Need 26-plus hard-tail frame.
Old 09-24-21, 03:56 PM
pullings
Quoted: 28 Post(s)
Liked 35 Times in 17 Posts
Suggestions?
My next project is a woods-ebike for my wife.
My rear-drive motor (135mm wide hub) will lace up to a 24" rim with 24x3" tire.
pullings is offline
Old 09-24-21, 05:54 PM
c_m_shooter
c_m_shooter's Avatar
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times in 166 Posts
An old Surly 1x1. They have the low side now, but I think it uses more "modern" hub styles.
c_m_shooter is offline
Old 10-07-21, 02:04 PM
pullings
Quoted: 28 Post(s)
Success!
After searching far and wide for a 26"+ frame I could not locate one.
I found a "Walmart Bike" Kent Saracino hardtail MTB that will serve as a great doner-bike for the aluminum 26 frame.
Not a "26+" frame, but will do the job
......everything else goes into the parts-bin or gets recycled/tossed.
The frame will take my 24x3 tires.
Wheel builds use 507x32mm rims laced up to 135mm rear-hub motor and WM MT3000 front hub.
pullings is offline
Old 10-18-21, 06:55 AM
pullings
Quoted: 28 Post(s)
Rims laced up fine to hubs.....tires clear frame OK.
Frame also has nice triangle for pack/electronics package build
pullings is offline
