Bottom bracket treasures
I am not sure what these extra dust caps are for or what befell the poor bearing cage but it was like pandoras box in the bottom bracket shell of this Miele Uno LS. These were all lying in there.
Quoted: 1372 Post(s)
Liked 1,751 Times
One never knows what surprises will present themselves when opening up a cavity. Stuck posts or stems. Not round balls. Pitted races are really the pits. One never knows.
I have shown this bottom bracket treasure before but I do get a kick out of showing it, now and again...
Likes For randyjawa:
Quoted: 3464 Post(s)
Liked 2,829 Times
I have encountered a bottom bracket where the spindle and cups were toast, was a bummer. I saved it as maybe one day I can figure out a way to retrofit sealed bearings into it.
Will need a lathe and some tooling.
Bikes: 1978 Raleigh Competition-1974 Raleigh Folder-1983 Austro Daimler-198? Fuji Monterey-Surly LHT-Surly Karate Monkey-Surly Cross Check
Quoted: 43 Post(s)
Liked 97 Times
The best surprise I ever got from an old bike was the bottom bracket. I bought an old beat up Fuji as an impulse buy for something like $20. I get it home and start to overhaul things a little bit and notice that the bottom bracket requires some special tool that I don't have. Turns out to be a Phil Wood.
Likes For fettsvenska:
Quoted: 1088 Post(s)
Liked 1,205 Times
Quoted: 964 Post(s)
Liked 1,451 Times
I have a bunch of no-good axles and no-good cups and I have access to the lathes that could do it, and I still won't - readily available sealed BBs are going to be lighter, stronger, smoother, and more durable, plus you won't have to machine hardened steel.
Quoted: 1106 Post(s)
Liked 1,327 Times
You may need a mighty good lathe and some tooling you don't really care about. Those BB axles are normally harder than a coffin nail!
And it might not be that difficult, I just took a 26.4 crown race to 27 on a mini-lathe with a carbide tool, it was hardened all the way through; no trouble.
But I agree, in most case off-the-shelf will be better in all those ways than what most hobbyists could do. If I had a crank for which axles were not readily available, like a Gnutti spline or the 3-degree SR, and an axle that was otherwise unusable, it'd be an option.
Liked 2,829 Times
Quoted: 964 Post(s)
Liked 1,451 Times
