Garmin Edge sensors and profiles question
Quoted: 222 Post(s)
Liked 303 Times
I've been using a Garmin Edge 530 for several years without issue. I mostly used it with one bike. I now want to use it with two bikes. One I'll call the road bike and the other MTB. I have a speed sensor on each bike. From what I can tell I cannot assign a sensor to a profile. It appears that either profile (road or MTB) will acquire whatever speed sensor it detects. I've tested this by waiting until all sensors are off (asleep) and regardless of the profile, if I spin the road wheel to wake the road speed sensor that is the sensor used regardless of the profile that is active. If I wait for the sensor to sleep, and spin the wheel on the other bike it wakes and becomes the speed sensor used.
Is this in fact the correct behavior?
Is there an alternative setting? Some way to force a sensor to a specific profile?
In general, I don't see a problem if it works as I seem to think it does. Though I could see if I perhaps I move some bikes around getting ready to ride, it might wake the sensor of a bike I'm not using and cause this to connect to the Garmin rather than the bike I intend to ride.
Anyone have some insights on this?
Thanks in advance.
Thanks in advance.
Quoted: 3238 Post(s)
Liked 2,084 Times
Yes, you have this correct. The sensors are agnostic to which bike is used, or which profile you use. The device will just see whatever sensor is active and use that.
Likes For Steve B.:
Quoted: 18883 Post(s)
Liked 10,646 Times
What you're seeing is the behavior we all get. 🙂
If it connects to the wrong speed sensor it will fix itself as you move out of range of the first.
Likes For Seattle Forrest:
Liked 2,968 Times
If for some reason it doesn't drop the out of range sensor (anticipating it will be back in range) , you can restart the smart device (edge) when you are out of range of the one sensor & only are in range with the desired sensor.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
If by chance both bikes are being ridden close by say with a friend one ca just disable the sensor you don’t want to use. Easy to disable and enable. In sensors select the one and toggle on or off.
Liked 2,084 Times
And know that the speed sensors do not transmit unless the wheel is turning.
