Cleat Positioning For Best Power
I just made the transition to road shoes. SPD-SL specifically. I've got the Garmin cleats with 6 degrees of float. I've watched quite a bit of bike fitting on Youtube. I gathered a consensus of opinion that positioning cleats as far back as possible won't create any problems, but they never really said what you can gain from moving them forward a bit. I also caught one suggestion to set cleats to be very slightly pointed to the inside of the center of the toe.
I tried that and it just didn't seem to feel right. I made slight adjustments during my initial ride until it felt like my feet were both pointing straight ahead and my knees felt like there was no strain on them. These road pedals and cleats are far more rigid than my old SPD pedals and cleats. I also made a very slight saddle adjustment to accommodate the stack of the new pedals. I had a little knee pain that was immediately alleviated after that. I was initially just concerned to not have anything setup to create a problem/injury.
I'm now curious if my cleat position is giving me the best power from my legs. It almost feels like having my feet 'straight' for the most part is putting more strain to my inner thighs (hamstrings?) than utilizing what might be the more powerful outer thigh muscles (outer quads)? I'm wondering if having that cleat position pointed slightly to the inside of the center of the toe would increase power and if I might get more use to it with a little time?
On my first ride out with my new Garmin Rally pedals I noticed that I held a 238 watt average power for the first hour of riding before fiddling with the cleat positioning. I'm not sure if everything was calibrated 100% with the Rally pedals. This wasn't an FTP attempt. I had stopped at stop lights, intersections, etc. Just a normal ride. My average power has been fairly significantly less since that first ride. Could just be fatigue too idk. Curious though.
longtime noob
Bikes: 2018 Trek Domane SL 6 // 1999 Trek 5000 // Burley Encore X
Quoted: 46 Post(s)
Liked 63 Times
Just my opinion but trying to game your cleat position for the "most power" seems misguided. Have a shop help you align the cleats so that everything from your feet to your hips are properly aligned. Gaming a few extra watts isn't worth it when you can't ride for more than an hour without knee pain.
I'm digging into it elsewhere a little further now and I see that it is suggested that your natural foot alignment as you walk is how your cleats should be setup? Maybe there isn't a 'best' setup tweak for power. It seems like this might be another topic that would get a dozen different answers from a dozen different people.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
I’m with Greiselman. Adjust your cleats for comfort. Start with a neutral position, whatever feels natural as soon as you lock into the pedals. If you have some discomfort after a long ride, especially something that doesn’t feel right in your knees, make minor adjustments. It might take some trial and error. The forward-back, side-to-side, and heel in-heel out adjustments might all have some influence. Some people are more sensitive to foot position than others, and it can be really hard to say in any case what will work best.
Get to where you can ride comfortably, and then as you put on lots of miles that number on your power meter will gradually increase.
I really like my Speedplay Zero pedals, because of the generous float they allow. I also have some SPD-SLs with yellow cleats, which give six degrees of float, I think. The Speedplays have much more—something like 25 or 30 degrees. And it’s easily adjustable. So, for example, I can set the heel-in limit to keep my shoe from brushing the chain stay, but allow full heel-out movement. They’re called Zero because there is zero resistance until you reach the float limit, where the pedal will disengage. When setting up my shoes with these cleats, I pay a little attention to the width adjustment, but otherwise I don’t worry about anything. I just ride. My feet can move around quite a lot, yet I’m still securely connected to the bike.
I'm getting ready to buy some PM pedals myself and just deciding which ones. Wahoo, which now owns Speedplay, have some ready for release on the retail market any day now. Because I like that style of pedal so much, I kind of want to hold out for them. However, part of me just wants some Garmins or Faveros, as it seems their electronics are better than what Wahoo is reportedly using.
Likes For Broctoon:
Quoted: 18883 Post(s)
Liked 10,646 Times
There isn't one. At least not for everyone. Cycling is an aerobic sport, you use your heart and lungs to make power, the position of your cleats is about comfort and avoiding repetitive stress.
Likes For Seattle Forrest:
Quoted: 2432 Post(s)
Liked 638 Times
I've never noticed a difference in power with the positioning. Like someone said, comfort is the concern for me. Mine are almost but not quite all the way back. If they're more forward I get hot spots on my toes so bad that if I go on a long ride I can hardly push the pedal down by mile 50.
I have to agree that I've never been aware that it was something that I was sensitive to while running SPD pedals. The float with them must be far greater than 6 degrees. In retrospect, if I had my cleats setup with them pointed slightly to the inside of the center of the toe initially then that was making my toes point out and putting more load on my inner thighs (hamstrings maybe?) vs my outer quads. Since I didn't really like that setup very much maybe I can try leaning it the opposite way a tiny bit and see if that suits me better anyway. It may not impact power one iota. I know I didn't really like my toes pointed outward though.
I've just been tuning in much closer to bike fitment issues and it made me question it. Thought I would throw it out there and see if there was any feedback that might confirm it.
Should Be More Popular
Quoted: 22596 Post(s)
Liked 8,925 Times
Agree. I have not seen any good study on this, and I do suspect cleat position has more to do with comfort/stability. Personally, I am old school and just aim to keep the ball of the foot over the pedal spindle, but YMMV.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Quoted: 1814 Post(s)
Liked 923 Times
Cleats further forward uses lower leg muscles more, and favors sprint-type accelerations.
Further back uses those muscles less so favors endurance.
Using cleats to point the feet where they don't want to go is only likely to do damage, IMO.
Likes For woodcraft:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
That’s always been my question for the people who want zero-float cleats. If your feet are not perfectly straight while pedaling, isn’t it better to have float than torque your joints? And if you are in perfect alignment, why does having float that is never used detrimental? I’m willing to accept that there might be something I haven’t thought of that makes it make sense, but no one has ever explained it to me.
Liked 8,925 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
Liked 923 Times
I think it's a lot what one is used to. The float can feel sloppy.
An analogy might be: if you put your feet on the pedals the same way every time, it shouldn't matter if your shoes are a size or two too big.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
For me, the biggest benefit of a pedal-based PM is the ability to easily move them between two or more bikes. This is actually pretty important to me.
Super-duper Genius
Quoted: 768 Post(s)
Liked 984 Times
If you're still experimenting a little and not the most fit guy or gal you know, having a little float makes it less critical to get everything else right. Going even further, Speedplay Zero cleats (that's zero resistance, not zero float) give even more "slop" or room for error.
It's kind of like a one piece handlebar and stem, or an integrated seat mast. If you're sure of what you want, there are benefits to these. I, on the other hand, am always fine tuning many points of adjustment on my bike, so I can't commit to something that permanent or expensive to change.
Liked 10,646 Times
I suspect that the ideal cleat position might even change as muscles fatigue or discomfort starts to develop. Point in favor of Seattle Forrest 's flat pedals -- people riding those can just shift their feet around without even thinking about it.
Blast from the Past
A great starting point if you want to develop a good cleat position over time.
https://www.stevehoggbikefitting.com...leat-position/
I've worked with one of his fitters in Austin in the past. Their methodology on shoes is very effective. I've ended up slightly aft of Steve's "Method 2" position as my riding has shifted more to TT type efforts. But it's a great starting point. I would also recommend float if for no other reason than margin of error for overuse injuries.
Likes For Voodoo76:
Quoted: 4399 Post(s)
Liked 4,844 Times
The best starting point for your feet in terms of toe-in/out is to sit on the edge of a table/stool and let your legs hang down naturally. Note how your feet are pointing (Are they straight, pointed in, or pointed out like a duck?). Basically you want to replicate your natural foot angle on your pedals as that will put the least strain on your knees. If you are a "duck" then you may also need to move the cleats laterally on the shoe (or use pedal spacers) to get enough heel clearance to your crank arms. Floating cleats are good as they give you some room for error.
As for fore-aft cleat position, I always slam mine to the maximum rearward position for endurance. Moving the cleats forward utilises your calf muscles more and gives you more leverage on the pedals, but this can also lead to more fatigue. You also need to adjust saddle height slightly if you move your cleats fore-aft i.e. lower saddle with cleats further back and vice-versa.
Likes For PeteHski:
