Bigger Gear Ratio
Quoted: 51 Post(s)
Liked 14 Times
Bigger Gear Ratio
I have 2010 KHS CX-200. Its a nice CX bike from back in the day. Its my gravel bike, among the others. It comes with Tiagra 9 speed shifters and Tiagra front derailleur. Crankset is 9 speed FSA 46/36. Rear derailleur is 105 SS 4600. Shimano says max cog is 27t. Casette on it is 12-25. I would like to get some better gear range for climbing. What would be the cheapest option to go with. I was thinking about maybe going with Alivio M3100 9 speed and 11-36 cassette. I think it would work with 9 speed Tiagra shifters? Another option would be to replace it with new groupset, in which case I might go with Sensah SRX 1x11 with 42t crankset and 11-46 cassette. Not sure which way to go. Any help is appreciated from gurus.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Likes For SurferRosa:
Quoted: 1819 Post(s)
Liked 1,693 Times
OK, so all you need is any Shimano compatible "9 speed" mountain bike derailleur that can handle the sort of cassette you want to buy. Oh, and the cassette and chain of course. Shimano and Microshift both still make derailleurs that will fill your needs
Just kidding, alcjphil. We know you meant MicroShift.
Bikes: More bikes than riders
Quoted: 1446 Post(s)
Liked 762 Times
Instead, I'd recommend a Deore RD-M591. It's one of the last traditional style Deore rear derailer and it's a pretty stout piece. Shimano says it will support up to 34T, but I can say from personal experience that it'll handle at least 36T.
Another option is the Alivio series RD-T4000. It's one step down from Deore in Shimano's line up and is a current production derailer. Like with the M591, it supports up to a 34T, but I run this derailer with a 40T on one of my bikes and it clears it with ease.
Likes For hokiefyd:
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
And yes, Shimano's limits are conservative and can usually be safely exceeded by 2 teeth. I have GS road derailleurs with limit ratings of 32T. I run 34T cassettes with no problems. Just be sure to test it in the stand first and make sure you don't bind the gears when going into the large-large combo.
Quoted: 51 Post(s)
Liked 14 Times
It will, but I've found the Shadow style derailers like these, which don't pivot the upper pulley wheel up with cage rotation, to have sluggish shifting across the smaller sprockets of the cassette, because the chain's further away from meshing tightly with those sprockets.
Liked 762 Times
It's on a fat bike right now with a 22-32-42 3x and a 12-36 cassette. It runs all combinations of that drivetrain well. I was using it in a 1x configuation (36t) with the 11-40 cassette.
It should be pretty easy to make work with a 1x. The T4000's cage is really long...in this case, I'd size the chain so that it pulls the cage forward just enough to clear the 40t sprocket...that should be it. It may be more difficult to make work with a 40t and a 2x/3x setup.
It looks like you were considering it with an 11-36 cassette and 2x...it should support that pretty well.
Bikes: Surly Bridge Club, 1992 Miyata 914
Quoted: 5 Post(s)
Liked 15 Times
You would give up 3-4 mph on the top end but that should not be an issue for gravel or mountain riding.
Likes For wrobertdavis:
Quoted: 51 Post(s)
Liked 14 Times
Have you considered attacking this from the crankset instead? You might possibly be able to change rings to 24-38 and get an improvement in the climbing without much cost or hassle.
Quoted: 51 Post(s)
Liked 14 Times
Likes For bh85:
Quoted: 4201 Post(s)
Liked 3,857 Times
Back when indexing was just becoming "the way" I use to describe component interchangeability this way. "Everything MicroSoft knows about planned obsolescence and compatibilities was learned from Shimano". Not true of course but no one misunderstood my opinion and most agreed Andy
AndrewRStewart
AndrewRStewart
