pedals turning,back wheel is'nt
Quoted: 7 Post(s)
Well can you give me a little more info? Have any pictures? What type of bike, components, etc?
Pedals spin on their own spindle that goes into the crank arm. The crank arms moves the chain which moves the rear wheel. The only reason I could possibly see for the pedals (and cranks) to be moving while the rear wheel does not is if you've absolutely destroyed your freewheel/cassette.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Or a 3-speed hub that's either trashed or sitting between 2nd and 3rd...
Formerly Known as Newbie
+1 to more info. What kind of gearing system (if any) do you have on the rear wheel?
--J
--J
To err is human. To moo is bovine.
Who is this General Failure anyway, and why is he reading my drive?
Become a Registered Member in Bike Forums
Community guidelines
Hello
+1 broken freehub or freewheel
- got one beside me right now ! (got it out of the trash)
- Chain is on - pedals turn crank - crank moves chain- free wheel rotates in both directions - not engaging - Bike remains stationary. Was this a test?
The cure= take it to your local bike shop and have them confirm this preliminary diagnosis and then replace
the freehub body or free wheel. (Unless it's a three speed as mentioned above)
Bikes: 2010 CAAD9-4
I totally had this same problem before I realized that the handlebars go in front. Then I turned my seat around and everything worked.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,171 Times
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
You put the air in the tires from the wrong side of the bike....that's why.......
Chombi
Chombi
Bikes: Giant CRS 2 (2009)
Bikes: '09 Felt F55, '84 Masi Cran Criterium, (2)'86 Schwinn Pelotons, '86 Look Equippe Hinault, '09 Globe Live 3 (dogtaxi), '94 Greg Lemond, '99 GT Pulse Kinesis
Quoted: 389 Post(s)
Liked 269 Times
It's okay, it's okay... some kind soul has replaced your fixed gear monstrosity with a freewheel. Going downhill will be much easier for you now.
