friction mode...it behaves like any downtube shifter. I don't know if this is normal or whether it's a fault of the one I own. I haven't tried it on a 7 speed block.
You'll note that the catalogue describes them as 6 speed in index mode but no reference to the power ratcheting when switched to friction. The left side is always power ratcheting. It's odd.
clubman is offline
Old 09-07-22, 05:45 PM
cpsqlrwn
OldSchool
Quoted: 82 Post(s)
Mine are shown below, no friction or indexed selection option. Just standard vintage friction style with ratcheting (clicking) feature but no indexing. Advertised as 6 speed. Would you expect that they would do 7 with no problem?
cpsqlrwn is offline
Likes For cpsqlrwn:
Old 09-07-22, 05:48 PM
bikemig
bikemig's Avatar
Quoted: 5888 Post(s)
Liked 3,471 Times in 2,079 Posts
Yes.
bikemig is offline
Likes For bikemig:
Old 09-07-22, 06:47 PM
TiHabanero
Quoted: 1744 Post(s)
Liked 1,370 Times in 719 Posts
I have the Suntour Bar Cons on several bikes. I have been able to get them to work with a Shimano 10 speed cassette mated to a Dura Ace 9 speed derailleur. Chain stay length is 43cm, cable housing is Suntour shift housing for indexed systems. It works, just takes a bit a tinkering to cover the full range. Works better with 9 speeds or fewer.
I also have a set of Suntour Accushift 7 speed indexed shifters on a bike, but run the indexed shifter on the front der, and the ratchet shifter on the rear der. It works really well for some reason!
TiHabanero is offline
Likes For TiHabanero:
Old 09-07-22, 06:53 PM
bikemig
bikemig's Avatar
Originally Posted by TiHabanero
snip . . .
Odd set up. I like it.
bikemig is offline
Likes For bikemig:
Old 09-07-22, 07:13 PM
JulesCW
Bikes: N+1
Quoted: 229 Post(s)
Liked 651 Times in 319 Posts
I regularly use the original Suntour bar-cons you're considering-- non-indexed -- to shift 5 through 9-speed rear freewheels and cassettes without issue. They're the bee's knees!
JulesCW is offline
Likes For JulesCW:
Old 09-07-22, 07:57 PM
clubman
Phyllo-buster
clubman's Avatar
Yup. You've got the standard barcons that really aren't 6 speed, or 5, 7 , 8, 9 speed. As noted they have great range and are the better choice. What I love about these is that you find yourself thinking that you're riding indexed when you're enjoying the ride.
clubman is offline
Likes For clubman:
Old 09-08-22, 06:58 AM
cpsqlrwn
OldSchool
Quoted: 82 Post(s)
Thank you for all the responses and excellent information. Thought this was the case but still quite pleased with all the confirmations. Great to know that I can use these with 9 or even 10 speeds down the road. Much appreciated.
cpsqlrwn is offline
Likes For cpsqlrwn:
Old 09-08-22, 07:40 AM
The Golden Boy
Extraordinary Magnitude
The Golden Boy's Avatar
Quoted: 2608 Post(s)
Liked 1,699 Times in 935 Posts
As has sorta been mentioned- there's several iterations of Suntour's BarCon.
The original, all-friction stubby.
Then there's the Accushift 6 and 7 speed version.
My guess there is a later Accushift 6 and 7, as well as 8 speed version after they lost the lawsuit over the ability to switch from index to friction. There was a later "Light Index" setting that was just a less robust click. IMO- it was useless, it wasn't friction. While the left was the ultra fine late "Power" ratcheting.
Accushift is much less forgiving about it's tolerances than SIS, so 6 is 6 speed, 7 is 7 speed, 8 is 8 speed- AND it really only works with an Accushift compatible RD.
Lots of people have lots of kludges for making SIS stuff work with Accushift stuff... but I think you'll find what one person says works, another person says doesn't work and vice versa.
Commence to jigglin’ huh?!?!
The Golden Boy is offline
Likes For The Golden Boy:
Old 09-08-22, 01:21 PM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,751 Times in 938 Posts
The friction bar ends will easily accomodate six or seven speed. The indexed six speed will not work well with a seven speed. One click to few but going from a seven speed set to a six cog freewheel will work.
When and if using the friction bar ends, keep in mind that the more cogs, the more precise you have to be to nail the sweet spots.
I use a seven speed indexed set of my Jamaica Bianchi and, absolutely, love them. (By the way, just a few minutes ago, Mrs. Me booked our Jamaica air fair for this year ($1,400 CND return for me and Mrs. Me)...
randyjawa is offline
Likes For randyjawa:
Old 09-10-22, 10:00 PM
Frenzen
Quoted: 94 Post(s)
Liked 12 Times in 10 Posts
Nice shifters, and why do you keep your bottles like that?
Frenzen is offline
Likes For Frenzen:
Old 09-10-22, 11:48 PM
randyjawa
randyjawa's Avatar
They are not my bottles. They are our bottles!
Often times, the plastic bottles are carelessly discarded by human beings. Jamaica attracts a lot of tourists that, coupled with many local inhabitants, carelessly toss their plastic drink bottles away, here, there and everywhere, making quite a mess of a beautiful island. A clever local fellow makes the cages, that look like big fish, out of welded re-rod (steel 1/2" rods) and chicken wire with the hope that people will toss their used/emptied plastic bottles into the cages. This unique opportunity, as you can see in the pictures, encourages a more environmentally friendly way of throwing away those emptied bottles. Personally, I think it is a great idea and these steel and chicken wire fish are now all over the place.
Thanks to the pandemic, my wife and I missed spending our winter in Jamaica last year. But before we left, the year before, the Jamaican government had issued a law banning plastic bags and plastic bags, carelessly tossed away, also were making a horrible mess in an, otherwise, truly beautiful environment. Sometimes, government does have the courage to get it right.
Old 09-11-22, 11:26 AM
Frenzen
Quoted: 94 Post(s)
This is a great idea about make sculptures out of bottles, also Canada is onto something similar about banning single plastic bags but I think people should just bring resusable bags for fruits and groceries . Oh nice see you having a vacation with the Mrs (I thought you guys were separating but none of my business!). How did you get that bike into Jamaica, or it stays there all year long?
Frenzen is offline
Old 09-11-22, 05:28 PM
randyjawa
randyjawa's Avatar
@Frenzen...
My wife and I have been married for 54 years, come December 7th. Separation does not seem to be in our future.
Old 09-11-22, 09:49 PM
Frenzen
Quoted: 94 Post(s)
@Frenzen...
My apologies, well do show us more cool stuff and enjoy your vacation!
Frenzen is offline
Old 09-11-22, 11:45 PM
tcpasley
Quoted: 47 Post(s)
Liked 9 Times in 7 Posts
There is a legend that 6 speed SunTour Accushift shifters can provide indexed shifting of 7 speed Shimano freewheels if you use a Shimano rear derailleur. I think this was even mentioned by the late Sheldon Brown on his site, but I can't find that reference any more. Maybe someone else here has more evidence of this. It has something to do with the built-in overshift the shifters have at either end of the range.
I have 2 sets of 6 speed Accushift barcons, but I haven't yet tried the 7 speed trick myself.
tcpasley is offline
