Hub gear stand?
Randomhead
Liked 3,696 Times
Does it have a chain that goes into the end of the axle? That could complicate things
Actually, no. The wheel I’m thinking of has a S-A kick shift 2 speed. Should have made that clear. I’m wondering because I see descriptions that include a replacement skewer. Not appropriate for this hub, unless I’m really missing something!
Randomhead
Liked 3,696 Times
Any wheel-on trainer should work. The replacement skewers are so that the cups on the end of the axle holder fit better.
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,182 Times
i think the replacement skewers are so that the wheel on trainer clamps do not break the plastic ends on the standard skewer that came with the bike. i changed mine out to all metal when i was on a CompuTrainer. the plastic ends would never have survived.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 347 Post(s)
Liked 189 Times
I think you probably want something like these, depending on your trainer.
https://www.amazon.com/Tacx-Track-Wh...ct_top?ie=UTF8
Anything up to a Kickr Core should work, I think. Might be a bit of a bother to get it adjusted if your OLD is narrower than 130mm.
Palmer
Quoted: 1663 Post(s)
Liked 1,817 Times
FWIW, the axle nuts on your Sturmey-Archer S2 are 13/32 x 26tpi.
