Gravity FSX: Need a fix for loosening Quick Release Skewers
Quoted: 46 Post(s)
My FSX bike quick release skewers are loosening up when riding.
What is the fix for this?
Switch to thru axles or is there some type of system to keep the quick skewers from loosening.
Also which side loosens?
Is it both sides, lever side, or the nut side?
Thanks
Thanks
Expired Member
Quoted: 3669 Post(s)
Liked 5,420 Times
Read up on the difference between internal cam and external cam skewers. If you have the external cam type, replace them with internal cam, like Shimano. They probably aren't actually loosening, just aren't gripping well from the start.
Quoted: 980 Post(s)
Liked 582 Times
The internal-cam type is doubtless better than the external cam type, but either kind will fail if not tightened properly.
I have bikes with both types and have never had one loosen unexpectedly.
Likes For sweeks:
Quoted: 1819 Post(s)
Liked 1,693 Times
The fix for this is to learn how to properly install a quick release wheel. Quick releases, if installed correctly, do not loosen. You cannot convert a bike with quick releases to through axle
Likes For alcjphil:
Quoted: 2482 Post(s)
Liked 2,952 Times
Expired Member
Liked 5,420 Times
